Home » Eclipse Projects » Standard Widget Toolkit (SWT) » SWT table
SWT table [message #462485] Wed, 12 October 2005 18:32 Go to next message
Originally posted by: ahsanfz.hotmail.com
Hye,
I have been banging my head with SWT table. I want it to appear in a preference page. Following is the code which I modified to run as swt application.
The problem is I can't get the table to appear whatever i do. Neither as a standlone application nor on preference page. Can someone point out what I am doing wrong.
Ahsan
import java.util.HashMap;
import java.util.Iterator;
import java.util.Set;
import java.util.Vector;
import org.eclipse.jface.preference.FieldEditor;
import org.eclipse.jface.preference.FieldEditorPreferencePage;
import org.eclipse.jface.preference.FileFieldEditor;
import org.eclipse.jface.preference.IPreferenceStore;
import org.eclipse.jface.viewers.ColumnWeightData;
import org.eclipse.jface.viewers.ILabelProviderListener;
import org.eclipse.jface.viewers.IStructuredContentProvider;
import org.eclipse.jface.viewers.ITableLabelProvider;
import org.eclipse.jface.viewers.TableLayout;
import org.eclipse.jface.viewers.TableViewer;
import org.eclipse.jface.viewers.Viewer;
import org.eclipse.swt.SWT;
import org.eclipse.swt.graphics.Image;
import org.eclipse.swt.layout.GridData;
import org.eclipse.swt.layout.GridLayout;
import org.eclipse.swt.widgets.Composite;
import org.eclipse.swt.widgets.Layout;
import org.eclipse.swt.widgets.Shell;
import org.eclipse.swt.widgets.Table;
import org.eclipse.swt.widgets.TableColumn;
import org.eclipse.swt.widgets.TableItem;
import org.eclipse.ui.IWorkbench;
import org.eclipse.ui.IWorkbenchPreferencePage;
import ed.inf.proofgeneral.ProofGeneralPlugin;
import ed.inf.proofgeneral.pgipdatastructure.BrokerStatus;
import ed.inf.proofgeneral.sessionmanager.SessionManager;
* @author Elemental
public class ProversPrefsPage //extends FieldEditorPreferencePage implements IWorkbenchPreferencePage
private TableViewer viewer;
public ProversPrefsPage()
protected void createFieldEditors()
createWidgets(getFieldEditorParent());
public void init(IWorkbench workbench)
// TODO Auto-generated method stub
public Composite ourComposite;
private void createWidgets(Composite parent)
ourComposite = new Composite(parent,SWT.NONE);
GridLayout layout = new GridLayout(2,false);
ourComposite.setLayout(layout);
ourComposite.setFont(parent.getFont());
layout.marginHeight = layout.marginWidth = 0;
GridData data = new GridData(SWT.FILL,SWT.FILL, true, true );
data.widthHint = 200;
ourComposite.setLayoutData(data);
Table proverTable = new Table(ourComposite, SWT.CENTER | SWT.BORDER | SWT.FULL_SELECTION);
proverTable.setLayoutData(data);
proverTable.setFont(parent.getFont());
viewer = buildAndLayoutTable(proverTable);
attachContentProvider(viewer);
attachLabelProvider(viewer);
BrokerStatus b = new BrokerStatus();
b.addRunningProver("123","1123");
// viewer.setInput(SessionManager.getDefault().getBrokerStatus( ));
viewer.setInput(b);
//Sample code if one wants to add a pop menu for prover actions here.
// MenuManager popupMenu = new MenuManager();
// IAction newRowAction = new NewRowAction();
// popupMenu.add(newRowAction);
// Menu menu = popupMenu.createContextMenu(table);
// table.setMenu(menu);
// viewer.setInput(CONTENT);
private void attachLabelProvider(TableViewer viewer)
viewer.setLabelProvider(new ITableLabelProvider()
public String getColumnText(Object element, int index)
switch (index)
case 0:
return ((ProverTableItem) element).provername;
case 1:
return ((ProverTableItem) element).proverid;
case 2:
return ((ProverTableItem) element).status;
default:
return "";
public Image getColumnImage(Object element, int columnIndex)
return null;
public void addListener(ILabelProviderListener listener)
public void dispose()
public boolean isLabelProperty(Object element, String property)
return false;
public void removeListener(ILabelProviderListener listener)
private void attachContentProvider(TableViewer viewer)
viewer.setContentProvider(new IStructuredContentProvider()
public Object[] getElements(Object input)
Vector result = new Vector();
if (input instanceof BrokerStatus)
BrokerStatus brokerStatus = (BrokerStatus) input;
HashMap hm = brokerStatus.getRunningprovers();
Set keyset = hm.keySet();
ProverTableItem tableItem;
for (Iterator i = keyset.iterator(); i.hasNext();)
Object proverid = i.next();
tableItem = new ProverTableItem((String)hm.get(proverid)
,(String)proverid
,"Running");
result.add(tableItem);
hm = brokerStatus.getKnownprovers();
,"Not running yet"
,"Not running yet");
return result.toArray();
public void inputChanged(Viewer viewer, Object oldInput,
Object newInput)
private TableViewer buildAndLayoutTable(Table table)
TableViewer tableViewer = new TableViewer(table);
TableLayout layout = new TableLayout();
layout.addColumnData(new ColumnWeightData(35, 75, true));
layout.addColumnData(new ColumnWeightData(40, 75, true));
layout.addColumnData(new ColumnWeightData(25, 75, true));
table.setLayout(layout);
TableColumn nameColumn = new TableColumn(table, SWT.CENTER);
nameColumn.setText("Prover Name");
TableColumn idColumn = new TableColumn(table, SWT.CENTER);
idColumn.setText("Prover ID");
TableColumn statusColumn = new TableColumn(table, SWT.CENTER);
statusColumn.setText("Status");
table.setHeaderVisible(true);
table.setLinesVisible(true);
return tableViewer;
class ProverTableItem
public String provername;
public String proverid;
public String status;
public ProverTableItem( String n, String i, String s)
provername = n;
proverid = i;
status = s;
public static void main(String[] args)
Display display = new Display();
Shell shell = new Shell(display);
ProversPrefsPage r = new ProversPrefsPage();
r.createWidgets(shell);
shell.update();
shell.pack();
shell.open();
while (!shell.isDisposed())
if (!display.readAndDispatch())
display.sleep();
display.dispose();
Re: SWT table [message #462508 is a reply to message #462485] Thu, 13 October 2005 05:37 Go to previous messageGo to next message
You forgot to set a layout on your shell.
