Problems running standalone SWT program from JAR file [message #461773] |
Thu, 29 September 2005 18:19 |
Originally posted by: eclipse.ptoye.com
Another silly newbie question, this time about how to build a JAR file for
a standalone SWT prog.
I tried using the File|Export wizard, included org.eclipse.swt as a
resource and told it to generate a manifest. It generated OK (with a
complaint that .classpath and .project were duplicated) but when I run it
from a command line I get
>java -jar PartSWT.jar
Exception in thread "main" java.lang.NoClassDefFoundError:
org/eclipse/swt/events/SelectionListener
at java.lang.ClassLoader.defineClass1(Native Method)
I suspect that the problem is in the manifest, but AFAICS the help files
don't tell you what to put in there (just the syntax) and the books I've
got are too elementary to be of use.
There are really two questions:
1) What should I change manually to get it to work?
2) Is it an Eclipse bug that the automatic generation doesn't work?
The manifest and jardesc files follow.
Peter
The MANIFEST.MF file in the JAR file says:
Manifest-Version: 1.0
Class-Path: swt.jar
Main-Class: com.ptoye.partSWT.GeneratePartitions
The JAR description file says:
<jardesc>
<jar path="D:/Peter/Java/PartitionSWT/PartSWT.jar"/>
<options buildIfNeeded="true" compress="true"
descriptionLocation="/PartitionSWT/PartSWT.jardesc" exportErrors="true"
exportWarnings="true" includeDirectoryEntries="false" overwrite="false"
saveDescription="true" useSourceFolders="false"/>
<manifest generateManifest="false"
mainClassHandleIdentifier="=PartitionSWT/<com.ptoye.partSWT
{GeneratePartitions.java[GeneratePartitions"
manifestLocation="/PartitionSWT/PartSWT.mf" manifestVersion="1.0"
reuseManifest="true" saveManifest="true" usesManifest="true">
<sealing sealJar="false">
<packagesToSeal/>
<packagesToUnSeal/>
</sealing>
</manifest>
<selectedElements exportClassFiles="true" exportJavaFiles="false"
exportOutputFolder="false">
<javaElement handleIdentifier="=org.eclipse.swt"/>
<javaElement handleIdentifier="=PartitionSWT/<com.ptoye.partSWT"/ >
</selectedElements>
</jardesc>
FUDForum. Page generated in 0.03583 seconds
