Home » Eclipse Projects » Standard Widget Toolkit (SWT) » Help with no more handles error
Help with no more handles error [message #461812] Fri, 30 September 2005 11:30 Go to next message
I'm trying to install the HTML Editor plugin, and I seem to have
problems in making SWT work with Firefox.
So far I did the following:
export MOZILLA_FIVE_HOME=/usr/local/firefox/lib (Eclipse was complaining
about the variable not being set)
added /usr/local/firefox to ld.so.conf, followed by ldconfig -v (to find
libxpcom.so)
But I now have a problem I can't solve. I get the following stack trace:
org.eclipse.swt.SWTError: No more handles [NS_InitEmbedding
/usr/local/firefox/lib error -2147221164]
at org.eclipse.swt.SWT.error(SWT.java:3277)
at org.eclipse.swt.browser.Browser.<init>(Browser.java:164)
at
tk.eclipse.plugin.htmleditor.editors.MultiPageHTMLEditor.cre atePage1(MultiPageHTMLEditor.java:75)
at
tk.eclipse.plugin.htmleditor.editors.MultiPageHTMLEditor.cre atePages(MultiPageHTMLEditor.java:84)
at
org.eclipse.ui.part.MultiPageEditorPart.createPartControl(Mu ltiPageEditorPart.java:241)
at
tk.eclipse.plugin.htmleditor.editors.HTMLEditor.createPartCo ntrol(HTMLEditor.java:97)
at
org.eclipse.ui.internal.EditorReference.createPartHelper(Edi torReference.java:599)
at
org.eclipse.ui.internal.EditorReference.createPart(EditorRef erence.java:374)
at
org.eclipse.ui.internal.WorkbenchPartReference.getPart(Workb enchPartReference.java:552)
at
org.eclipse.ui.internal.EditorReference.getEditor(EditorRefe rence.java:213)
at
org.eclipse.ui.internal.WorkbenchPage.busyOpenEditorBatched( WorkbenchPage.java:2370)
at
org.eclipse.ui.internal.WorkbenchPage.busyOpenEditor(Workben chPage.java:2303)
at org.eclipse.ui.internal.WorkbenchPage.access$10(WorkbenchPag e.java:2295)
at org.eclipse.ui.internal.WorkbenchPage$9.run(WorkbenchPage.ja va:2281)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:69)
at
org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPa ge.java:2276)
at
org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPa ge.java:2257)
at org.eclipse.ui.ide.IDE.openEditor(IDE.java:372)
at org.eclipse.ui.ide.IDE.openEditor(IDE.java:335)
at
org.eclipse.jdt.internal.ui.javaeditor.EditorUtility.openInE ditor(EditorUtility.java:251)
at
org.eclipse.jdt.internal.ui.javaeditor.EditorUtility.openInE ditor(EditorUtility.java:131)
at
org.eclipse.jdt.internal.ui.actions.OpenActionUtil.open(Open ActionUtil.java:49)
at org.eclipse.jdt.ui.actions.OpenAction.run(OpenAction.java:16 9)
at org.eclipse.jdt.ui.actions.OpenAction.run(OpenAction.java:15 3)
at
org.eclipse.jdt.ui.actions.SelectionDispatchAction.dispatchR un(SelectionDispatchAction.java:222)
at
org.eclipse.jdt.ui.actions.SelectionDispatchAction.run(Selec tionDispatchAction.java:198)
at
org.eclipse.jdt.internal.ui.packageview.PackageExplorerActio nGroup.handleOpen(PackageExplorerActionGroup.java:296)
at
org.eclipse.jdt.internal.ui.packageview.PackageExplorerPart$ 4.open(PackageExplorerPart.java:869)
at
org.eclipse.jface.viewers.StructuredViewer$2.run(StructuredV iewer.java:741)
at
org.eclipse.core.internal.runtime.InternalPlatform.run(Inter nalPlatform.java:1044)
at org.eclipse.core.runtime.Platform.run(Platform.java:783)
at org.eclipse.ui.internal.JFaceUtil$1.run(JFaceUtil.java:44)
at org.eclipse.jface.util.SafeRunnable.run(SafeRunnable.java:14 8)
at
org.eclipse.jface.viewers.StructuredViewer.fireOpen(Structur edViewer.java:739)
at
org.eclipse.jface.viewers.StructuredViewer.handleOpen(Struct uredViewer.java:968)
at
org.eclipse.jface.viewers.StructuredViewer$6.handleOpen(Stru cturedViewer.java:1067)
at org.eclipse.jface.util.OpenStrategy.fireOpenEvent(OpenStrate gy.java:243)
at org.eclipse.jface.util.OpenStrategy.access$2(OpenStrategy.ja va:238)
at org.eclipse.jface.util.OpenStrategy$1.handleEvent(OpenStrate gy.java:277)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :66)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1050)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:2909)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2605)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1755)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1719)
at
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:368)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:143)
at org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:106)
at
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:226)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:377)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:164)
at
at
at java.lang.reflect.Method.invoke(Method.java:324)
at org.eclipse.core.launcher.Main.invokeFramework(Main.java:338 )
at org.eclipse.core.launcher.Main.basicRun(Main.java:282)
at org.eclipse.core.launcher.Main.run(Main.java:977)
at org.eclipse.core.launcher.Main.main(Main.java:952)
the problem looks related to the way STW deals with Mozilla/Firefox, but
I don't know exactly how. I have an old machine (Pentium 4 1.8 GHz), so
everything must be 32 bits
Can anybody help me?
