Home » Eclipse Projects » Standard Widget Toolkit (SWT) » HTML text rendering in a text widget (like JLabel in Swing)?
HTML text rendering in a text widget (like JLabel in Swing)? [message #461263] Mon, 19 September 2005 18:27 Go to next message
Hey all,
I have a string that contains HTML text formating tags, such as bold,
italic and line break and would like to display the properly formatted
string in a SWT app.
After searching around and asking some people, I haven't found any SWT
widget that makes this easy, like JLabel in Swing. For instance, I've found
that I can use StyledText/StyleRange to display a string with different font
styles and colors, but getting StyleRange from HTML seems like it might be
difficult.
Before setting out on a difficult task of rolling my own, I want to make
sure there isn't something easy I'm overlooking. Any help?
Nadeem
Re: HTML text rendering in a text widget (like JLabel in Swing)? [message #461277 is a reply to message #461263] Tue, 20 September 2005 07:23 Go to previous messageGo to next message
You could reuse the HTML2TextReader that Eclipse is using to render JavaDoc
in the Hovers.
It is using StyledText and StyleRanges as well and supports basic Font
styles
and paragraphs.
Ben
> Hey all,
> difficult.
> Nadeem
Re: HTML text rendering in a text widget (like JLabel in Swing)? [message #461279 is a reply to message #461277] Tue, 20 September 2005 07:08 Go to previous messageGo to next message
> JavaDoc
> in the Hovers.
How? I get a message that it's not visible.
Do you have a quick example?
:) Henrik
Re: HTML text rendering in a text widget (like JLabel in Swing)? [message #461290 is a reply to message #461263] Tue, 20 September 2005 08:54 Go to previous messageGo to next message
Originally posted by: sunil_kamath.nohotspammail.com
"Nadeem Aboobaker" <nadeem.aboobaker@bea.com> wrote in message
news:dgne1a$o33$1@news.eclipse.org...
> Hey all,
> found that I can use StyledText/StyleRange to display a string with
> different font styles and colors, but getting StyleRange from HTML seems
> like it might be difficult.
Why don't you just use the Browser widget?
Does the widget need to be editable?
Sunil
Re: HTML text rendering in a text widget (like JLabel in Swing)? [message #461335 is a reply to message #461279] Tue, 20 September 2005 19:36 Go to previous message
Ah well, I'd simply copy the entire class into your project.
Ben
>> JavaDoc
>> in the Hovers.
> :) Henrik
Previous Topic:set location of Dialog
Next Topic:improve performance of tree
Current Time: Sun Jul 27 01:53:55 EDT 2025
Powered by FUDForum. Page generated in 0.10202 seconds
