Home » Eclipse Projects » Standard Widget Toolkit (SWT) » Setting selection in JFace ComboViewer
Setting selection in JFace ComboViewer [message #462552] Thu, 13 October 2005 10:40 Go to next message
Originally posted by: webapp.gmx.de
how can I set the selection in a combobox using the JFace ComboViewer?
There's a method setSelection, but I don't know how to handle it.
Sorry, if this was asked before, but there's no search function available.
Thanks, Rudolf
Re: Setting selection in JFace ComboViewer [message #462602 is a reply to message #462552] Fri, 14 October 2005 11:24 Go to previous messageGo to next message
Originally posted by: micasim.gmx.de
Hi Rudolf,
I assume you set a ComboViewer on a SWT Combo and supported it with a
ContentProvider and a LabelProvider.
Then the object(s) in the selection are to be same that would be returned
by the ContentProvider.
The simple way I normally do it:
StructuredSelection selection = new StructuredSelection (list); // where
"list" is a java.util.List or an array of objects. If you just want to
select one object you create the StructuredSelection with just that one
comboViewer.setSelection (selection);
hope this helps,
Michael
On Thu, 13 Oct 2005 16:40:21 +0200, Rudolf Schmidt <webapp@gmx.de> wrote:
> available.
> Thanks, Rudolf
Re: Setting selection in JFace ComboViewer [message #462605 is a reply to message #462602] Fri, 14 October 2005 15:47 Go to previous messageGo to next message
Does the StructuredSelection object need to implement the
public boolean equals(Object obj)
method?
Michael Simons wrote:
> Hi Rudolf,
> returned by the ContentProvider.
> where "list" is a java.util.List or an array of objects. If you just
> want to select one object you create the StructuredSelection with just
> that one
> hope this helps,
> Michael
>> Hi,
>> ComboViewer? There's a method setSelection, but I don't know how to
>> handle it.
>> available.
>> Thanks, Rudolf
Re: Setting selection in JFace ComboViewer [message #462608 is a reply to message #462605] Fri, 14 October 2005 18:58 Go to previous message
Hi Rudolf,
No, not AFAIK and the objects we use don't at least not all do.
Regards, Michael
On Fri, 14 Oct 2005 21:47:00 +0200, James Leotta <jleotta@bascom.com>
> method?
>> Hi Rudolf,
>> that one
>> hope this helps,
>> Michael
>> wrote:
>>> Hi,
>>> handle it.
>>> available.
>>> Thanks, Rudolf
Previous Topic:How do you listen to editor and view focus events?
Next Topic:OLE: how to set a (OLECHAR **ppchURLOut) parameter?
Current Time: Sun Jul 27 01:58:08 EDT 2025
Powered by FUDForum. Page generated in 0.06560 seconds
