Home » Eclipse Projects » Standard Widget Toolkit (SWT) » Virtual table problems
Virtual table problems [message #462360] |
Tue, 11 October 2005 09:44  |
I'm using a Table control with SWT.VIRTUAL flag, all items have an image
(100x90 pixels), now the problem is if the user keeps the page down button
down after a while there is no image displayed for table items. There is no
error message with no more handles or out of memory.
Below is a snippet based on this problem, of course the image size is
smaller.
Boby
import org.eclipse.swt.SWT;
import org.eclipse.swt.graphics.Image;
import org.eclipse.swt.graphics.ImageData;
import org.eclipse.swt.graphics.PaletteData;
import org.eclipse.swt.graphics.RGB;
import org.eclipse.swt.layout.RowData;
import org.eclipse.swt.layout.RowLayout;
import org.eclipse.swt.widgets.Button;
import org.eclipse.swt.widgets.Event;
import org.eclipse.swt.widgets.Label;
import org.eclipse.swt.widgets.Listener;
import org.eclipse.swt.widgets.Shell;
import org.eclipse.swt.widgets.Table;
import org.eclipse.swt.widgets.TableItem;
public class TableTest {
static final int COUNT = 50000;
private static Table table;
Display display = new Display();
final Shell shell = new Shell(display);
shell.setLayout(new RowLayout(SWT.VERTICAL));
table = new Table(shell, SWT.VIRTUAL | SWT.BORDER);
table.addListener(SWT.SetData, new Listener() {
public void handleEvent(Event event) {
TableItem item = (TableItem) event.item;
final int index = table.indexOf (item);
Thread thread = new Thread() {
public void run() {
PaletteData paletteData = new PaletteData(new RGB[] {
new RGB(255, 0, 0), new RGB(0, 255, 0) });
ImageData imageData = new ImageData(50, 50, 1, paletteData);
for (int x = 11; x < 35; x++) {
for (int y = 11; y < 35; y++) {
imageData.setPixel(x, y, 1);
setImage(index, imageData);
thread.start();
table.setLayoutData(new RowData(200, 200));
Button button = new Button(shell, SWT.PUSH);
button.setText("Add Items");
final Label label = new Label(shell, SWT.NONE);
button.addListener(SWT.Selection, new Listener() {
long t1 = System.currentTimeMillis();
table.setItemCount(COUNT);
long t2 = System.currentTimeMillis();
label.setText("Items: " + COUNT + ", Time: " + (t2 - t1) + " (ms)");
shell.layout();
shell.pack();
shell.open();
while (!shell.isDisposed()) {
if (!display.readAndDispatch())
display.sleep();
display.dispose();
* @param index
* @param imageData
private static void setImage(final int index, final ImageData imageData) {
table.getDisplay().asyncExec(new Runnable(){
public void run() {
TableItem item = table.getItem(index);
item.setImage(new Image(table.getDisplay(), imageData));
item.setText("" + index);
Re: Virtual table problems [message #463375 is a reply to message #462360] |
Fri, 04 November 2005 14:09  |
This is happening because you are leaking the image and Windows runs out of
resources.
"Robert Bacs" <boby@zerosoft.ro> wrote in message
news:digfj8$cb6$1@news.eclipse.org...
no
> smaller.
> Best regards,
> Boby
> import org.eclipse.swt.widgets.Display;
> public static void main(String[] args) {
> public void run() {
> thread.start();
(ms)");
> shell.layout();
> shell.pack();
> shell.open();
> display.sleep();
> display.dispose();
> * @param index
> * @param imageData
> public void run() {
Current Time: Wed Jul 23 04:14:24 EDT 2025
Powered by FUDForum. Page generated in 0.10420 seconds
