Home » Eclipse Projects » Rich Client Platform (RCP) » using IPersistableElement
using IPersistableElement [message #462990] Fri, 02 February 2007 16:45 Go to next message
Originally posted by: tcmsimoes.criticalsoftware.com
I am having some problems using the IPersistableElement interface.
I am using it for one of my classes which i would to save its state after
the workbench shutdowns. I just implemented the interface in that class and
created an IElementFactory for it (and the correspondent extension point).
However the saveState, getFactoryID, createElement methods are never called.
What ami i missing? does the IPersistableElement interface only work for
editors or special page inputs that the workbench knows or do i need to
register my object somewhere for the workbench know that it is persistable?
Tiago
Re: using IPersistableElement [message #462996 is a reply to message #462990] Fri, 02 February 2007 17:59 Go to previous messageGo to next message
You have to call saveState after the workbench stops running (you can
register the workbench listener, for instance) and restoreState when
restoring your object.
Snjeza
> Thanks
> Tiago
Re: using IPersistableElement [message #463014 is a reply to message #462996] Sat, 03 February 2007 18:02 Go to previous messageGo to next message
Thanks Snjeza.
I see your point, however how can i get the memento from the workbench to
use for the IPersistableElement interface methods?
"Snjezana Peco" <snjeza.peco@gmail.com> wrote in message
news:eq0fp3$g0u$1@utils.eclipse.org...
> Snjeza
> Tiago Sim
Re: using IPersistableElement [message #463016 is a reply to message #463014] Sat, 03 February 2007 18:29 Go to previous message
There is the ready API for views and editors (the saveState and init
methods).
If you want to use the Memento pattern for your classes, you have to
implement the IMemento interface.
See org.eclipse.ui.XMLMemento for details.
Snjeza
Tiago Simões wrote:
> Thanks Snjeza.
>> Snjeza
>>> and created an IElementFactory for it (and the correspondent extension
>>> point). However the saveState, getFactoryID, createElement methods are
>>> never called.
>>> persistable?
>>> Thanks
>>> Tiago
Previous Topic:org.eclipse.ui.forms does not get exported
Next Topic:Changing the perspective bar look and location
Current Time: Sun Aug 31 06:58:42 EDT 2025
Powered by FUDForum. Page generated in 0.05830 seconds
