Home » Eclipse Projects » Standard Widget Toolkit (SWT) » Toolbar and SWT.FLAT
Toolbar and SWT.FLAT [message #463219] Mon, 31 October 2005 13:17 Go to next message
Originally posted by: davidyoung_2001.yahoo.co.uk
If I create a toolbar with SWT.FLAT and then add a ToolItem with
SWT.DROPDOWN type, the right hand arrow part of the DROPDOWN button is not
displayed as SWT.FLAT....is this a bug in SWT or is there something I am
missing?
Re: Toolbar and SWT.FLAT [message #463294 is a reply to message #463219] Wed, 02 November 2005 13:57 Go to previous messageGo to next message
Any takers on this?
Re: Toolbar and SWT.FLAT [message #463304 is a reply to message #463294] Thu, 03 November 2005 03:38 Go to previous messageGo to next message
Originally posted by: friederich.kupzog.de
well, it works fine for me on win32. No idea how to help. You could send
me a snippet and I try it out. If you are also on win32 there is a
chance that we can find out what you do wrong.
Friederich
david young wrote:
> Any takers on this?
Friederich Kupzog
Elektronik & Software
Neusser Str. 5-7
50670 Köln
Tel 0241 160696-1
Fax 0221 726670
www.kupzog.de/fkmk
Re: Toolbar and SWT.FLAT [message #463321 is a reply to message #463304] Thu, 03 November 2005 08:44 Go to previous messageGo to next message
OK know I'm very confused on Windows XP Professional - it works, on
Windows XP Home Edition, it doesn't
package myMail;
import org.eclipse.swt.graphics.Point;
import org.eclipse.swt.widgets.Shell;
import org.eclipse.swt.widgets.ToolBar;
import org.eclipse.swt.SWT;
import org.eclipse.swt.widgets.ToolItem;
public class Test {
private Shell sShell = null;
private ToolBar toolBar = null;
* This method initializes toolBar
private void createToolBar() {
toolBar = new ToolBar(sShell, SWT.FLAT);
toolBar.setBounds(new org.eclipse.swt.graphics.Rectangle(1,3,291,37));
ToolItem toolItem = new ToolItem(toolBar, SWT.DROP_DOWN);
toolItem.setText("Test");
* @param args
// TODO Auto-generated method stub
/* Before this is run, be sure to set up the launch configuration
(Arguments->VM Arguments)
* for the correct SWT library path in order to run with the SWT dlls.
* The dlls are located in the SWT plugin jar.
* For example, on Windows the Eclipse SWT 3.1 plugin jar is:
* installation_directory\plugins\org.eclipse.swt.win32_3.1.0.j ar
Display display = Display.getDefault();
Test thisClass = new Test();
thisClass.createSShell();
thisClass.sShell.open();
while (!thisClass.sShell.isDisposed()) {
if (!display.readAndDispatch())
display.sleep();
display.dispose();
* This method initializes sShell
private void createSShell() {
sShell = new Shell();
sShell.setText("Shell");
createToolBar();
sShell.setSize(new Point(300, 200));
Re: Toolbar and SWT.FLAT [message #463323 is a reply to message #463321] Thu, 03 November 2005 10:20 Go to previous messageGo to next message
Hi David,
just tested it on WinXP Home Edition: ToolItem including drop-down arrow
are perfectly flat.
No idea what your problem is. Sorry.
Friederich
> package myMail;
> import org.eclipse.swt.widgets.Display;
> public class Test {
> * @param args
> public static void main(String[] args) {
> configuration (Arguments->VM Arguments)
> dlls. * The dlls are located in the SWT plugin jar. *
> display.sleep();
> display.dispose();
> createToolBar();
Friederich Kupzog
Neusser Str. 5-7
50670 Köln
Tel 0241 160696-1
Fax 0221 726670
www.kupzog.de/fkmk
Re: Toolbar and SWT.FLAT [message #463353 is a reply to message #463323] Fri, 04 November 2005 02:27 Go to previous message
I've re-installed everything on the Windows XP machine and it works now
thanks for the help
Previous Topic:performOK() return cancel, disables ok button?
Next Topic:how to get current cursor location relative to current editor
Current Time: Wed Jul 23 13:27:18 EDT 2025
Powered by FUDForum. Page generated in 0.25568 seconds
