Home » Eclipse Projects » Rich Client Platform (RCP) » Exporting a product based on features
Exporting a product based on features [message #461179] Fri, 05 January 2007 19:30 Go to next message
My RCP application consists of 6 plugins. I created a feature project
and added the 6 plugins to be packaged with the feature. Then I created
a product configuration based on features and added my feature project
to it. When I export the product, I only see my feature and the 6
plugins exported. The depended plugins (eclipse plugins) are not exported.
When I export the product based on plugins, I see all the required
plugins also exported.
Is this is a bug or am I doing something wrong.
Anand
____________________________________________________________ ______________________
Anand Narasimhan
anandn@cisco.com
Re: Exporting a product based on features [message #461206 is a reply to message #461179] Sat, 06 January 2007 14:39 Go to previous messageGo to next message
You must add other features to your product. Either require some of the
basic eclipse/RCP features, or create your own RCP lib feature with the
smallest amount of plugins that you need.
Later,
PW
Re: Exporting a product based on features [message #461212 is a reply to message #461206] Sat, 06 January 2007 17:17 Go to previous messageGo to next message
When I add RCP feature to the included features, I get an error while
exporting.
"Unable to find org.eclispse.osgi_3.2.1R32x_v20060619"
Anand
> Later,
> PW
Anand Narasimhan
anandn@cisco.com
Re: Exporting a product based on features [message #462573 is a reply to message #461212] Tue, 30 January 2007 12:28 Go to previous messageGo to next message
This problem occurs only when I have the RCP patch installed. Looks like
the RCP patch feature installs a newer version of osgi bundle, but the
RCP feature requires org.eclispse.osgi_3.2.1R32x_v20060619. Even though
both bundles are available, some how the export does not seem to find
the required one.
Any suggestions on how to resolve this. Is this a bug in the export wizard?
Anand
> exporting.
> Thanks
> Anand
>> the basic eclipse/RCP features, or create your own RCP lib feature
>> with the smallest amount of plugins that you need.
>> Later,
>> PW
____________________________________________________________ _________________________
Anand Narasimhan
anandn@cisco.com
Re: Exporting a product based on features [message #462588 is a reply to message #462573] Tue, 30 January 2007 18:58 Go to previous messageGo to next message
I seem to recall that the extra _ in the osgi bundle has caused some headaches along the lines; this may be an example of it in action. I seem to recall that it was fixed for the 3.2.2 release which isn't out yet, so your choices are to run with the older feature version for 3.2.0 or wait to see if 3.2.2 fixes the problem.
Alex.
Re: Exporting a product based on features [message #465114 is a reply to message #462588] Fri, 23 March 2007 01:25 Go to previous messageGo to next message
Alex,
Is there a bug on this. If so can you tell me the bug ID.
Anand
> Alex.
Anand Narasimhan
anandn@cisco.com
Re: Exporting a product based on features [message #465130 is a reply to message #465114] Fri, 23 March 2007 06:57 Go to previous message
Yes, but (a) I believe that 3.2.2 solved the problem, and (b) you are just as capable of searching bugs.eclipse.org as I am to find the problem. I don't have the ID to hand.
Alex.
Previous Topic:Extra space in wizard
Next Topic:Text based DialogCellEditor does not allow paste
Current Time: Sun Aug 31 21:07:11 EDT 2025
Powered by FUDForum. Page generated in 0.06947 seconds
