Home » Eclipse Projects » Standard Widget Toolkit (SWT) » problems with swt browser - mozilla on linux
problems with swt browser - mozilla on linux [message #461027] Wed, 14 September 2005 19:14 Go to next message
Hi!
I have noticed some problems with swt browser under linux with mozilla
(1.7.5 and 1.7.11) - jvm is exitting after SIGSEGV
given problem shows up in browser view and birt components (they are
using HTML display) is there any workaround/bugfix to this?
here goses trace from hs_err file:
---------------------------- BEGIN --------------------------
# An unexpected error has been detected by HotSpot Virtual Machine:
# SIGSEGV (0xb) at pc=0xadef834b, pid=4242, tid=3085526720
# Java VM: Java HotSpot(TM) Client VM (1.5.0_04-b05 mixed mode, sharing)
# Problematic frame:
# C [libdocshell.so+0x2534b]
--------------- T H R E A D ---------------
Current thread (0x0805bbe8): JavaThread "main" [_thread_in_native, id=4242]
siginfo:si_signo=11, si_errno=0, si_code=2, si_addr=0xadf27b28
Registers:
EAX=0x08c932e0, EBX=0xadf2b8a4, ECX=0xadf27b28, EDX=0x08c932e0
ESP=0xbfffb7e0, EBP=0xbfffb9f8, ESI=0x00000003, EDI=0xadf27b28
EIP=0xadef834b, CR2=0xadf27b28, EFLAGS=0x00010286
Top of Stack: (sp=0xbfffb7e0)
0xbfffb7e0: bfffb850 bfffb810 bfffb810 08aab950
0xbfffb7f0: 08aaca38 adf27200 bfffb818 b79f33c4
0xbfffb800: ade2ea64 bfffb840 bfffb850 ade2ea74
0xbfffb810: ade30c8a 00000000 00000001 08c932e0
0xbfffb820: 08aaad0c 08b38f48 bfffb830 ade2ea64
0xbfffb830: 08aaca3c ae0fb564 bfffb858 ae0a3220
0xbfffb840: 08aaad0c 08b69a90 bfffb878 ade33154
0xbfffb850: ade33154 80004005 bfffb878 ae0eeb09
Instructions: (pc=0xadef834b)
0xadef833b: c7 02 00 00 00 00 8b 7d 3c 85 ff 74 09 8b 4d 3c
0xadef834b: c7 01 00 00 00 00 8b 75 0c 85 f6 b8 03 40 00 80
Stack: [0xbfe00000,0xc0000000), sp=0xbfffb7e0, free space=2029k
Native frames: (J=compiled Java code, j=interpreted, Vv=VM code,
C=native code)
C [libdocshell.so+0x3a685]
C [libdocshell.so+0x1be68]
C [libdocshell.so+0x27fed]
C [libdocshell.so+0x28273]
C [libdocshell.so+0x239cd]
C [libdocshell.so+0x32092]
C [libdocshell.so+0x3774b]
_ZN18nsDocumentOpenInfo18TryContentListenerEP21nsIURIContent ListenerP10nsIChannel+0x1cb
C [libdocshell.so+0x368ce]
_ZN18nsDocumentOpenInfo15DispatchContentEP10nsIRequestP11nsI Supports+0x23e
C [libdocshell.so+0x3621f]
C [libnecko.so+0x98e0d]
C [libnecko.so+0x99363]
C [libnecko.so+0x990e5]
C [libnecko.so+0xa1b51]
C [libnecko.so+0x18795]
C [libnecko.so+0x18717]
C [libxpcom.so+0x6628b]
_ZN23nsInputStreamReadyEvent12EventHandlerEP7PLEvent+0x3b
C [libxpcom.so+0x7bc13] PL_HandleEvent+0x23
C [libxpcom.so+0x7bb29] PL_ProcessPendingEvents+0x99
C [libxpcom.so+0x7d778]
C [libwidget_gtk2.so+0x18636]
C [libglib-2.0.so.0+0x4964f]
C [libglib-2.0.so.0+0x23c72]
C [libglib-2.0.so.0+0x24cf8] g_main_context_dispatch+0x98
C [libglib-2.0.so.0+0x25030]
C [libglib-2.0.so.0+0x2527d] g_main_context_iteration+0x6d
C [libswt-pi-gtk-3138.so+0x28746]
Java_org_eclipse_swt_internal_gtk_OS__1g_1main_1context_1ite ration+0x20
J org.eclipse.swt.internal.gtk.OS._g_main_context_iteration(IZ )Z
J org.eclipse.swt.internal.gtk.OS.g_main_context_iteration(IZ) Z
J org.eclipse.swt.widgets.Display.readAndDispatch()Z
j
org.eclipse.ui.internal.Workbench.runEventLoop(Lorg/eclipse/ jface/window/Window$IExceptionHandler;Lorg/eclipse/swt/widge ts/Display;)V+9
j org.eclipse.ui.internal.Workbench.runUI()I+108
j
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Lorg /eclipse/swt/widgets/Display;Lorg/eclipse/ui/application/Wor kbenchAdvisor;)I+11
j
org.eclipse.ui.PlatformUI.createAndRunWorkbench(Lorg/eclipse /swt/widgets/Display;Lorg/eclipse/ui/application/WorkbenchAd visor;)I+2
j
org.eclipse.ui.internal.ide.IDEApplication.run(Ljava/lang/Ob ject;)Ljava/lang/Object;+98
j
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Lj ava/lang/Object;)Ljava/lang/Object;+257
j
org.eclipse.core.runtime.adaptor.EclipseStarter.run(Ljava/la ng/Object;)Ljava/lang/Object;+170
j
org.eclipse.core.runtime.adaptor.EclipseStarter.run([Ljava/l ang/String;Ljava/lang/Runnable;)Ljava/lang/Object;+57
v ~StubRoutines::call_stub
V [libjvm.so+0x16bf8c]
V [libjvm.so+0x25e5f8]
V [libjvm.so+0x16bdbf]
V [libjvm.so+0x27f84c]
V [libjvm.so+0x28251a]
V [libjvm.so+0x1ce24b]
C [libjava.so+0x13764]
Java_sun_reflect_NativeMethodAccessorImpl_invoke0+0x34
j
sun.reflect.NativeMethodAccessorImpl.invoke0(Ljava/lang/refl ect/Method;Ljava/lang/Object;[Ljava/lang/Object;)Ljava/lang/ Object;+0
j
sun.reflect.NativeMethodAccessorImpl.invoke(Ljava/lang/Objec t;[Ljava/lang/Object;)Ljava/lang/Object;+87
j
