Home » Eclipse Projects » Standard Widget Toolkit (SWT) » FieldEditor does not write default-value
FieldEditor does not write default-value [message #462974] Mon, 24 October 2005 08:49 Go to next message
in a prefgerences-page i have two FieldEditors. to ease the use i display
default-values, so the suer has not to type in any values if he's happy
with default ones.
but the default values are not stored to the prefs -- thus any attempt to
use those values causes an error.
if i fill in arbitrary values, different from the default, it's stored --
but thus the ability to present default values seems meaningless to me.
what do i wrong, how do i force the FieldEditors to save even the
unchanged default?
public class LocalDBPreferencePage extends FieldEditorPreferencePage
implements IWorkbenchPreferencePage {
IPreferenceStore ips;
public LocalDBPreferencePage() {
super(GRID);
setPreferenceStore(ips=MyPlugin.getDefault().getPreferenceSt ore());
setDescription("Preference page for the local Derby-DB");
ips.setDefault("derbydbpath",
Platform.getLocation().toOSString());
ips.setDefault("derbydbname", "NJVDB");
public void createFieldEditors() {
Composite fep=getFieldEditorParent();
DirectoryFieldEditor dfe=new
DirectoryFieldEditor(PreferenceConstants.P_PATH, "&Speicherort der DB:",
fep);
dfe.setPreferenceName("derbydbpath");
addField(dfe);
StringFieldEditor sfeDBN=new
StringFieldEditor(PreferenceConstants.P_STRING, "Datenbankname:", fep);
sfeDBN.setPreferenceName("derbydbname");
addField(sfeDBN);
public void init(IWorkbench workbench) {}
Re: FieldEditor does not write default-value [message #462978 is a reply to message #462974] Mon, 24 October 2005 10:05 Go to previous messageGo to next message
solved the issue by calling ips.setDefault() in the plugin's
start()-method.
i still think the default-value should be saved to the props, but that's
probably rather a matter of taste ...
Re: FieldEditor does not write default-value [message #462979 is a reply to message #462974] Mon, 24 October 2005 12:07 Go to previous messageGo to next message
arne,
set default values in preference initializer
see extension point org.eclipse.core.runtime.preferences
and class
org.eclipse.core.runtime.preferences.AbstractPreferencesInit ializer
Peco
> with default ones.
> unchanged default?
> super(GRID);
> fep);
> addField(dfe);
> addField(sfeDBN);
Re: FieldEditor does not write default-value [message #462981 is a reply to message #462978] Mon, 24 October 2005 12:09 Go to previous message
> start()-method.
preferences initializer is better solution because it call without plugin
start
Previous Topic:How to find a TreeItem when using a TreeViewer
Next Topic:Problems with Table
Current Time: Wed Jul 23 11:52:02 EDT 2025
Powered by FUDForum. Page generated in 0.04943 seconds
