Home » Eclipse Projects » Standard Widget Toolkit (SWT) » How do you find a TreeItem index by searching the Data fields ?
How do you find a TreeItem index by searching the Data fields ? [message #462258] Sun, 09 October 2005 20:06 Go to next message
Here is my problem... I have a Tree and I am populating it from a database.
When I add a TreeItem to the tree, I am setting its Data field with the
index of the database record ( .setData(Integer.toString(dbIndex)) ). Now,
if I read a record from the database, and I know the index I am looking for,
how can I easily find the TreeItem in the Tree ?
I thought I could somehow use the .indexOf() function... but it requires a
TreeItem as the parameter... but that is what I am looking for.... can I
somehow create a 'dummy' TreeItem, do a setData of it to the index I am
searching for, and call .indexOf(dummyTreeItem) ? or does the .indexOf
require ALL fields fo the search item to match ?
Hope I am making sense....
Of course, I could create my own search function and just traverse the Tree
looking at each TreeItem's Data field.... just wondered if there was an
easier way.
TJ
Re: How do you find a TreeItem index by searching the Data fields ? [message #462366 is a reply to message #462258] Tue, 11 October 2005 09:58 Go to previous message
There isn't a way provided for locating a TreeItem based on its data.
indexOf(TreeItem) does an identity match, so this won't help you.
Depending on your context there may be a better approach than running
through the full Tree each time though. For example, since your indexes
seem to be static, just keeping an array with index->TreeItem mappings could
provide a quicker solution.
Grant
"TJ Forshee" <timforshee@bgdigital.com> wrote in message
news:dicbat$6id$1@news.eclipse.org...
database.
Now,
for,
Tree
> easier way.
> TJ
Previous Topic:Waiting dialogs
Next Topic:fixed TableColumn
Current Time: Sun Jul 27 08:06:20 EDT 2025
Powered by FUDForum. Page generated in 0.03277 seconds