sun.reflect.DelegatingMethodAccessorImpl.invoke(Ljava/lang/O bject;[Ljava/lang/Object;)Ljava/lang/Object;+6
j
java.lang.reflect.Method.invoke(Ljava/lang/Object;[Ljava/lan g/Object;)Ljava/lang/Object;+111
j
org.eclipse.core.launcher.Main.invokeFramework([Ljava/lang/S tring;[Ljava/net/URL;)V+181
j org.eclipse.core.launcher.Main.basicRun([Ljava/lang/String;) V+107
j org.eclipse.core.launcher.Main.run([Ljava/lang/String;)I+4
j org.eclipse.core.launcher.Main.main([Ljava/lang/String;)V+10
V [libjvm.so+0x18f102]
V [libjvm.so+0x1838c7]
C [java+0x17fe]
C [libc.so.6+0x14fcb] __libc_start_main+0xdb
Java frames: (J=compiled Java code, j=interpreted, Vv=VM code)
j
j
j
j
j
j
j
j
j
j
j
j
--------------- P R O C E S S ---------------
Java Threads: ( => current thread )
0x0884d210 JavaThread "Worker-5" [_thread_blocked, id=4261]
0x088ab538 JavaThread "Worker-4" [_thread_blocked, id=4260]
0x08858bc8 JavaThread "Worker-3" [_thread_blocked, id=4259]
0x0869acd8 JavaThread "Worker-2" [_thread_blocked, id=4258]
0x0815b340 JavaThread "Worker-1" [_thread_blocked, id=4257]
0x080e3d18 JavaThread "Java indexing" daemon [_thread_blocked, id=4256]
0x086158c0 JavaThread "Worker-0" [_thread_blocked, id=4255]
0x083bc1c8 JavaThread "Start Level Event Dispatcher" daemon
[_thread_blocked, id=4254]
0x083bde70 JavaThread "Framework Event Dispatcher" daemon
[_thread_blocked, id=4253]
0x083b8678 JavaThread "State Data Manager" daemon [_thread_blocked,
id=4252]
0x080a28f8 JavaThread "Low Memory Detector" daemon [_thread_blocked,
id=4248]
0x080a13a8 JavaThread "CompilerThread0" daemon [_thread_blocked, id=4247]
0x080a0480 JavaThread "Signal Dispatcher" daemon [_thread_blocked,
id=4246]
0x08099ef0 JavaThread "Finalizer" daemon [_thread_blocked, id=4245]
0x080991f0 JavaThread "Reference Handler" daemon [_thread_blocked,
id=4244]
=>0x0805bbe8 JavaThread "main" [_thread_in_native, id=4242]
Other Threads:
0x080966f8 VMThread [id=4243]
0x080a3d88 WatcherThread [id=4249]
VM state:not at safepoint (normal execution)
VM Mutex/Monitor currently owned by a thread: None
Heap
def new generation total 2880K, used 1686K [0x59940000, 0x59c60000,
0x5acf0000)
eden space 2560K, 65% used [0x59940000, 0x59ae5940, 0x59bc0000)
from space 320K, 0% used [0x59bc0000, 0x59bc0000, 0x59c10000)
to space 320K, 0% used [0x59c10000, 0x59c10000, 0x59c60000)
tenured generation total 37824K, used 8698K [0x5acf0000, 0x5d1e0000,
0x69940000)
the space 37824K, 22% used [0x5acf0000, 0x5b56e8f8, 0x5b56ea00,
0x5d1e0000)
compacting perm gen total 21504K, used 21456K [0x69940000,
0x6ae40000, 0x6d940000)
the space 21504K, 99% used [0x69940000, 0x6ae34010, 0x6ae34200,
0x6ae40000)
ro space 8192K, 68% used [0x6d940000, 0x6deba338, 0x6deba400,
0x6e140000)
rw space 12288K, 47% used [0x6e140000, 0x6e6f97d8, 0x6e6f9800,
0x6ed40000)
Dynamic libraries:
08048000-08056000 r-xp 00000000 03:46 218374175
/usr/lib/jdk1.5.0_04/bin/java
08056000-08058000 rwxp 0000e000 03:46 218374175
08058000-08fc6000 rwxp 08058000 00:00 0
59940000-59c60000 rwxp 59940000 00:00 0
59c60000-5acf0000 rwxp 59c60000 00:00 0
5acf0000-5d1e0000 rwxp 5acf0000 00:00 0
5d1e0000-69940000 rwxp 5d1e0000 00:00 0
69940000-6ae40000 rwxp 69940000 00:00 0
6ae40000-6d940000 rwxp 6ae40000 00:00 0
6d940000-6debb000 r-xs 00001000 03:46 84914530
/usr/lib/jdk1.5.0_04/jre/lib/i386/client/classes.jsa
6debb000-6e140000 rwxp 6debb000 00:00 0
6e140000-6e6fa000 rwxp 0057c000 03:46 84914530
6e6fa000-6ed40000 rwxp 6e6fa000 00:00 0
6ed40000-6ee0f000 rwxp 00b36000 03:46 84914530
6ee0f000-6f140000 rwxp 6ee0f000 00:00 0
6f140000-6f144000 r-xs 00c05000 03:46 84914530
6f144000-6f540000 rwxp 6f144000 00:00 0
aa3ec000-aa3ef000 rwxp aa3ec000 00:00 0
aa3ef000-aa46c000 rwxp aa3ef000 00:00 0
aa46c000-aa479000 r-xp 00000000 03:46 218749421
/usr/X11R6/lib/X11/fonts/TTF/VeraMono.ttf
aa479000-aa49d000 r-xp 00000000 03:46 218565634
/usr/X11R6/lib/X11/fonts/TTF/ARIALBD.TTF
aa4c0000-aa4c1000 ---p aa4c0000 00:00 0
aa4c1000-aacc0000 rwxp aa4c1000 00:00 0
aacc0000-aad74000 r-xp 00000000 03:46 50647276 /usr/lib/libasound.so.2.0.0
aad74000-aad79000 rwxp 000b3000 03:46 50647276 /usr/lib/libasound.so.2.0.0
aad79000-aad9a000 r-xp 00000000 03:46 50347933
/usr/lib/libaudiofile.so.0.0.2
aad9a000-aad9d000 rwxp 00020000 03:46 50347933
aad9d000-aada6000 r-xp 00000000 03:46 50347960 /usr/lib/libesd.so.0.2.34
aada6000-aada7000 rwxp 00008000 03:46 50347960 /usr/lib/libesd.so.0.2.34
aada7000-aadaa000 rwxp aada7000 00:00 0
aadaa000-ab5a7000 rwxp aadaa000 00:00 0
ab5a7000-ab5a8000 ---p ab5a7000 00:00 0
ab5a8000-abda7000 rwxp ab5a8000 00:00 0
abda7000-abda8000 ---p abda7000 00:00 0
