SWT Browser, silent mode? [message #462781] |
Wed, 19 October 2005 06:22  |
I use the SWT browser widget to display any HTML page to the user.
1.
Is there any way within the SWT browser widget to detect/trigger when an
HTML page is loaded completely (including frames, flash animations, etc.)?
2.
Is it possible to avoid popups by some settings of SWT Browser widget?
3.
If I receive a forign HTML page (mainly Cineese) a message pops up from the
browser offering to install a language pack.
Is it possible by the SWT browser widget to avoid this message popping up?
So basically I want to avoid that the SWT browser window opens any other
window, even HTML windows or system messages.
Under C++ Browser component I can activate a so called 'silent mode'
property, but how to do using JAVA / SWT?
Any idea?
Thanks for any hint!
Re: SWT Browser, silent mode? [message #462783 is a reply to message #462781] |
Wed, 19 October 2005 06:38   |
Mr. Burns wrote:
> Hello,
> 1.
Check out the ProgressListener, but I cant tell if it guarantess the call of
completed in any case, like frames and flash.
> 2.
Popups will trigger show-method in the VisibilityWindowListener. Inside the
WindowEvent you can check if the window is having adressbar, menubar and
stuff like that, which common popups dont have. Checking that, you can react
on a popupwindow and close it directly. But this is not a solution that will
work for any popup. Be carefull, that links wanting to open inside a new
window will trigger the same event.
> 3.
> Any idea?
I guess this is not possible for any dialogs.
Re: SWT Browser, silent mode? [message #462798 is a reply to message #462783] |
Wed, 19 October 2005 11:05  |
The Completed event should only fire once the top-level frame has completed,
which includes all contained frames, etc.
Grant
> > 1.
etc.)?
of
FUDForum. Page generated in 0.07985 seconds
