Home » Eclipse Projects » Standard Widget Toolkit (SWT) » Question regarding TreeViewer
Question regarding TreeViewer [message #462610] Fri, 14 October 2005 20:11 Go to next message
I am using a TreeViewer with additional columns.
Since such a tree with table columns right to the tree can be hard to
read once it get's larger and one adds more columns, I would like to
introduce a nice color banding for odd and even rows.
I have not found a solution to my problem yet. The only piece of code I
found was for a table, there it worked by setting the background of the
TableItems.
I tested to set the background of the root item and it worked partially
in the sense that the tree column was not completely background colored
with my color (only the label, not the space right to it up to the next
column). The subsequent columns to the right were correctly colored
though. Good.
The problems I have are firstly how to do it in a hierarchy of items and
secondly when to do it - perhaps in some listener?
In Swing I always used a renderer for such kind of stuff so I'm kind of
lost now.
Andre
Re: Question regarding TreeViewer [message #462628 is a reply to message #462610] Sat, 15 October 2005 04:16 Go to previous messageGo to next message
Andre R. Pareis wrote:
Is
treeviewer.getTree().setLinesVisible(true);
what you're looking for?
Re: Question regarding TreeViewer [message #462636 is a reply to message #462628] Sat, 15 October 2005 15:43 Go to previous messageGo to next message
Fabian Wolf schrieb:
> Is
Unfortunately not. setLinesVisible draws only the grid lines IIRC.
What I mean with color banding is to have alternating background colors
for odd end even line numbers.
With a table it's pretty simple by just calling
table.getItem(i).setBackgroundColor(i%2==1 ? oddBackground : evenBackground)
I looking for something similar that works with a tree.
thanks
andre
Re: Question regarding TreeViewer [message #462704 is a reply to message #462636] Mon, 17 October 2005 10:45 Go to previous messageGo to next message
Hi Andre,
The approach that you're taking is correct. You can make the background
colour span the full width, excluding the expand/collapse box, by creating
your Tree with style SWT.FULL_SELECTION.
Ideally, style FULL_SELECTION should not be needed to make this work, but
this seems to be the case on win32. I'm not sure if this is a bug or native
platform behaviour, so I've logged
https://bugs.eclipse.org/bugs/show_bug.cgi?id=112791 to investigate.
Grant
"Andre R. Pareis" <andre.pareis@entura.ch> wrote in message
news:dirm5i$r7v$1@news.eclipse.org...
> > Is
evenBackground)
> thanks
> andre
Re: Question regarding TreeViewer [message #462711 is a reply to message #462704] Mon, 17 October 2005 16:50 Go to previous messageGo to next message
> Grant
Great - or not so great, but I can live with that small bug for the time
being. I added FULL_SELECTION, now the row is colored completely.
I still have no idea how to do the banding with alternating colors on a
tree correctly. The problem is that I just can't go through the
hierarchy and apply alternating background colors to the TreeItems on my
way, because I have to consider the expansion state of each node so that
no two rows will result in the same background color.
I'm sure this is FAQ, but I have no idea where to hook for listening to
expansion events - if there are such ???
Can somebody point me into the right direction?
andre
Re: Question regarding TreeViewer [message #462731 is a reply to message #462711] Tue, 18 October 2005 09:57 Go to previous messageGo to next message
Tree.addTreeListener() will let you listen for expands and collapses.
news:dj12rd$n6e$1@news.eclipse.org...
creating
but
native
> > Grant
> andre
Re: Question regarding TreeViewer [message #462787 is a reply to message #462731] Wed, 19 October 2005 08:43 Go to previous messageGo to next message
Unfortunately the events are triggered when the tree item is about to
expand.
This made it necessary to invoke my banding method after the expansion
event, which I solved by calling Display.syncExec(...) from within a
temporary thread. This works fine now but looks weird. Here's the code:
treeViewerWithColumns.addTreeListener(new ITreeViewerListener() {
public void treeCollapsed(TreeExpansionEvent event) {
applyBanding();
public void treeExpanded(TreeExpansionEvent event) {
applyBanding();
private void applyBanding() {
new Thread(new Runnable() {
public void run() {
treeViewerWithColumns.getTree().getDisplay().syncExec(new Runnable() {
public void run() {
applyBandingOnTree(treeViewerWithColumns.getTree().getItem(0 ), 0);
}).start();
private int applyBandingOnTree(TreeItem ti, int n) {
ti.setBackground((n++&1)==1 ? oddBG : evenBG);
if(ti.getExpanded()) {
TreeItem[] subitems = ti.getItems();
for (TreeItem item : subitems) {
n = applyBandingOnTree(item, n);
return n;
thanks
andre
Re: Question regarding TreeViewer [message #462791 is a reply to message #462787] Wed, 19 October 2005 09:56 Go to previous messageGo to next message
A slightly less hacky approach to deferring the banding is to do it in an
asyncExec. This would make your applyBanding method look like:
final Tree tree = treeViewerWithColumns.getTree();
tree.getDisplay().asyncExec(new Runnable() {
public void run() {
if (!tree.isDisposed()) {
applyBandingOnTree(tree.getItem(0), 0);
Grant
news:dj5f1o$4qr$1@news.eclipse.org...
> expand.
> applyBanding();
> applyBanding();
> public void run() {
> public void run() {
> }).start();
> return n;
> thanks
> andre
Re: Question regarding TreeViewer [message #462805 is a reply to message #462791] Wed, 19 October 2005 16:00 Go to previous message
> public void run() {
thanks Grant, workes fine and makes expansion visually a bit smoother
andre
Previous Topic:No SelectionEvent when right-clicking Tree
Next Topic:SWT Browser crash
Current Time: Sat Jul 26 00:30:31 EDT 2025
Powered by FUDForum. Page generated in 0.05166 seconds