abda8000-ac5a7000 rwxp abda8000 00:00 0
ac5a7000-ac609000 r-xp 00000000 03:46 135209160
/usr/lib/mozilla-1.7.5/components/libmsgcompose.so
ac609000-ac60c000 rwxp 00061000 03:46 135209160
ac60c000-ac614000 r-xp 00000000 03:46 135209158
/usr/lib/mozilla-1.7.5/components/libimpText.so
ac614000-ac615000 rwxp 00007000 03:46 135209158
ac615000-ac61c000 r-xp 00000000 03:46 135209154
/usr/lib/mozilla-1.7.5/components/libspellchecker.so
ac61c000-ac61d000 rwxp 00006000 03:46 135209154
ac61d000-ac622000 r-xp 00000000 03:46 135209153
/usr/lib/mozilla-1.7.5/components/libtxmgr.so
ac622000-ac623000 rwxp 00004000 03:46 135209153
ac623000-ac62a000 r-xp 00000000 03:46 135209151
/usr/lib/mozilla-1.7.5/components/libvcard.so
ac62a000-ac62b000 rwxp 00006000 03:46 135209151
ac62b000-ac634000 r-xp 00000000 03:46 135209150
/usr/lib/mozilla-1.7.5/components/libmimeemitter.so
ac634000-ac635000 rwxp 00009000 03:46 135209150
ac635000-ac645000 r-xp 00000000 03:46 135209147
/usr/lib/mozilla-1.7.5/components/libpref.so
ac645000-ac646000 rwxp 00010000 03:46 135209147
ac646000-ac6f3000 r-xp 00000000 03:46 135209143
/usr/lib/mozilla-1.7.5/components/libeditor.so
ac6f3000-ac6f7000 rwxp 000ad000 03:46 135209143
ac6f7000-ac708000 r-xp 00000000 03:46 135209141
/usr/lib/mozilla-1.7.5/components/libuniversalchardet.so
ac708000-ac711000 rwxp 00011000 03:46 135209141
ac711000-ac763000 r-xp 00000000 03:46 135209139
/usr/lib/mozilla-1.7.5/components/libgfx_gtk.so
ac763000-ac768000 rwxp 00051000 03:46 135209139
ac768000-ac7be000 r-xp 00000000 03:46 135209134
/usr/lib/mozilla-1.7.5/components/libtransformiix.so
ac7be000-ac7c2000 rwxp 00055000 03:46 135209134
ac7c2000-ac7de000 r-xp 00000000 03:46 135209133
/usr/lib/mozilla-1.7.5/components/libmsgdb.so
ac7de000-ac7e0000 rwxp 0001b000 03:46 135209133
ac7e0000-ac7ed000 r-xp 00000000 03:46 135209131
/usr/lib/mozilla-1.7.5/components/libinspector.so
ac7ed000-ac7ee000 rwxp 0000c000 03:46 135209131
ac7ee000-ac821000 r-xp 00000000 03:46 135209212
/usr/lib/mozilla-1.7.5/components/libxpinstall.so
ac821000-ac823000 rwxp 00033000 03:46 135209212
ac823000-ac82a000 r-xp 00000000 03:46 135209210
/usr/lib/mozilla-1.7.5/components/libpippki.so
ac82a000-ac82b000 rwxp 00006000 03:46 135209210
ac82b000-ac8a8000 r-xp 00000000 03:46 135209208
/usr/lib/mozilla-1.7.5/components/libaccessibility.so
ac8a8000-ac8b5000 rwxp 0007d000 03:46 135209208
ac8b5000-ac91f000 r-xp 00000000 03:46 50342497 /usr/lib/libsoftokn3.so
ac91f000-ac923000 rwxp 00069000 03:46 50342497 /usr/lib/libsoftokn3.so
ac923000-ac98a000 r-xp 00000000 03:46 50342498 /usr/lib/libnss3.so
ac98a000-ac98f000 rwxp 00066000 03:46 50342498 /usr/lib/libnss3.so
ac98f000-ac9af000 r-xp 00000000 03:46 50406180 /usr/lib/libssl3.so
ac9af000-ac9b1000 rwxp 0001f000 03:46 50406180 /usr/lib/libssl3.so
ac9b1000-ac9d2000 r-xp 00000000 03:46 50342501 /usr/lib/libsmime3.so
ac9d2000-ac9d4000 rwxp 00021000 03:46 50342501 /usr/lib/libsmime3.so
ac9d4000-aca25000 r-xp 00000000 03:46 135209206
/usr/lib/mozilla-1.7.5/components/libpipnss.so
aca25000-aca28000 rwxp 00051000 03:46 135209206
aca28000-aca46000 r-xp 00000000 03:46 135209201
/usr/lib/mozilla-1.7.5/components/libnsappshell.so
aca46000-aca48000 rwxp 0001d000 03:46 135209201
aca48000-acad6000 r-xp 00000000 03:46 135209199
/usr/lib/mozilla-1.7.5/components/libmsgimap.so
acad6000-acada000 rwxp 0008d000 03:46 135209199
acada000-acae0000 r-xp 00000000 03:46 135209191
/usr/lib/mozilla-1.7.5/components/libmsgmdn.so
acae0000-acae1000 rwxp 00006000 03:46 135209191
acae1000-acb36000 r-xp 00000000 03:46 135209189
/usr/lib/mozilla-1.7.5/components/libhtmlpars.so
acb36000-acb3b000 rwxp 00055000 03:46 135209189
acb3b000-acb42000 r-xp 00000000 03:46 50331802 /usr/lib/libpopt.so.0.0.0
acb42000-acb43000 rwxp 00006000 03:46 50331802 /usr/lib/libpopt.so.0.0.0
acb43000-acb47000 r-xp 00000000 03:46 59299849
/usr/lib/libORBitCosNaming-2.so.0.0.0
acb47000-acb48000 rwxp 00004000 03:46 59299849
acb48000-acb4e000 r-xp 00000000 03:42 8417570 /lib/tls/librt-2.3.5.so
acb4e000-acb50000 rwxp 00005000 03:42 8417570 /lib/tls/librt-2.3.5.so
acb50000-acc3c000 r-xp 00000000 03:46 50332251 /usr/lib/libcrypto.so.0.9.7
acc3c000-acc4e000 rwxp 000ec000 03:46 50332251 /usr/lib/libcrypto.so.0.9.7
acc4e000-acc51000 rwxp acc4e000 00:00 0
acc51000-acc7f000 r-xp 00000000 03:46 50332250 /usr/lib/libssl.so.0.9.7
acc7f000-acc82000 rwxp 0002e000 03:46 50332250 /usr/lib/libssl.so.0.9.7
acc82000-acd86000 r-xp 00000000 03:46 50334939 /usr/lib/libxml2.so.2.6.19
acd86000-acd8e000 rwxp 00104000 03:46 50334939 /usr/lib/libxml2.so.2.6.19
