Home » Eclipse Projects » Rich Client Platform (RCP) » How to specify a file in the config.ini file
How to specify a file in the config.ini file [message #461002] Wed, 03 January 2007 09:29 Go to next message
Hi!
I have implemented my own RCP application.
Now, I need to specify in the VM Arguments of the .product :
<b>-Djava.security.policy=my.java.policy</b>
But, I need to export the file my.java.policy like this:
-MyApplication
|-config.ini
|-<b>my.java.policy</b>
|--plugins directory
| |------>A plugin
| |------>Another plugin
How to do that?
Do you have an idea?
Jean-Michael
Re: How to specify a file in the config.ini file [message #461007 is a reply to message #461002] Wed, 03 January 2007 10:01 Go to previous messageGo to next message
Any files will be relative to the position of the 'eclipse' executable. So, if your entries are like:
eclipse.exe
configuration\config.ini
configuration\my.java.policy
then you would be able to refer to it as configuration\my.java.policy
Alex.
Re: How to specify a file in the config.ini file [message #461011 is a reply to message #461007] Wed, 03 January 2007 10:41 Go to previous messageGo to next message
Hi Alex!
I have tried to do what you say.
I have put my file 'my.java.policy' in the configuration directory of my exported product.
Next, I have written in the config.ini:
-Djava.security.policy=configuration\my.java.policy
And, I launch my application, but it doesn't find my 'my.java.policy' file.
How to specify to Eclipse where to search my file?
Or, Where must I put my file?
Jean-Michael
Re: How to specify a file in the config.ini file [message #461036 is a reply to message #461011] Thu, 04 January 2007 05:36 Go to previous messageGo to next message
Hi!
Finnaly, I have found a solution.
1) I export my product.
2) I write in the myRCPApp.ini file:
-Djava.security.policy=${user.home}/my.java.policy
3) I put my file 'my.java.policy' in the home directory.
And, all seems to work!
But in Eclipse, if I add '-Djava.security.policy=${user.home}/my.java.policy' in the VM Arguments window of my product. And, I test in Eclipse with the 'Launch the product' action, a window appears with this message : 'Reference to undefined variable user.home'
Eclipse doesn't know the user.home variable???
How can I set user.home in Eclipse??
Jean-Michael
Re: How to specify a file in the config.ini file [message #461040 is a reply to message #461036] Thu, 04 January 2007 06:06 Go to previous message
In the launch configuration (Run -> Run...) you can have edit the launch; one of the tabs is 'environment' which allows you to supply values of e.g. user.home.
Alex.
Previous Topic:StreamCorruptedException ?
Next Topic:SWT_AWT bridge usage
Current Time: Mon Sep 08 14:43:09 EDT 2025
Powered by FUDForum. Page generated in 0.10497 seconds
