Home » Eclipse Projects » Standard Widget Toolkit (SWT) » Shift-F2 and SWT - where is it?
Shift-F2 and SWT - where is it? [message #461744] Thu, 29 September 2005 04:44 Go to next message
Originally posted by: eclipse.ptoye.com
A newbie question, I'm afraid.
I want to use the shift-F2 mechanism for looking up the javadoc for SWT
elements - but I don't know how to tell Eclipse where the javadoc is.
Where do I get it from please? It doesn't seem to be part of the download
package.
Peter
Re: Shift-F2 and SWT - where is it? [message #461751 is a reply to message #461744] Thu, 29 September 2005 06:10 Go to previous messageGo to next message
Right-click on the swt.jar, then select Properties, in the Javadoc location
select the "Javadoc in archive" radio button and put the following in the
above edit boxes:
1'st edit box:
%ECLIPSE_HOME%\plugins\org.eclipse.platform.doc.isv_3.1.0\do c.zip
2'nd edit box: reference\api
Of course you need to replace %ECLIPSE_HOME% with your root directory of
installed Eclipse.
Hope this helps.
Boby
"Peter Toye" <eclipse@ptoye.com> wrote in message
news:memo.20050929094428.2760A@ptoye-ptoye.cix.co.uk...
> package.
> Peter
Re: Shift-F2 and SWT - where is it? [message #461771 is a reply to message #461751] Thu, 29 September 2005 18:19 Go to previous messageGo to next message
In article <dhgejb$42s$1@news.eclipse.org>, boby@zerosoft.ro (Robert Bacs)
wrote:
> *From:* "Robert Bacs" <boby@zerosoft.ro>
> *Date:* Thu, 29 Sep 2005 13:10:49 +0300
> location
> the
> above edit boxes:
> 1'st edit box:
> installed Eclipse.
> Hope this helps.
> Regards,
> Boby
> > SWT
> > download
> > package.
> > Peter
Boby,
Thanks a million. How on earth does one find this out (without asking
silly newbie questions in the newsgroup)?
Peter
Re: Shift-F2 and SWT - where is it? [message #461820 is a reply to message #461744] Fri, 30 September 2005 16:45 Go to previous messageGo to next message
> package.
The Javadoc is online here, and you can give this URL in Eclipse:
http://help.eclipse.org/help31/nftopic/org.eclipse.platform. doc.isv/reference/api/
In the standalone SWT download on www.eclipse.org/swt/ this is now set
up by default when you import the project (SWT .zip 3.2M2 and newer), so
Shift-F2 should "just work". Let me know if you have problems.
-Billy
Re: Shift-F2 and SWT - where is it? [message #461821 is a reply to message #461771] Fri, 30 September 2005 16:48 Go to previous messageGo to next message
See my other post for our fix in 3.2M2 and newer. The fact that it
wasn't set up by default was basically a bug (or a misfeature, we just
didn't have it set up right).
That said, SWT javadoc is linked to from the SWT homepage at
(www.eclipse.org/swt/).
-Billy
Re: Shift-F2 and SWT - where is it? [message #461822 is a reply to message #461820] Fri, 30 September 2005 18:10 Go to previous message
In article <dhk860$ctk$3@news.eclipse.org>, bbiggs@ca.ibm.com (Billy
Biggs) wrote:
> *From:* Billy Biggs <bbiggs@ca.ibm.com>
> *Date:* Fri, 30 Sep 2005 16:45:52 -0400
> > SWT elements - but I don't know how to tell Eclipse where the javadoc
> > is. Where do I get it from please? It doesn't seem to be part of the
> > download package.
> rence/api/
> set
> -Billy
Thanks Billy - Boby got there first. And it works fine (on a single test -
not the world's best statistical sample, but I'm involved in other things
at the moment).
Peter
Previous Topic:FormLayout calculating location of formData.bottom
Next Topic:problems with drawing image with transparent background
Current Time: Wed Jul 23 12:31:52 EDT 2025
Powered by FUDForum. Page generated in 0.30486 seconds
