Home » Eclipse Projects » Standard Widget Toolkit (SWT) » How to make a TableViewer virtual
How to make a TableViewer virtual [message #461006] Wed, 14 September 2005 09:35 Go to next message
[Eclipse 3.1.0, JDK 1.4.2]
I'm looking for a documentation describing how-to make a TableViewer
virtual.
Does anyone know of such one or can anybody give me a hint how/where to
start?
Michael
Re: How to make a TableViewer virtual [message #461035 is a reply to message #461006] Thu, 15 September 2005 02:53 Go to previous messageGo to next message
Table t = new Table(parent, SWT.VIRTUAL);
//create columns
for(int i=0;i<5;i++) new TableColumn(t,SWT.NONE).setText("#"+i);
TableViewer v = new TableViewer(table);
v.setContentProvider(new ILazyContentProvider(){
//implement your Content Provider here
v.setLabelProvider(new ITableLabelProvider(){
//implement your label Provider here
//for lazy tables setItemCount instead of v.setInput(yourinput)
v.setItemCount(yourItemCount);
You should put the ContentProvider and LabelProvider in seperate
classfiles, I used anonymous classes to show which interfaces must be
implemented.
Howto enable Cellediting: This works the same ways as with non-lazy
TableViewers.
Yves
michael wrote:
> virtual.
> start?
> Regards,
> Michael
Re: How to make a TableViewer virtual [message #461037 is a reply to message #461035] Thu, 15 September 2005 02:54 Go to previous messageGo to next message
Just one last thing:
Don't forget to pack() the TableColumns or you won't see anything.
> //create columns
> implemented.
> TableViewers.
> Regards,
> Yves
> michael wrote:
>> Hi,
>> virtual.
>> to start?
>> Regards,
>> Michael
Re: How to make a TableViewer virtual [message #461078 is a reply to message #461035] Thu, 15 September 2005 11:32 Go to previous messageGo to next message
Hi Yves,
First of all thanks for your help.
Do I guess right, that a "virtual" Table/TableViewer is only lazy loading
but not virtual the way Swing JTable and KTable are?
That means, with these kind of tables its possible to only load the first
n records, but the vertical scrollbar "knows" how much records there are
in the model. So you can scroll down and then the next batch of records
gets displayed.
IMHO, the problem with the SWT/JFace table seems that the table's
scrollbar also only knows of the number of records specified by
setItemCount(int) and so are actually displayed.
I know I could handle the scrollbar's events and re-fill the whole table
by doing a clear() and setItemCount() again, but the vertical scrollbar is
not in sync with the number of records in the model.
Am I right or am I missing anything?
Michael
Am Thu, 15 Sep 2005 08:53:05 +0200 schrieb Yves Harms
<user@domain.invalid>:
> //create columns
> implemented.
> TableViewers.
> Regards,
> Yves
> michael wrote:
>> Hi,
>> virtual.
>> to start?
>> Regards,
>> Michael
Erstellt mit M2, Operas revolutionärem E-Mail-Modul:
http://www.opera.com/m2/
Re: How to make a TableViewer virtual [message #461103 is a reply to message #461078] Fri, 16 September 2005 04:52 Go to previous messageGo to next message
Hi Michael,
as far as i know this concept is centered on the table, not the
scrollbar. The table so to speak only tells the scollbar how many space
it needs (this is a simplification of the real workflow).
Its all about how many items are inside the table. So working with plain
SWT you could always remove(dispose) or add items (new TableItem(..))
without worrying about the scollbar.
Yves
michael wrote:
> Hi michael
> loading but not virtual the way Swing JTable and KTable are?
> first n records, but the vertical scrollbar "knows" how much records
> there are in the model. So you can scroll down and then the next batch
> of records gets displayed.
> table by doing a clear() and setItemCount() again, but the vertical
> scrollbar is not in sync with the number of records in the model.
Re: How to make a TableViewer virtual [message #461119 is a reply to message #461103] Fri, 16 September 2005 10:24 Go to previous messageGo to next message
I think what he is getting at is, say there are actually 1000 items in
the input to the table, but he doesn't want to get all 1000 items at
once. But the scrollbar should actually look like there really are 1000
items in the table even though there aren't 1000 TableItem's yet.
I don't know if the virtual table works this way.
