Home » Eclipse Projects » Standard Widget Toolkit (SWT) » Rotate a figure around the center
Rotate a figure around the center [message #461158] Sun, 18 September 2005 14:19 Go to next message
I like to rotate a Figure depending on degree.
I have a connection with a symbol in the middle and depending on the
direction of the connection I have to align the symbol.
I have try it with gc.rotate() but unfortunately this rotates the figure
not around the center. Is there an other way to rotate a figure.
Here is my current, not suitable code:
Image img = new Image(display, 31, 31);
GC gc = new GC(img);
Transform tr = new Transform(display);
tr.rotate(45);
gc.setTransform(tr);
gc.drawLine(0,15,30,15);
g.drawImage(img,new Point(r.x+10,r.y-10));
Re: Rotate a figure around the center [message #461163 is a reply to message #461158] Mon, 19 September 2005 05:52 Go to previous messageGo to next message
The normal way is to translate the image, so that the centre of the image is where you want to rotate around, do the rotation, and then translate back again. So if you have a 100x100 image, and you want to rotate around the centre, you translate it (-50,-50), rotate (45) and then translate it back again (50,50).
However, this will result in some image data being pushed outside out of the drawable area, and I'm not sure how the Eclipse libraries handle that having never tried it myself...
Re: Rotate a figure around the center [message #461194 is a reply to message #461163] Mon, 19 September 2005 09:17 Go to previous messageGo to next message
Thanks for your answer. I understand your idee but I don't know how I
translate the image?
I have try it with gc.translate, but this do not bring the right
results. Further I do not understand how I can translate my image back
again because the translater is already set to gc. Or is this possible
with the Graphics g object?
Rectangle r = getBounds().getCopy();
Display display = PlatformUI.getWorkbench().getDisplay();
Image img = new Image(display, 30, 30);
tr.translate(-15,-15); //??????
tr.rotate(45);
g.translate(+15,+15);
g.drawImage(img,new Point(r.x,r.y));
Re: Rotate a figure around the center [message #461257 is a reply to message #461194] Mon, 19 September 2005 13:08 Go to previous messageGo to next message
I'm not sure why you're doing some transforms on the Transform, and why you're doing others on the Graphics Context.
I believe (but do not know for sure) that you can do the transforms on the same Transform instance. So you would have:
tr.translate(startX,startY); // centre of image
tr.translate(15,15); // half the width/height of image
tr.rotate(45); // degrees to rotate
tr.translate(-15,-15); // half the width/height of image
gc.drawImage(img,0,0); // draw at 'notional' zero
gc.setTransform(tr); // associate with the transform
Hope that helps,
Alex.
Re: Rotate a figure around the center [message #461275 is a reply to message #461257] Tue, 20 September 2005 05:44 Go to previous message
Yes, your answer helps.
Here my solution:
Image img = new Image(display, 16,16);
Image img2 = new Image(display, "c:\\test.gif");
tr.translate(8,8);
tr.rotate(60);
tr.translate(-8,-8);
gc.drawImage(img2,0,0);
I am not sure if I have to work with to images but it works.
Jens
> Hope that helps,
> Alex.
Previous Topic:Custom widget
Next Topic:Query for positioning the views
Current Time: Sat Jul 26 15:20:06 EDT 2025
Powered by FUDForum. Page generated in 0.05864 seconds
