several plugins locations in one product configuration? [message #461173] |
Fri, 05 January 2007 13:36 |
Hi all,
is it possible to specify several plugins locations in one product
configuration?
more details:
I have RCP with several products installed:
<eclipse>
config_A/
config.ini
config_B/
config.ini
plugins/
plugin_Aa/...
plugin_Ab/...
plugin_Ba/...
rcp plugins
Each product is launched as 'eclipse -configuration config_#',
application ids are set in config.ini files, and update.configurator
is used to find installed bundles:
osgi.bundles=...\
org.eclipse.equinox.common@2:start,\
org.eclipse.update.configurator@3:start,\
org.eclipse.core.runtime@start,\
(We have target RCP platforms for different platforms => there are
platform-dependent bundles like SWT; that's why we use update
configurator rather than exact list of bundles.)
Applications work fine. The only problem is that _all_ the plugins are
resolved by the update configurator; thus, some extensions defined for
product_A are visible in product_B. E.g., extra help topics may be
visible, extra menu items may appear, etc.
Is it possible to specify several plugin locations for update
configurator, e.g., use the following structure:
<eclipse>
config_A/
config.ini
config_B/
config.ini
plugins_rcp/
rcp plugins
help plugins
plugins_A
plugin_Aa/...
plugin_Ab/...
plugins_B
plugin_Ba/...
thanks
/Sergey
FUDForum. Page generated in 0.03454 seconds