acd8e000-acd8f000 rwxp acd8e000 00:00 0
acd8f000-acde0000 r-xp 00000000 03:46 59292020
/usr/lib/libbonobo-2.so.0.0.0
acde0000-acdea000 rwxp 00051000 03:46 59292020
acdea000-ace1c000 r-xp 00000000 03:46 59209076
/usr/lib/libgconf-2.so.4.1.0
ace1c000-ace1f000 rwxp 00031000 03:46 59209076
ace1f000-ace65000 r-xp 00000000 03:46 59299845
/usr/lib/libORBit-2.so.0.0.0
ace65000-ace6e000 rwxp 00046000 03:46 59299845
ace6e000-ace80000 r-xp 00000000 03:46 59292023
/usr/lib/libbonobo-activation.so.4.0.0
ace80000-ace83000 rwxp 00011000 03:46 59292023
ace83000-acedb000 r-xp 00000000 03:46 59276791
/usr/lib/libgnomevfs-2.so.0.600.1
acedb000-acee0000 rwxp 00058000 03:46 59276791
acee7000-acefa000 r-xp 00000000 03:46 59292051
/usr/lib/libgnome-2.so.0.600.1
acefa000-acefb000 rwxp 00013000 03:46 59292051
acefb000-acf00000 r-xp 00000000 03:46 135209187
/usr/lib/mozilla-1.7.5/components/libbayesflt.so
acf00000-acf01000 rwxp 00005000 03:46 135209187
acf01000-acf06000 r-xp 00000000 03:46 135209185
/usr/lib/mozilla-1.7.5/components/libnkgnomevfs.so
acf06000-acf07000 rwxp 00005000 03:46 135209185
acf07000-acf10000 r-xp 00000000 03:46 135209184
/usr/lib/mozilla-1.7.5/components/libcookie.so
acf10000-acf11000 rwxp 00009000 03:46 135209184
acf11000-acf22000 r-xp 00000000 03:46 135209181
/usr/lib/mozilla-1.7.5/components/libnsprefm.so
acf22000-acf23000 rwxp 00011000 03:46 135209181
acf23000-acf28000 r-xp 00000000 03:46 135209180
/usr/lib/mozilla-1.7.5/components/libxpcom_compat_c.so
acf28000-acf29000 rwxp 00005000 03:46 135209180
acf29000-acf30000 r-xp 00000000 03:46 135209177
/usr/lib/mozilla-1.7.5/components/libmsgsmime.so
acf30000-acf31000 rwxp 00006000 03:46 135209177
acf31000-acf35000 r-xp 00000000 03:46 135209173
/usr/lib/mozilla-1.7.5/components/libfileview.so
acf35000-acf36000 rwxp 00004000 03:46 135209173
acf36000-acf62000 r-xp 00000000 03:46 135209170
/usr/lib/mozilla-1.7.5/components/libimglib2.so
acf62000-acf63000 rwxp 0002c000 03:46 135209170
acf63000-acf6c000 r-xp 00000000 03:46 135209168
/usr/lib/mozilla-1.7.5/components/libipcdc.so
acf6c000-acf6d000 rwxp 00008000 03:46 135209168
acf6d000-acf7e000 r-xp 00000000 03:46 135209165
/usr/lib/mozilla-1.7.5/components/libxmlextras.so
acf7e000-acf7f000 rwxp 00011000 03:46 135209165
acf7f000-acfb6000 r-xp 00000000 03:46 135209164
/usr/lib/mozilla-1.7.5/components/libi18n.so
acfb6000-acfb9000 rwxp 00036000 03:46 135209164
acfb9000-acfbe000 r-xp 00000000 03:46 135209122
/usr/lib/mozilla-1.7.5/components/libimpComm4xMail.so
acfbe000-acfbf000 rwxp 00004000 03:46 135209122
acfbf000-acffe000 r-xp 00000000 03:46 135209121
/usr/lib/mozilla-1.7.5/components/libxpical.so
acffe000-ad008000 rwxp 0003e000 03:46 135209121
ad008000-ad00f000 rwxp ad008000 00:00 0
ad00f000-ad023000 r-xp 00000000 03:46 135209120
/usr/lib/mozilla-1.7.5/components/libcaps.so
ad023000-ad024000 rwxp 00013000 03:46 135209120
ad024000-ad096000 r-xp 00000000 03:46 135209110
/usr/lib/mozilla-1.7.5/components/libwebsrvcs.so
ad096000-ad09b000 rwxp 00071000 03:46 135209110
ad09b000-ad0dd000 r-xp 00000000 03:46 135209109
/usr/lib/mozilla-1.7.5/components/libmsgnews.so
ad0dd000-ad0e0000 rwxp 00042000 03:46 135209109
ad0e0000-ad0fd000 r-xp 00000000 03:46 135209101
/usr/lib/mozilla-1.7.5/components/libwallet.so
ad0fd000-ad0fe000 rwxp 0001d000 03:46 135209101
ad0fe000-ad106000 r-xp 00000000 03:46 135209099
/usr/lib/mozilla-1.7.5/components/libmyspell.so
ad106000-ad107000 rwxp 00007000 03:46 135209099
ad107000-ad12f000 r-xp 00000000 03:46 135209097
/usr/lib/mozilla-1.7.5/components/libembedcomponents.so
ad12f000-ad131000 rwxp 00028000 03:46 135209097
ad131000-ad132000 r-xp 00000000 03:46 135209096
/usr/lib/mozilla-1.7.5/components/libmozfind.so
ad132000-ad133000 rwxp 00001000 03:46 135209096
ad133000-ad141000 r-xp 00000000 03:46 135209092
/usr/lib/mozilla-1.7.5/components/libtypeaheadfind.so
ad141000-ad142000 rwxp 0000d000 03:46 135209092
ad142000-ad170000 r-xp 00000000 03:46 135209091
/usr/lib/mozilla-1.7.5/components/libwidget_gtk2.so
ad170000-ad173000 rwxp 0002e000 03:46 135209091
ad173000-ad187000 r-xp 00000000 03:46 134434128
/usr/lib/mozilla-1.7.5/components/libprofile.so
ad187000-ad188000 rwxp 00014000 03:46 134434128
ad188000-ad18f000 r-xp 00000000 03:46 134434127
/usr/lib/mozilla-1.7.5/components/libpipboot.so
ad18f000-ad190000 rwxp 00006000 03:46 134434127
ad190000-ad193000 r-xp 00000000 03:46 134434124
/usr/lib/mozilla-1.7.5/components/libmailview.so
ad193000-ad194000 rwxp 00002000 03:46 134434124
ad194000-ad1a7000 r-xp 00000000 03:46 134353915
