Home » Eclipse Projects » Standard Widget Toolkit (SWT) » Problem with TableTreeViewer and CheckboxTreeViewer -- HELP NEEDED!
Problem with TableTreeViewer and CheckboxTreeViewer -- HELP NEEDED! [message #463758] Mon, 14 November 2005 09:59 Go to next message
Originally posted by: preetamp.aftek.com
I have created a checked box table tree using
checkboxTableTreeViewer = new TableTreeViewer(parent, SWT.CHECK);
and have associated a table tree editor like
final TableTreeEditor tableTreeEditor = new TableTreeEditor(tableTree);
this works fine but now I want to listen for check event of the checked tree
How can I do this ?
I tried
CheckboxTreeViewer checkboxTreeViewer = new CheckboxTreeViewer(
checkboxTableTreeViewer.getTableTree());
checkboxTreeViewer.addCheckStateListener(new
CheckboxTreeViewerCheckStateChanged());
But the control never comes to CheckboxTreeViewerCheckStateChanged class
(function checkStateChanged )
Am I doing wrong ?
what's the correct way to create such a control ?
Thanks in advance
~Preetam
Re: Problem with TableTreeViewer and CheckboxTreeViewer -- HELP NEEDED! [message #463770 is a reply to message #463758] Mon, 14 November 2005 14:31 Go to previous messageGo to next message
Since you created the underlying tree with the SWT.CHCK style you should use
Tree.addSelectionListener() and in the event.detail look for SWT.CHECK
to distinguish the checkbox selection from selecting the row.
"Preetam" <preetamp@aftek.com> wrote in message
news:dla9it$fn8$1@news.eclipse.org...
> tree
> How can I do this ?
> I tried
> Am I doing wrong ?
> Thanks in advance
> ~Preetam
Re: Problem with TableTreeViewer and CheckboxTreeViewer -- HELP NEEDED! [message #464969 is a reply to message #463770] Fri, 02 December 2005 07:03 Go to previous messageGo to next message
Thanks !
I did that
But now i have one more problem !
The tree i created looks good on windows 2K
but does not look proper on Linux Fedora core 3
I means on fedora the nodes at verious levels of tree should get indented to
right. The tree hirarchy should get clear.
I m attaching the sample pic.
See that node1 has child node2 which has also a child node3
The relation between node1 and node2 does not get seen properly wheare as
the relation between node2 and node3 is clear deu to indentation !
Any clue ?
~Preetam
"Veronika Irvine" <veronika_irvine@oti.com> wrote in message
news:dlaom2$7m3$1@news.eclipse.org...
use
> > Hi,
> > tree
> > How can I do this ?
> > I tried
> > Am I doing wrong ?
> > Thanks in advance
> > ~Preetam
  • Attachment: tree.jpg
    (Size: 7.90KB, Downloaded 259 times)
Re: Problem with TableTreeViewer and CheckboxTreeViewer -- HELP NEEDED! [message #465094 is a reply to message #464969] Mon, 05 December 2005 16:54 Go to previous message
This is a known problem on GTK - indentation is not supported. This is why
in 3.1 we deprecated TableTree and added support for Tree with TreeColumn.
See:
http://dev.eclipse.org/viewcvs/index.cgi/org.eclipse.swt.sni ppets/src/org/eclipse/swt/snippets/Snippet170.java?rev=HEAD& amp;content-type=text/vnd.viewcvs-markup
TreeViewer also supports TreeColumn.
news:dmpd62$5qv$1@news.eclipse.org...
> Thanks !
> I did that
> to
> Any clue ?
> Thanks
> ~Preetam
> use
>> > Hi,
>> > tree
>> > How can I do this ?
>> > I tried
>> > class
>> > Am I doing wrong ?
>> > Thanks in advance
>> > ~Preetam
Previous Topic:Popup windows / date entry content completition
Next Topic:Why is composites like Table not intended to be subclassed?
Current Time: Sat Jul 26 11:04:51 EDT 2025
Powered by FUDForum. Page generated in 0.03957 seconds