Rich Kulp
Re: How to make a TableViewer virtual [message #461123 is a reply to message #461119] Fri, 16 September 2005 11:47 Go to previous messageGo to next message
That is how it works. For a very minimal jface-level example of this see
the snippet below, or for an swt-level example of this see
http://dev.eclipse.org/viewcvs/index.cgi/org.eclipse.swt.sni ppets/src/org/eclipse/swt/snippets/Snippet144.java?rev=HEAD& amp;content-type=text/vnd.viewcvs-markup .
public class TableViewerVIRTUAL {
Display display = new Display();
Shell shell = new Shell(display);
shell.setBounds(10,10,300,300);
Table table = new Table(shell, SWT.VIRTUAL);
table.setBounds(10,10,200,200);
final TableViewer viewer = new TableViewer(table);
viewer.setItemCount(10000); // <------
viewer.setLabelProvider(new ITableLabelProvider() {
public void removeListener(ILabelProviderListener listener) {}
public boolean isLabelProperty(Object element, String property)
return false;
public void dispose() {}
public void addListener(ILabelProviderListener listener) {}
public String getColumnText(Object element, int columnIndex) {
return "virtual item: " +
String.valueOf(((Integer)element).intValue());
public Image getColumnImage(Object element, int columnIndex) {
return null;
viewer.setContentProvider(new ILazyContentProvider() { // <------
public void inputChanged(Viewer viewer, Object oldInput, Object
newInput) {}
public void updateElement(int index) {
System.out.println("setting: " + index);
viewer.replace(new Integer(index), index);
shell.open();
while (!shell.isDisposed()) {
if (!display.readAndDispatch()) display.sleep();
display.dispose();
Grant
"Rich Kulp" <richkulp@us.NO_SPAM.ibm.com> wrote in message
news:dgekjc$l0u$3@news.eclipse.org...
> Rich Kulp
Re: How to make a TableViewer virtual [message #461136 is a reply to message #461119] Fri, 16 September 2005 15:45 Go to previous messageGo to next message
Originally posted by: micasim.gmx.de
Hi Rich,
indeed, that's what I meant.
Thanks for clarification,
Michael
On Fri, 16 Sep 2005 16:24:44 +0200, Rich Kulp
Re: How to make a TableViewer virtual [message #462325 is a reply to message #461123] Mon, 10 October 2005 10:38 Go to previous messageGo to next message
------=_NextPart_000_0027_01C5CDB9.0A81A6C0
Content-Type: text/plain;
charset="iso-8859-1"
Content-Transfer-Encoding: quoted-printable
Hello Grant,
I try to get your example TableViewerVIRTUAL to work. I get no compile =
error, but if I run the project I get an error message saying:
Exception in thread "main" java.lang.NoClassDefFoundError: =
org/eclipse/core/runtime/ISafeRunnableat =
TableViewerVIRTUAL.main(TableViewerVIRTUAL.java:15)
I am working under Eclipse 3.1, and added a project dependency to SWT =
project (described under http://www.eclipse.org/swt/eclipse.php).
I also added the the org.eclipse.jface_3.1.0.jar to my project.
What did I wrong? Is there something missing?
Thanks for any help!
Content-Type: text/html;
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.0 Transitional//EN">
<HTML><HEAD>
<META http-equiv=3DContent-Type content=3D"text/html; =
charset=3Diso-8859-1">
<META content=3D"MSHTML 6.00.2900.2668" name=3DGENERATOR>
<STYLE></STYLE>
</HEAD>
<BODY>
<DIV><FONT face=3DArial size=3D2>Hello Grant,</FONT></DIV>
<DIV><FONT face=3DArial size=3D2></FONT>&nbsp;</DIV>
<DIV><FONT face=3DArial size=3D2>I try to get your example&nbsp; =
TableViewerVIRTUAL=20
to work. I get no compile error, but if I run the project I get an error =
message=20
saying:</FONT></DIV><FONT face=3DArial size=3D2>
<DIV><BR>Exception in thread "main" java.lang.NoClassDefFoundError:=20
org/eclipse/core/runtime/ISafeRunnable</FONT><FONT face=3DArial =
size=3D2>at=20
TableViewerVIRTUAL.main(TableViewerVIRTUAL.java:15)<BR></FONT ><FONT =
face=3DArial=20
size=3D2><BR></FONT><FONT face=3DArial size=3D2>I am working under =
Eclipse 3.1, and=20
added a project dependency to SWT project (described under <A=20
href=3D"http://www.eclipse.org/swt/eclipse.php">http://www.eclipse.org/sw=
t/eclipse.php</A>).<BR>I=20
also added the the org.eclipse.jface_3.1.0.jar to my =
project.<BR><BR>What did I=20
wrong? Is there something missing?<BR><BR>Thanks for any =
help!</FONT></DIV>
<DIV><FONT face=3DArial size=3D2><BR>&nbsp;</DIV></FONT></BODY></HTML>
------=_NextPart_000_0027_01C5CDB9.0A81A6C0--
Re: How to make a TableViewer virtual [message #462358 is a reply to message #462325] Tue, 11 October 2005 09:39 Go to previous message
JFace has other dependencies, you also need to add org.eclipse.core.runtime
and org.eclipse.osgi.
Grant
"Mr. Burns" <Mr._Burns@web.de> wrote in message
news:didud4$3g6$1@news.eclipse.org...
Hello Grant,
Previous Topic:How to remove TableColumns from Table
Next Topic:Waiting dialogs
Current Time: Fri Jul 18 23:54:56 EDT 2025
Powered by FUDForum. Page generated in 0.05247 seconds