/usr/lib/mozilla-1.7.5/components/libcomposer.so
ad1a7000-ad1a9000 rwxp 00012000 03:46 134353915
ad1a9000-ad1ef000 r-xp 00000000 03:46 134353914
/usr/lib/mozilla-1.7.5/components/liblocalmail.so
ad1ef000-ad1f2000 rwxp 00046000 03:46 134353914
ad1f2000-ad207000 r-xp 00000000 03:46 83907950
/usr/X11R6/lib/libICE.so.6.3
ad207000-ad208000 rwxp 00014000 03:46 83907950
ad208000-ad20a000 rwxp ad208000 00:00 0
ad20a000-ad211000 r-xp 00000000 03:46 84847788 /usr/X11R6/lib/libSM.so.6.0
ad211000-ad212000 rwxp 00007000 03:46 84847788 /usr/X11R6/lib/libSM.so.6.0
ad212000-ad25f000 r-xp 00000000 03:46 83907952 /usr/X11R6/lib/libXt.so.6.0
ad25f000-ad262000 rwxp 0004d000 03:46 83907952 /usr/X11R6/lib/libXt.so.6.0
ad262000-ad263000 rwxp ad262000 00:00 0
ad274000-ad275000 r-xp ad274000 00:00 0
ad284000-ad287000 r-xp 00000000 03:46 135209228
/usr/lib/mozilla-1.7.5/libgtkxtbin.so
ad287000-ad288000 rwxp 00003000 03:46 135209228
ad288000-ad2b9000 r-xp 00000000 03:46 134353913
/usr/lib/mozilla-1.7.5/components/libgkplugin.so
ad2b9000-ad2bb000 rwxp 00030000 03:46 134353913
ad2bb000-ad2d8000 r-xp 00000000 03:46 134353911
/usr/lib/mozilla-1.7.5/components/libgfxps.so
ad2d8000-ad30d000 rwxp 0001d000 03:46 134353911
ad30d000-ad318000 r-xp 00000000 03:46 134353906
/usr/lib/mozilla-1.7.5/components/libnecko2.so
ad318000-ad319000 rwxp 0000b000 03:46 134353906
ad319000-ad322000 r-xp 00000000 03:46 134353902
/usr/lib/mozilla-1.7.5/components/libautoconfig.so
ad322000-ad323000 rwxp 00008000 03:46 134353902
ad323000-ad392000 r-xp 00000000 03:46 134353898
/usr/lib/mozilla-1.7.5/components/libaddrbook.so
ad392000-ad397000 rwxp 0006f000 03:46 134353898
ad397000-ad398000 rwxp ad397000 00:00 0
ad398000-ad3a8000 r-xp 00000000 03:46 134353894
/usr/lib/mozilla-1.7.5/components/libwebbrwsr.so
ad3a8000-ad3a9000 rwxp 00010000 03:46 134353894
ad3a9000-ad3b3000 r-xp 00000000 03:46 134353890
/usr/lib/mozilla-1.7.5/components/libjar50.so
ad3b3000-ad3b4000 rwxp 0000a000 03:46 134353890
ad3b4000-ad471000 r-xp 00000000 03:46 134353888
/usr/lib/mozilla-1.7.5/components/libuconv.so
ad471000-ad478000 rwxp 000bd000 03:46 134353888
ad478000-ad482000 rwxp ad478000 00:00 0
ad482000-ad485000 r-xp 00000000 03:46 135209225
/usr/lib/mozilla-1.7.5/libprldap50.so
ad485000-ad486000 rwxp 00003000 03:46 135209225
ad486000-ad4ae000 r-xp 00000000 03:46 134381189
/usr/lib/mozilla-1.7.5/libldap50.so
ad4ae000-ad4b0000 rwxp 00027000 03:46 134381189
ad4b0000-ad4bc000 r-xp 00000000 03:46 134354203
/usr/lib/mozilla-1.7.5/components/libmozldap.so
ad4bc000-ad4bd000 rwxp 0000c000 03:46 134354203
ad4bd000-ad4c5000 r-xp 00000000 03:46 134354200
/usr/lib/mozilla-1.7.5/components/libucvmath.so
ad4c5000-ad4c6000 rwxp 00008000 03:46 134354200
ad4c6000-ad4d8000 r-xp 00000000 03:46 134354199
/usr/lib/mozilla-1.7.5/components/libimport.so
ad4d8000-ad4d9000 rwxp 00012000 03:46 134354199
ad4d9000-ad563000 r-xp 00000000 03:46 134354193
/usr/lib/mozilla-1.7.5/components/libmailnews.so
ad563000-ad568000 rwxp 0008a000 03:46 134354193
ad568000-ad59b000 r-xp 00000000 03:46 134354189
/usr/lib/mozilla-1.7.5/components/libmork.so
ad59b000-ad59d000 rwxp 00033000 03:46 134354189
ad59d000-ad5a0000 r-xp 00000000 03:46 134354184
/usr/lib/mozilla-1.7.5/components/libwalletviewers.so
ad5a0000-ad5a1000 rwxp 00002000 03:46 134354184
ad5a1000-ad5c8000 r-xp 00000000 03:46 134354182
/usr/lib/mozilla-1.7.5/components/librdf.so
ad5c8000-ad5ca000 rwxp 00027000 03:46 134354182
ad5ca000-ad5cd000 r-xp 00000000 03:46 134354180
/usr/lib/mozilla-1.7.5/components/libxremote_client.so
ad5cd000-ad5ce000 rwxp 00002000 03:46 134354180
ad5ce000-ad5e3000 r-xp 00000000 03:46 134354176
/usr/lib/mozilla-1.7.5/components/libchrome.so
ad5e3000-ad5e4000 rwxp 00015000 03:46 134354176
ad5e4000-ad604000 r-xp 00000000 03:46 135209231
/usr/lib/mozilla-1.7.5/libgkgfx.so
ad604000-ad605000 rwxp 00020000 03:46 135209231
ad605000-adbac000 r-xp 00000000 03:46 134354174
/usr/lib/mozilla-1.7.5/components/libgklayout.so
adbac000-adbe7000 rwxp 005a7000 03:46 134354174
adbe7000-adbed000 rwxp adbe7000 00:00 0
adbed000-adc05000 r-xp 00000000 03:46 134381183
/usr/lib/mozilla-1.7.5/libjsj.so
adc05000-adc07000 rwxp 00017000 03:46 134381183
adc07000-adc1e000 r-xp 00000000 03:46 134354171
/usr/lib/mozilla-1.7.5/components/liboji.so
adc1e000-adc1f000 rwxp 00017000 03:46 134354171
adc1f000-adcdd000 r-xp 00000000 03:46 134354169
/usr/lib/mozilla-1.7.5/components/libnecko.so
adcdd000-adce3000 rwxp 000be000 03:46 134354169
adce3000-add24000 r-xp 00000000 03:46 134354168
/usr/lib/mozilla-1.7.5/components/libxpconnect.so
