Force Shell Focus [message #461729] |
Wed, 28 September 2005 14:07  |
Originally posted by: jacker.web.de
Hi!
I am searching for a way to force a shell to the foreground.
shell.forceFocus() doesn't work. Any Idea?
Is there a posibility to detect wheter the shell is hidden behind another
Non-SWT-window?
Re: Force Shell Focus [message #461732 is a reply to message #461729] |
Wed, 28 September 2005 16:43  |
> foreground.
I think that you are looking for the style SWT.ON_TOP for the shell, and when you change to another Non-SWT-window (ALT+TAB) you'll still see the SWT-window.
Another way is that you use the "setActive()" method of the shell, when is not active or at the top. But you'll set the focus in it, and loose from the other window.
> Non-SWT-window?
You can add to the shell a ShellListener, and implement the method "shellDeactivated" or/and "shellIconified".
One is when you put another window over yours, and the other, well, when you icnonifie the shell, or "minimize" it.
Best regards.
FUDForum. Page generated in 0.25755 seconds
