Home » Eclipse Projects » Standard Widget Toolkit (SWT) » Looking for a generic Transfer implementation for simple D&D
Looking for a generic Transfer implementation for simple D&D [message #461742] Thu, 29 September 2005 04:26 Go to next message
I need to implement drag&drop support. The drag source is a tree viewer
which contains self-defined model objects. The drop target will be some
widget that knows the model class.
I read some docs on SWT/JFace D&D and it seems I have to implement a
subclass of Transfer in order to use the D&D facilities. Now I wonder if
there's no simpler way of doing this: both sender and receiver know the
data type they exchange, but still I have to write a transportation
format that converts my model objects from/to byte[] (assuming I
subclass ByteArrayTransfer)...
Is there no 'generic' Transfer class that can transfer any Java object?
Or (that would be even better) did I miss something and there's a much
simpler solution for this?
Any comments are welcome.
TIA,
Martin
Re: Looking for a generic Transfer implementation for simple D&D [message #461753 is a reply to message #461742] Thu, 29 September 2005 07:02 Go to previous messageGo to next message
Martin,
have a look at EMFs D&D for a good starting point.
Daniel
Re: Looking for a generic Transfer implementation for simple D&D [message #461759 is a reply to message #461753] Thu, 29 September 2005 11:12 Go to previous messageGo to next message
Daniel Hirscher wrote:
> Martin,
Thanks for that hint. Looks very interesting, but I think that adding
EMF to my project wouldn't be reasonable... I already have a working
data model, and it's very simple (a Composite pattern structure with
three classes) so that using a modeling framework seems a bit
over-engineered.
I just want to be able to pass objects from one SWT thingie to another
via D&D. My current implementation uses TextTransfer to pass a unique
string identifying the object; on the drop site, this id is used to get
the original object from a commonly known storage. That works, but I
feel somewhat dirty when looking at the code...
Martin
Re: Looking for a generic Transfer implementation for simple D&D [message #461761 is a reply to message #461759] Thu, 29 September 2005 12:20 Go to previous messageGo to next message
Write your own data transfer that just puts a string in the byte array (same
string you were using for TextTransfer) and locally copies over the object.
The reason TextTransfer is not a good choice is because there are lots of
places where Text data is a valid type and people will drop your string into
strange places.
Here is an example class that you can start with:
public class MyTransfer extends ByteArrayTransfer {
private MyType data;
private static final String MYTYPENAME =
"name_for_my_type_which_is_unique_to_me";
private static final int MYTYPEID = registerType (MYTYPENAME);
private static MyTransfer _instance = new MyTransfer ();
public static MyTransfer getInstance () {
return _instance;
public void javaToNative (Object object, TransferData transferData) {
if (!checkMyType(object) || !isSupportedType (transferData)) {
DND.error(DND.ERROR_INVALID_DATA);
data = (MyType)object;
byte[] buffer = object.toString().getBytes();
super.javaToNative (buffer, transferData);
public Object nativeToJava (TransferData transferData) {
if (isSupportedType (transferData)) {
byte [] buffer = (byte []) super.nativeToJava
(transferData);
String string = new String(buffer);
if (string.equals(data.toString())) return data;
return null;
protected String [] getTypeNames () {
return new String [] {MYTYPENAME};
protected int [] getTypeIds () {
return new int [] {MYTYPEID};
boolean checkMyType(Object object) {
return (object != null && object instanceof MyType);
protected boolean validate(Object object) {
return checkMyType(object);
"Martin" <address.starts.after.hyphen-martin.umgeher@joanneum.at> wrote in
message news:dhh0bj$18t$1@news.eclipse.org...
>> Martin,
> Thanks for that hint. Looks very interesting, but I think that adding EMF
> to my project wouldn't be reasonable... I already have a working data
> model, and it's very simple (a Composite pattern structure with three
> classes) so that using a modeling framework seems a bit over-engineered.
> I just want to be able to pass objects from one SWT thingie to another via
> D&D. My current implementation uses TextTransfer to pass a unique string
> identifying the object; on the drop site, this id is used to get the
> original object from a commonly known storage. That works, but I feel
> Regards,
> Martin
Re: Looking for a generic Transfer implementation for simple D&D [message #461786 is a reply to message #461761] Fri, 30 September 2005 03:47 Go to previous messageGo to next message
> strange places.
> [ snip ]
Thanks, that really helped a lot!
Just as a matter of interest: why do I have to provide something that's
convertable to and from byte[] at all? I just don't get what
javaToNative and nativeToJava are good for if I can store the actual
object I want to transfer in the MyTransfer instance. I experimented a
bit with your code and it seems that those methods have to be called,
but I can ignore their results:
public void javaToNative(Object object, TransferData transferData) {
if (!validate(object) || !isSupportedType(transferData)) {
super.javaToNative("whatever".getBytes(), transferData);
public Object nativeToJava(TransferData transferData) {
super.nativeToJava(transferData);
return data;
I'd really like to understand SWT D&D a bit better, so any explanation
(e.g. why this works or why it's evil) is welcome.
thx
Martin
Re: Looking for a generic Transfer implementation for simple D&D [message #461808 is a reply to message #461786] Fri, 30 September 2005 10:01 Go to previous message
Drag and Drop uses the OS to transfer the data. The destination can be in a
completely different application from the source so you can not transfer a
Java object. Also, on many platforms drag and drop will fail if you don't
provide any data at all.
You do not have to create a byte array but if you do not use a byte array
you will have to write platform specific code to create a pointer to your
data in whatever form you choose. The byte array is a convenience format
provided by SWT.
message news:dhiqkt$cv6$1@news.eclipse.org...
>> (same string you were using for TextTransfer) and locally copies over the
>> object.
>> into strange places.
>> [ snip ]
> convertable to and from byte[] at all? I just don't get what javaToNative
> and nativeToJava are good for if I can store the actual object I want to
> transfer in the MyTransfer instance. I experimented a bit with your code
> and it seems that those methods have to be called, but I can ignore their
> results:
> @Override
> return data;
> thx
> Martin
Previous Topic:GUI update
Next Topic:FormLayout calculating location of formData.bottom
Current Time: Mon Jul 21 00:32:16 EDT 2025
Powered by FUDForum. Page generated in 0.30890 seconds