Re: Help with no more handles error [message #461815 is a reply to message #461812] Fri, 30 September 2005 11:55 Go to previous messageGo to next message
> libxpcom.so)
It looks like your version of firefox has been compiled without
embedding support ... you need to get a version with embedding support,
either compiling it yourself or finding some RPMs.
in my install, I have a libgtkembedmoz.so ... I'm guessing thats the
embedded support.
Later,
PW
Re: Help with no more handles error [message #461816 is a reply to message #461812] Fri, 30 September 2005 12:14 Go to previous messageGo to next message
No more handles is usually a low-level SWT problem; it could be that you're loading too many images (and so the system runs out of resources) but if it's occuring the first time something is starting then it's more indicative of a worse problem.
Re: Help with no more handles error [message #461905 is a reply to message #461815] Tue, 04 October 2005 09:31 Go to previous messageGo to next message
Paul, thank you for the suggestion. It took me quite some time to find
out that, while Firefox doesn't have embedding support (apparently it
can be built, but I don't know how), Mozilla does. I now have Mozilla
1.7.8, I set MOZILLA_FIVE_HOME to /usr/local/mozilla and I removed the
line from ld.so.conf that refers to firefox. But I still have a problem:
org.eclipse.swt.SWTError: No more handles [Mozilla GTK2 required (GTK1.2
detected)]
at org.eclipse.swt.browser.Browser.<init>(Browser.java:142)
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
I don't know what the problem is. As far as I see I do have GTK2, and if
I don't I can start Mozilla from the command line anyway, so I don't
understand what is happening.
Do you have an extra suggestion?
Re: Help with no more handles error [message #461918 is a reply to message #461905] Tue, 04 October 2005 11:48 Go to previous messageGo to next message
> detected)]
> at
It could be that you have a version of mozilla that's compiled against
gtk 1.2 ... you can check in /usr/lib/mozilla by:
% ldd libgtkxtbin.so | grep libgtk
libgtk-x11-2.0.so.0 => /usr/lib/libgtk-x11-2.0.so.0 (0x00111000)
My version of firefox is compiled against GTK+ 2.0 ... if it says 1.2,
that's why.
Later,
PW
Re: Help with no more handles error [message #462056 is a reply to message #461905] Wed, 05 October 2005 09:03 Go to previous messageGo to next message
You have to use a mozilla that is built with GTK2 and Xft. You'll find many
of these at http://www.mozilla.org/releases/ , just look for "GTK2".
Grant
"Andrea Desole" <e_news@desole.demon.nl> wrote in message
news:dhu07k$57o$1@news.eclipse.org...
> detected)]
> at
> at
> at
t.java:241)
> at
..java:97)
> at
a:599)
> at
> at
e.java:552)
> at
> at
va:2370)
> at
> at
> at
> at
> at
ity.java:251)
> at
ity.java:131)
> at
49)
> at
> at
on.java:198)
> at
> at
> at
> at
:1044)
> at
9)
> at
968)
> at
a:1067)
> at
> at
> at
> at
java:226)
> at
> at
> at
> at
..java:25)
Re: Help with no more handles error [message #462068 is a reply to message #462056] Wed, 05 October 2005 12:05 Go to previous message
Hey, thanks a lot! To download Mozilla I went straight to
ftp.mozilla.org with an ftp client. I didn't think about looking for
extra versions on the site. I was even ready to recompile Mozilla with
GTK2, which didn't look straightforward. Pity that I was not successful
with Firefox.
I finally got it. Thanks to everyone for the help
Previous Topic:Wanted: Simple ant file for hello world
Next Topic:Tree CCombo KeyListener traverse problem swt 3.1.1
Current Time: Fri Jul 25 09:08:51 EDT 2025
Powered by FUDForum. Page generated in 0.29525 seconds