add24000-add27000 rwxp 00041000 03:46 134354168
add27000-add41000 r-xp 00000000 03:46 135209224
/usr/lib/mozilla-1.7.5/libxpcom_compat.so
add41000-add42000 rwxp 00019000 03:46 135209224
add42000-add8f000 r-xp 00000000 03:46 135209221
/usr/lib/mozilla-1.7.5/libmsgbaseutil.so
add8f000-add91000 rwxp 0004d000 03:46 135209221
add91000-addc3000 r-xp 00000000 03:46 134354166
/usr/lib/mozilla-1.7.5/components/libmime.so
addc3000-addc5000 rwxp 00031000 03:46 134354166
addc5000-ade32000 r-xp 00000000 03:46 134354164
/usr/lib/mozilla-1.7.5/components/libappcomps.so
ade32000-ade35000 rwxp 0006d000 03:46 134354164
ade35000-ade3b000 r-xp 00000000 03:46 134354158
/usr/lib/mozilla-1.7.5/components/libp3p.so
ade3b000-ade3c000 rwxp 00006000 03:46 134354158
ade3c000-ade4e000 r-xp 00000000 03:46 134354156
/usr/lib/mozilla-1.7.5/components/libjsd.so
ade4e000-ade4f000 rwxp 00012000 03:46 134354156
ade4f000-ade55000 r-xp 00000000 03:46 134354147
/usr/lib/mozilla-1.7.5/components/libxremoteservice.so
ade55000-ade56000 rwxp 00005000 03:46 134354147
ade56000-adecf000 r-xp 00000000 03:46 134381188
/usr/lib/mozilla-1.7.5/libmozjs.so
adecf000-aded3000 rwxp 00079000 03:46 134381188
aded3000-adf2b000 r-xp 00000000 03:46 134354145
/usr/lib/mozilla-1.7.5/components/libdocshell.so
adf2b000-adf2e000 rwxp 00058000 03:46 134354145
adf2e000-adf36000 r-xp 00000000 03:46 50425732 /usr/lib/libgcc_s.so.1
adf36000-adf37000 rwxp 00007000 03:46 50425732 /usr/lib/libgcc_s.so.1
adf37000-adfe5000 r-xp 00000000 03:46 50425742 /usr/lib/libstdc++.so.5.0.7
adfe5000-adfea000 rwxp 000ad000 03:46 50425742 /usr/lib/libstdc++.so.5.0.7
adfea000-adfef000 rwxp adfea000 00:00 0
adff6000-ae005000 r-xp 00000000 03:46 218753909
/usr/X11R6/lib/X11/fonts/TTF/VeraSe.ttf
ae005000-ae00b000 r-xp 00000000 03:46 134354144
/usr/lib/mozilla-1.7.5/components/libsystem-pref.so
ae00b000-ae00c000 rwxp 00005000 03:46 134354144
ae00c000-ae00e000 r-xp 00000000 03:46 67207353 /usr/lib/gconv/UTF-16.so
ae00e000-ae010000 rwxp 00001000 03:46 67207353 /usr/lib/gconv/UTF-16.so
ae010000-ae014000 r-xp 00000000 03:46 50342500 /usr/lib/libplc4.so
ae014000-ae015000 rwxp 00003000 03:46 50342500 /usr/lib/libplc4.so
ae015000-ae017000 r-xp 00000000 03:46 50342499 /usr/lib/libplds4.so
ae017000-ae018000 rwxp 00001000 03:46 50342499 /usr/lib/libplds4.so
ae018000-ae048000 r-xp 00000000 03:46 50342496 /usr/lib/libnspr4.so
ae048000-ae04a000 rwxp 00030000 03:46 50342496 /usr/lib/libnspr4.so
ae04a000-ae04b000 rwxp ae04a000 00:00 0
ae04b000-ae0fa000 r-xp 00000000 03:46 135209227
/usr/lib/mozilla-1.7.5/libxpcom.so
ae0fa000-ae100000 rwxp 000af000 03:46 135209227
ae100000-ae121000 rwxp ae100000 00:00 0
ae121000-ae200000 ---p ae121000 00:00 0
ae20a000-ae219000 r-xp 00000000 03:46 218753885
/usr/X11R6/lib/X11/fonts/TTF/VeraSeBd.ttf
ae219000-ae22b000 r-xp 00000000 03:45 18961813
/home/thomas/eclipse-3.1/configuration/org.eclipse.osgi/bund les/208/1/.cp/libswt-mozilla-gtk-3138.so
ae22b000-ae22c000 rwxp 00011000 03:45 18961813
ae22c000-ae256000 r-xs 00000000 03:45 67987533
/home/thomas/eclipse-3.1/plugins/org.eclipse.ui.browser_3.1. 0.jar
ae256000-ae25d000 r-xs 00000000 03:45 104559021
/home/thomas/eclipse-extensions/wtp/eclipse/plugins/org.ecli pse.wst.internet.proxy_0.7.0/ipproxy.jar
ae25d000-ae263000 r-xs 00000000 03:45 67987504
/home/thomas/eclipse-3.1/plugins/org.eclipse.update.schedule r_3.1.0.jar
ae263000-ae26c000 r-xs 00000000 03:45 27684328
/home/thomas/eclipse-extensions/tptp/eclipse/plugins/org.ecl ipse.hyades.execution_4.1.0/hexr.jar
ae26c000-ae28a000 r-xs 00000000 03:45 50460106
/home/thomas/eclipse-3.1/plugins/org.junit_3.8.1/junit.jar
ae28a000-ae28c000 r-xs 00000000 03:45 84931635
/home/thomas/eclipse-extensions/tptp/eclipse/plugins/org.ecl ipse.hyades.test.tools.core_4.1.0/java.runner.jar
ae28c000-ae2a0000 r-xs 00000000 03:45 84931636
/home/thomas/eclipse-extensions/tptp/eclipse/plugins/org.ecl ipse.hyades.test.tools.core_4.1.0/manual.runner.jar
ae2a0000-ae2ac000 r-xs 00000000 03:45 84931630
/home/thomas/eclipse-extensions/tptp/eclipse/plugins/org.ecl ipse.hyades.test.tools.core_4.1.0/common.runner.jar
ae2ac000-ae2ce000 r-xs 00000000 03:45 55653531
/home/thomas/eclipse-extensions/tptp/eclipse/plugins/org.ecl ipse.hyades.test.core_4.1.0/test-core.jar
ae2ce000-ae2d2000 r-xs 00000000 03:45 55653527
/home/thomas/eclipse-extensions/tptp/eclipse/plugins/org.ecl ipse.hyades.test.core_4.1.0/hexrecr.jar
ae2d2000-ae2e4000 r-xs 00000000 03:45 55653528
/home/thomas/eclipse-extensions/tptp/eclipse/plugins/org.ecl ipse.hyades.test.core_4.1.0/hexteh.jar
ae2e4000-ae2f5000 r-xs 00000000 03:45 84931639
