Home » Eclipse Projects » Rich Client Platform (RCP) » TreeViewer refresh
TreeViewer refresh [message #462625] Wed, 31 January 2007 02:05 Go to next message
Originally posted by: chaitrali.butala.cognizant.com
Problem Context:
I am developing a RCP based real time application. Objective of the application is to capture real time events (~200/sec) from information bus and display them in a tree format.
Tree hierarchy is required because events received, have parent child relationship I.e. an event received can be a parent event by it self or can be child of any already present event.
Right now I am using TreeViewer,Tree and TreeColumn to achieve above requirement.
Problem Statement:
As mentioned above, newly added event need to appear in Tree view as soon it arrives. I wanted to update only a specific node for which child event has been added, instead of refreshing whole tree which will lead to flicker. Is it possible and how?
Re: TreeViewer refresh [message #462645 is a reply to message #462625] Wed, 31 January 2007 05:41 Go to previous messageGo to next message
Why don't you use the add(*) methods instead of refreshing the whole tree?
Tom
chaitrali schrieb:
> Problem Context:
> Problem Statement:
Re: TreeViewer refresh [message #462672 is a reply to message #462625] Wed, 31 January 2007 07:52 Go to previous messageGo to next message
Originally posted by: lamont_gilbert.rigidsoftware.com
On Wed, 31 Jan 2007 02:05:41 -0500, chaitrali wrote:
> Problem Context:
> requirement.
> Problem Statement:
Are you changing the structure of the tree, or changing the name of nodes,
or both?
Re: TreeViewer refresh [message #462815 is a reply to message #462672] Thu, 01 February 2007 04:22 Go to previous messageGo to next message
I am changing the structure of the tree.
Seems,have got the solution. We can refresh a particular node instaed of complete tree. Thanks for the help.
Re: TreeViewer refresh [message #462818 is a reply to message #462645] Thu, 01 February 2007 04:26 Go to previous messageGo to next message
I am already using add method but was unaware of the method refresh that can refresh only a particular node.
Now I am using it and it is working. Thanks for the help.
Re: TreeViewer refresh [message #463163 is a reply to message #462818] Wed, 07 February 2007 03:50 Go to previous messageGo to next message
I am building up an Eclipse-RCP based application.
I have already tried organizing my code in MVC pattern, but wondering weather I can get better by usage of Spring IOC?
Re: TreeViewer refresh [message #463164 is a reply to message #463163] Wed, 07 February 2007 04:05 Go to previous message
why don't use the newly developed databinding framework? I'm currently
developing an XML-Dialect to completely do gui-design/databinding in XML
but it is at the very early stages, I think this is the future for
datadriven applications written in SWT whether you use the databinding
component directly or through some layer.
Tom
Previous Topic:Retarget Action does not work
Next Topic:Data should be entered in INSERT mode
Current Time: Tue Sep 16 23:34:16 EDT 2025
Powered by FUDForum. Page generated in 0.29156 seconds