shell.setLayout(new GridLayout());
Boby
"Elemental" <ahsanfz@hotmail.com> wrote in message
news:3680915.1129156407585.JavaMail.root@cp1.javalobby.org...
> Hye,
application.
am doing wrong.
> Ahsan
> import org.eclipse.swt.widgets.Display;
> * @author Elemental
> viewer.setInput(b);
> switch (index)
> case 0:
> case 1:
> case 2:
> default:
> return "";
> return null;
> return false;
> ,(String)proverid
> ,"Running");
> ,"Not running yet"
> Object newInput)
> return tableViewer;
> provername = n;
> proverid = i;
> status = s;
> shell.update();
> shell.pack();
> shell.open();
> display.sleep();
> display.dispose();
Re: SWT table [message #462510 is a reply to message #462508] Thu, 13 October 2005 06:18 Go to previous messageGo to next message
Thanks for the first reply, but no thats not the problem. I think something is wrong with my version of swt or something.
Here is another class I wrote for testing and I have set the layout for the shell there. Even put a Group to see whether anything even gets added. And then created a simple table to chk things out. Code for my application table is also there which you can comment an unchk. But both of them dont appear. Plz do have a quick look again if you see anything wrong. I am still a newbie to SWT.
I can't believe why glitches like this are haunting me.
import org.eclipse.swt.layout.FillLayout;
import org.eclipse.swt.widgets.Group;
public class Testing
public Testing()
super();
// TODO Auto-generated constructor stub
layout.addColumnData(new ColumnWeightData(35, 40, true));
layout.addColumnData(new ColumnWeightData(40, 50, true));
layout.addColumnData(new ColumnWeightData(25, 30, true));
return tableViewer;
switch (index)
case 0:
case 1:
case 2:
default:
return "";
return null;
return false;
,(String)proverid
,"Running");
,"Not running yet"
Object newInput)
* @param args
FillLayout flayout = new FillLayout(SWT.VERTICAL|SWT.HORIZONTAL);
shell.setLayout(flayout);
Group group = new Group(shell,SWT.SHADOW_ETCHED_IN);
group.setText("Group Label");
Testing t = new Testing();
Composite ourComposite = new Composite(group,SWT.NONE);
GridLayout layout = new GridLayout(1,false);
ourComposite.setFont(shell.getFont());
layout.marginHeight = layout.marginWidth = 10;
// Set up the table layout
TableLayout tablelayout = new TableLayout();
tablelayout.addColumnData(new ColumnWeightData(33, 75, true));
Table table = new Table(ourComposite, SWT.SINGLE);
table.setLayout(tablelayout);
// Add columns to the table
TableColumn column1 = new TableColumn(table, SWT.CENTER);
column1.setWidth(30);
TableColumn column2 = new TableColumn(table, SWT.CENTER);
column2.setWidth(30);
TableColumn column3 = new TableColumn(table, SWT.CENTER);
column3.setWidth(30);
TableItem item = new TableItem(table, SWT.NONE);
item.setText( new String[] { "column 1",
"column 2",
"column 3" } );
item.setText( new String[] { "a", "b", "c" } );
table.setVisible(true);
/////////////////Code sample 2 Uncomment to chk///////////////////////////////////////
// Table proverTable = new Table(ourComposite, SWT.FULL_SELECTION);
// data = new GridData(SWT.FILL,SWT.FILL, true, true );
// proverTable.setLayoutData(data);
// proverTable.setFont(shell.getFont());
// TableViewer viewer = t.buildAndLayoutTable(proverTable);
// t.attachContentProvider(viewer);
// t.attachLabelProvider(viewer);
// BrokerStatus b = new BrokerStatus();
// b.addRunningProver("123","1123");
//// viewer.setInput(SessionManager.getDefault().getBrokerStatus( ));
// viewer.setInput(b);
shell.update();
shell.pack();
shell.open();
display.sleep();
display.dispose();
provername = n;
proverid = i;
status = s;
Re: SWT table [message #462514 is a reply to message #462510] Thu, 13 October 2005 07:27 Go to previous messageGo to next message
I think I figured out the problem but the behaviour is not as I expected.
If I just add the line setBounds or setSize than the table starts to appear. But I have set the data of the composite that holds the table to SWT.FILL and have done the same for the table so it should take up all the space and should appear by default.
Any thoughts by anyone.
Regards.
Re: SWT table [message #462557 is a reply to message #462514] Thu, 13 October 2005 12:20 Go to previous message
Now you forgot to set a layout for the Group widget.
If you create a widget always set on it a layout too, otherwise use
setBounds().
Boby
news:15377267.1129202865471.JavaMail.root@cp1.javalobby.org...
> Regards.
Previous Topic:It's a bug ? Why ? java.lang.StackOverflowError getShell()
Next Topic:How does one pronounce SWT?
Current Time: Sat Jul 19 03:55:53 EDT 2025
Powered by FUDForum. Page generated in 0.10911 seconds
