Home » Eclipse Projects » Standard Widget Toolkit (SWT) » Image transparency problem - easy, I think
Image transparency problem - easy, I think [message #462744] Tue, 18 October 2005 14:10 Go to next message
I am using a suggestion that someone had on this board for copying an image
(.gif) to a new file.
Here's the code:
private void moveImage(Image image, String fileName)
//New image loader
ImageLoader imageSaver = new ImageLoader();
//image has been loaded from a .gif fi.e
ImageData idata = image.getImageData();
//Set the old image data into the loader and
imageSaver.data = new ImageData[]{idata};
//save as the new image.
imageSaver.save(path+File.separator+fileName+".gif",
SWT.IMAGE_JPEG);
The problem is that the background of the new image is black rather than
transparent.
I saw the information about the transparency bit but apparently, I'm not
smart enough to understand it. :-)
Any help would be appreciated.
Mark
Re: Image transparency problem - easy, I think - Still need help [message #462746 is a reply to message #462744] Tue, 18 October 2005 14:33 Go to previous messageGo to next message
I realized that I typed SWT.IMAGE_JPEG rather than SWT.IMAGE_GIF.
Thought I'd be all set.
However, now I get an error that the "depth is unsupported" on the
imageSaver.save( ) call. When I debug, the depth is 32. The image is a 256
color gif.
Now any ideas?
Mark
"Mark Victory" <mvictory@us.ibm.com> wrote in message
news:dj3dqh$m4b$1@news.eclipse.org...
> Here's the code:
> //New image loader
> SWT.IMAGE_JPEG);
> transparent.
> Mark
Re: Image transparency problem - easy, I think - Still need help [message #462750 is a reply to message #462746] Tue, 18 October 2005 17:10 Go to previous message
I got it working.
It appears that there is a difference in the ImageData extracted from a
loaded image as opposed
to creating the ImageData from an input stream even if the source .GIF file
is the same.
Mark
news:dj3f5n$o0u$1@news.eclipse.org...
> 256 color gif.
> Now any ideas?
> Mark
>>image (.gif) to a new file.
>> Here's the code:
>> //New image loader
>> SWT.IMAGE_JPEG);
>> transparent.
>> Thanks,
>> Mark
Previous Topic:Warning on SWT_AWT and OSX and a suggestion
Next Topic:Browser Resolution
Current Time: Sun Jul 27 09:28:46 EDT 2025
Powered by FUDForum. Page generated in 0.03203 seconds
