Home » Eclipse Projects » Standard Widget Toolkit (SWT) » clipboard content not up to date
clipboard content not up to date [message #463317] Thu, 03 November 2005 06:57 Go to next message
Hi everybody!
I want to get selected text from an ole-integrated acrobat reader.
At present, to get the string, I select the text with the mouse, press
ctrl+c and press a button that reads the content clipboard.
To shorten the workflow, I post an "ctrl+c" keyevent to the display just
before I read the content of the clipboard.
The unsatisfying result of this operation: I get the old clipboard content.
The content is actual, only when I part the actions!
Can anybody help me with this problem?
I've written some code to illustrate this problem.
Just enter some text, press the "ctrlc" button (watch debug output) and at
the end "show clipboard".
Thank you,
Florian
import org.eclipse.swt.widgets.*;
import org.eclipse.swt.SWT;
import org.eclipse.swt.events.SelectionEvent;
import org.eclipse.swt.events.SelectionAdapter;
import org.eclipse.swt.layout.GridLayout;
import org.eclipse.swt.layout.GridData;
import org.eclipse.swt.dnd.Clipboard;
import org.eclipse.swt.dnd.TextTransfer;
public class clipboardTest{
static Clipboard cb = null;
static Display display = null;
public static void ctrlc(Text text){
System.out.println("ctrlc");
text.setFocus();
Event event = new Event();
event.type = SWT.KeyDown;
event.keyCode = SWT.CTRL;
display.post(event);
event.character = 'c';
event.type = SWT.KeyUp;
}//ctrlc
public static void showClipboard(){
TextTransfer transfer = TextTransfer.getInstance();
String data = (String) cb.getContents(transfer);
System.out.println("clipboard: " + data);
}//clipboardZeigen
public static void main(String[] args){
display = new Display();
cb = new Clipboard(display);
final Shell shell = new Shell(display);
shell.setLayout(new GridLayout(1, false));
final Text text = new Text(shell, SWT.BORDER);
text.setLayoutData(new GridData(GridData.FILL_HORIZONTAL));
Button ctc = new Button(shell, SWT.PUSH);
ctc.setText("ctrlc");
Button showClipboard = new Button(shell, SWT.PUSH);
showClipboard.setText("show clipboard");
shell.pack();
shell.open();
ctc.addSelectionListener(new SelectionAdapter(){
public void widgetSelected(SelectionEvent event){
ctrlc(text);
showClipboard();
showClipboard.addSelectionListener(new SelectionAdapter(){
showClipboard();
while(!shell.isDisposed()){
if(!display.readAndDispatch()) display.sleep();
display.dispose();
Re: clipboard content not up to date [message #463357 is a reply to message #463317] Fri, 04 November 2005 04:37 Go to previous messageGo to next message
I found an other posting of the same problem:
http://dev.eclipse.org/mhonarc/lists/platform-swt-dev/msg045 92.html
but no answer :-(
F
Re: clipboard content not up to date [message #463393 is a reply to message #463357] Fri, 04 November 2005 14:37 Go to previous message
When you use Display.post to post the Ctrl+C key events, this is quite
different from using the Clipboard.setContents() method. Your question is
not the same as the one in msg04592.html.
When you use Display.post, you add events to the event queue. These events
are not processed until the event loop is run. That means when you call
clipboard.getContents() right after posting CTRL+C, you should still get the
old clipboard contents because the CTRL+C is still waiting in the queue to
be processed.
"Florian Huber" <fhuber@picturesafe.de> wrote in message
news:1d044f35e1cc1eaf688af1293cb3b2aa$1@www.eclipse.org...
> but no answer :-(
> F
Previous Topic:Update font size immediately
Next Topic:SWT.VIRTUAL TableViewer not sorting
Current Time: Sun Jul 27 10:06:30 EDT 2025
Powered by FUDForum. Page generated in 0.04660 seconds
