Home » Eclipse Projects » Standard Widget Toolkit (SWT) » EXCEPTION_ACCESS_VIOLATION
EXCEPTION_ACCESS_VIOLATION [message #462844] Thu, 20 October 2005 07:45 Go to next message
Originally posted by: frederic.lebeau.websurf.be
My application uses SWT and sometimes, it shuts down when the user click
on toolbar, menu, ... in this case some oleautomation are called...
Is it a well known problem?
An unexpected exception has been detected in native code outside the VM.
Unexpected Signal : EXCEPTION_ACCESS_VIOLATION (0xc0000005) occurred at
PC=0x77F7D814
Function=RtlDestroyHeap+0x518
Library=C:\NTWKS\System32\ntdll.dll
Current Java thread:
at org.eclipse.swt.internal.ole.win32.COM.VariantClear(Native Method)
at org.eclipse.swt.ole.win32.OleAutomation.invoke(OleAutomation .java:449)
at org.eclipse.swt.ole.win32.OleAutomation.invoke(OleAutomation .java:397)
Re: EXCEPTION_ACCESS_VIOLATION [message #462847 is a reply to message #462844] Thu, 20 October 2005 08:46 Go to previous messageGo to next message
No, I don't see any similar traces in bugzilla. Please log a bug report
with Platform - SWT and include the full stack trace and if possible a
stand-alone snippet that reproduces the problem for you.
http://eclipse.org/swt/faq.php#whatisasnippet
Grant
"Lebeau Frederic" <frederic.lebeau@websurf.be> wrote in message
news:880528ef04c1d52917c6b657831aea61$1@www.eclipse.org...
> Hello,
> PC=0x77F7D814
Re: EXCEPTION_ACCESS_VIOLATION [message #462895 is a reply to message #462847] Thu, 20 October 2005 10:45 Go to previous messageGo to next message
Ok , but the problem is that is not systematic...
so could you help me when this kingd of problem can occurs??
Re: EXCEPTION_ACCESS_VIOLATION [message #462901 is a reply to message #462844] Thu, 20 October 2005 13:13 Go to previous messageGo to next message
Not being an expert on the inner workings of SWT on win32, I'm not going to push my opinion as cannon. However, it looks like this is a threading issue. Is it possible that SWT isn't ensuring that the event is being passed to the win32 subsystem in the event dispatch thread?
Re: EXCEPTION_ACCESS_VIOLATION [message #462969 is a reply to message #462901] Mon, 24 October 2005 04:30 Go to previous message
After some researches, here is the problem...
1) my applications jar files is on the network(also the swt.jar)
2) i'm launching the application from my workstation 'java.exe -cp blabla'
3) the network shuts down
4) i continue the navigation into my application (click button, open tabs,
5) the network is available
6) hs_err_pid created in the application folder(on the network)
PC=0x77F64DBA
Function=RtlFreeHeap+0x2A
at java.util.zip.InflaterInputStream.read(InflaterInputStream.j ava:134)
at
org.eclipse.swt.internal.image.LEDataInputStream.readData(LE DataInputStream.java:136)
at
org.eclipse.swt.internal.image.LEDataInputStream.read(LEData InputStream.java:86)
at java.io.InputStream.read(InputStream.java:89)
at
org.eclipse.swt.internal.image.WinBMPFileFormat.isFileFormat (WinBMPFileFormat.java:325)
at org.eclipse.swt.internal.image.FileFormat.load(FileFormat.ja va:63)
at org.eclipse.swt.graphics.ImageLoader.load(ImageLoader.java:1 24)
at org.eclipse.swt.graphics.ImageData.<init>(ImageData.java:308)
Previous Topic:KTable: Right handling of TableModel
Next Topic:How to find a TreeItem when using a TreeViewer
Current Time: Wed Jul 23 03:12:57 EDT 2025
Powered by FUDForum. Page generated in 0.30637 seconds