/home/thomas/eclipse-extensions/tptp/eclipse/plugins/org.ecl ipse.hyades.test.tools.core_4.1.0/tools-core.jar
ae2f5000-ae3c0000 r-xs 00000000 03:45 84719204
/home/thomas/eclipse-extensions/tptp/eclipse/plugins/org.ecl ipse.hyades.ui_4.1.0.jar
ae3c0000-ae400000 r-xs 00000000 03:45 93886892
/home/thomas/eclipse-3.1/configuration/org.eclipse.osgi/bund les/79/1/.cp/autogui.jar
ae400000-ae43d000 r-xs 00000000 03:45 84932831
/home/thomas/eclipse-extensions/tptp/eclipse/plugins/org.ecl ipse.tptp.test.auto.gui_4.1.0.jar
ae43d000-ae478000 r-xs 00000000 03:45 27684327
/home/thomas/eclipse-extensions/tptp/eclipse/plugins/org.ecl ipse.hyades.execution_4.1.0/hexl.jar
ae478000-ae495000 r-xs 00000000 03:45 27684326
/home/thomas/eclipse-extensions/tptp/eclipse/plugins/org.ecl ipse.hyades.execution_4.1.0/hexcore.jar
ae495000-ae498000 r-xs 00000000 03:45 44129217
/home/thomas/eclipse-extensions/jboss/eclipse/plugins/org.jb oss.ide.eclipse.jdt.ws.core_1.5.0.M2/org-jboss-ide-eclipse-j dt-ws-core.jar
ae498000-ae49a000 r-xs 00000000 03:45 44106009
/home/thomas/eclipse-extensions/jboss/eclipse/plugins/org.jb oss.ide.eclipse.jdt.j2ee.core_1.5.0.M2/org-jboss-ide-eclipse -jdt-j2ee-core.jar
ae49a000-ae514000 r-xs 00000000 03:45 712092
/home/thomas/eclipse-extensions/jboss/eclipse/plugins/org.jb oss.ide.eclipse.jdt.j2ee.jsp.core_1.5.0.M2/org-jboss-ide-ecl ipse-jdt-j2ee-jsp-core.jar
ae514000-ae52a000 r-xs 00000000 03:45 59145675
/home/thomas/eclipse-extensions/jboss/eclipse/plugins/org.jb oss.ide.eclipse.jdt.j2ee.jsp.ui_1.5.0.M2/org-jboss-ide-eclip se-jdt-j2ee-jsp-ui.jar
ae52a000-ae52f000 r-xs 00000000 03:45 34705955
/home/thomas/eclipse-extensions/jboss/eclipse/plugins/org.jb oss.ide.eclipse.deployer.core_1.5.0.M2/org-jboss-ide-eclipse -deployer-core.jar
ae52f000-ae539000 r-xs 00000000 03:45 44106004
/home/thomas/eclipse-extensions/jboss/eclipse/plugins/org.jb oss.ide.eclipse.deployer.ui_1.5.0.M2/org-jboss-ide-eclipse-d eployer-ui.jar
ae53d000-ae549000 r-xp 00000000 03:46 218753904
/usr/X11R6/lib/X11/fonts/TTF/VeraMoBd.ttf
ae549000-ae54e000 r-xs 00000000 03:45 34897957
/home/thomas/eclipse-extensions/jboss/eclipse/plugins/org.jb oss.ide.eclipse.jdt.core_1.5.0.M2/org-jboss-ide-eclipse-jdt- core.jar
ae54e000-ae550000 r-xs 00000000 03:45 75717769
/home/thomas/eclipse-extensions/jboss/eclipse/plugins/org.jb oss.ide.eclipse.jdt.test.core_1.5.0.M2/org-jboss-ide-eclipse -jdt-test-core.jar
ae550000-ae557000 r-xs 00000000 03:45 18951702
/home/thomas/eclipse-extensions/orm/eclipse/plugins/org.ecli pse.jsr220orm.core_0.9.4/xmlbeans/typelib/ejb3-persistence-x ml.jar
ae557000-ae7c0000 r-xs 00000000 03:45 29949803
/home/thomas/eclipse-extensions/orm/eclipse/plugins/org.ecli pse.jsr220orm.core_0.9.4/xmlbeans/lib/xbean.jar
ae7c0000-ae7c7000 r-xs 00000000 03:45 29949802
/home/thomas/eclipse-extensions/orm/eclipse/plugins/org.ecli pse.jsr220orm.core_0.9.4/xmlbeans/lib/jsr173_api.jar
ae7c7000-ae7d3000 r-xs 00000000 03:45 2313765
/home/thomas/eclipse-extensions/orm/eclipse/plugins/org.ecli pse.jsr220orm.core_0.9.4/jsr220orm.jar
ae7d3000-ae7fd000 r-xs 00000000 03:45 77805937
/home/thomas/eclipse-extensions/orm/eclipse/plugins/org.ecli pse.jsr220orm.generic_0.9.4/generic-ejb3.jar
ae7fd000-ae807000 r-xs 00000000 03:45 89204708
/home/thomas/eclipse-extensions/orm/eclipse/plugins/org.ecli pse.jsr220orm.generic_0.9.4/lib/ejb3-persistence.jar
ae807000-aea5e000 r-xs 00000000 03:45 95154668
/home/thomas/eclipse-extensions/tptp/eclipse/plugins/org.ecl ipse.tptp.platform.models_4.1.0/tptp-models.jar
aea5e000-aeab1000 r-xs 00000000 03:45 59672982
/home/thomas/eclipse-extensions/tptp/eclipse/plugins/org.ecl ipse.hyades.statistical.ui_4.1.0/statistical_ui.jar
aeab1000-aeb26000 r-xs 00000000 03:45 67987531
/home/thomas/eclipse-3.1/plugins/org.eclipse.pde.core_3.1.0. jar
aeb26000-aeb75000 r-xs 00000000 03:45 42087238
/home/thomas/eclipse-3.1/plugins/org.eclipse.jdt.junit_3.1.0 /junitsupport.jar
aeb75000-aeb78000 r-xs 00000000 03:45 29770672
/home/thomas/eclipse-extensions/jboss/eclipse/plugins/org.jb oss.ide.eclipse.core_1.5.0.M2/org-jboss-ide-eclipse-core.jar
aeb78000-aeb81000 r-xs 00000000 03:45 109787499
/home/thomas/eclipse-extensions/jboss/eclipse/plugins/org.jb oss.ide.eclipse.launcher.core_1.5.0.M2/org-jboss-ide-eclipse -launcher-core.jar
aeb81000-aeb84000 ---p aeb81000 00:00 0
aeb84000-aec01000 rwxp aeb84000 00:00 0
aec01000-aec04000 ---p aec01000 00:00 0
aec04000-aec81000 rwxp aec04000 00:00 0
aec81000-aec83000 r-xs 00000000 03:45 84479824
/home/thomas/eclipse-extensions/jboss/eclipse/plugins/org.jb oss.ide.eclipse.ejb3.wizards.core_1.0.0.beta3/ejb3-wizards-c ore.jar
aec83000-aecf0000 r-xs 00000000 03:45 8703979
/home/thomas/eclipse-extensions/jboss/eclipse/plugins/org.jb oss.ide.eclipse.jdt.aop.core_1.1.0.beta3/xsdlib.jar
aecf0000-aed2c000 r-xs 00000000 03:45 8703958
/home/thomas/eclipse-extensions/jboss/eclipse/plugins/org.jb oss.ide.eclipse.jdt.aop.core_1.1.0.beta3/bsh-1.3.0.jar
aed2c000-aed6c000 r-xs 00000000 03:45 8703968
/home/thomas/eclipse-extensions/jboss/eclipse/plugins/org.jb oss.ide.eclipse.jdt.aop.core_1.1.0.beta3/jboss-aspect-librar y.jar
aed6c000-aed8a000 r-xs 00000000 03:45 8703970
/home/thomas/eclipse-extensions/jboss/eclipse/plugins/org.jb oss.ide.eclipse.jdt.aop.core_1.1.0.beta3/junit.jar
aed8a000-aedee000 r-xs 00000000 03:45 8703960
/home/thomas/eclipse-extensions/jboss/eclipse/plugins/org.jb oss.ide.eclipse.jdt.aop.core_1.1.0.beta3/javassist.jar
aedee000-aee47000 r-xs 00000000 03:45 8703978
/home/thomas/eclipse-extensions/jboss/eclipse/plugins/org.jb oss.ide.eclipse.jdt.aop.core_1.1.0.beta3/trove.jar
aee47000-aee71000 r-xs 00000000 03:45 8703959
/home/thomas/eclipse-extensions/jboss/eclipse/plugins/org.jb oss.ide.eclipse.jdt.aop.core_1.1.0.beta3/concurrent.jar
aee71000-aee84000 r-xs 00000000 03:45 8703976
/home/thomas/eclipse-extensions/jboss/eclipse/plugins/org.jb oss.ide.eclipse.jdt.aop.core_1.1.0.beta3/qdox.jar
aee84000-aef25000 r-xs 00000000 03:45 8703969
/home/thomas/eclipse-extensions/jboss/eclipse/plugins/org.jb oss.ide.eclipse.jdt.aop.core_1.1.0.beta3/jboss-common.jar
aef25000-aefc1000 r-xs 00000000 03:45 8703966
/home/thomas/eclipse-extensions/jboss/eclipse/plugins/org.jb oss.ide.eclipse.jdt.aop.core_1.1.0.beta3/jboss-aop.jar
aefc1000-af05a000 r-xs 00000000 03:45 8703972
/home/thomas/eclipse-extensions/jboss/eclipse/plugins/org.jb oss.ide.eclipse.jdt.aop.core_1.1.0.beta3/org-jboss-ide-eclip se-jdt-aop-core.jar
af05a000-af062000 r-xs 00000000 03:45 8703977
/home/thomas/eclipse-extensions/jboss/eclipse/plugins/org.jb oss.ide.eclipse.jdt.aop.core_1.1.0.beta3/relaxngDatatype.jar
af062000-af1fb000 r-xs 00000000 03:45 8703964
/home/thomas/eclipse-extensions/jboss/eclipse/plugins/org.jb oss.ide.eclipse.jdt.aop.core_1.1.0.beta3/jaxb-libs.jar
af1fb000-af247000 r-xs 00000000 03:45 8703963
/home/thomas/eclipse-extensions/jboss/eclipse/plugins/org.jb oss.ide.eclipse.jdt.aop.core_1.1.0.beta3/jaxb-impl.jar
af247000-af249000 r-xs 00000000 03:45 8703961
/home/thomas/eclipse-extensions/jboss/eclipse/plugins/org.jb oss.ide.eclipse.jdt.aop.core_1.1.0.beta3/jax-qname.jar
af249000-af24b000 r-xs 00000000 03:45 8703971
/home/thomas/eclipse-extensions/jboss/eclipse/plugins/org.jb oss.ide.eclipse.jdt.aop.core_1.1.0.beta3/namespace.jar
af24b000-af25e000 r-xs 00000000 03:45 8703962
/home/thomas/eclipse-extensions/jboss/eclipse/plugins/org.jb oss.ide.eclipse.jdt.aop.core_1.1.0.beta3/jaxb-api.jar
af25e000-af261000 ---p af25e000 00:00 0
af261000-af2de000 rwxp af261000 00:00 0
af2de000-af30f000 r-xs 00000000 03:45 67527076
/home/thomas/eclipse-3.1/plugins/org.eclipse.jdt.launching_3 .1.0.jar
af30f000-af384000 r-xs 00000000 03:45 67526682
/home/thomas/eclipse-3.1/plugins/org.eclipse.team.cvs.core_3 .1.0.jar
af384000-af387000 ---p af384000 00:00 0
af387000-af404000 rwxp af387000 00:00 0
af404000-af43e000 r-xs 00000000 03:45 111105652
/home/thomas/eclipse-extensions/wtp/eclipse/plugins/org.ecli pse.wst.server.core_0.7.0.jar
af43e000-af452000 r-xs 00000000 03:45 111100739
/home/thomas/eclipse-extensions/wtp/eclipse/plugins/org.ecli pse.jst.server.tomcat.ui_0.7.0.jar
af452000-af548000 r-xs 00000000 03:45 67929798
/home/thomas/eclipse-3.1/plugins/org.eclipse.ant.ui_3.1.0.ja r
af548000-af620000 r-xs 00000000 03:45 84719202
/home/thomas/eclipse-extensions/tptp/eclipse/plugins/org.ecl ipse.hyades.trace.ui_4.1.0.jar
af620000-af65a000 r-xs 00000000 03:45 67527085
/home/thomas/eclipse-3.1/plugins/org.eclipse.debug.core_3.1. 0.jar
af65a000-af762000 r-xs 00000000 03:45 67526684
/home/thomas/eclipse-3.1/plugins/org.eclipse.jdt.debug.ui_3. 1.0.jar
af762000-af780000 r-xs 00000000 03:45 67526676
/home/thomas/eclipse-3.1/plugins/org.eclipse.ui.externaltool s_3.1.0.jar
af780000-af7fd000 r-xs 00000000 03:45 111100750
/home/thomas/eclipse-extensions/wtp/eclipse/plugins/org.ecli pse.jst.ws.consumption.ui_0.7.1.jar
af7fd000-af7fe000 r-xs 00000000 03:45 95861744
/home/thomas/eclipse-extensions/ve/eclipse/plugins/org.eclip se.ve.java.core_1.1.0.1/common.jar
af7fe000-af8bf000 r-xs 00000000 03:45 95861742
/home/thomas/eclipse-extensions/ve/eclipse/plugins/org.eclip se.ve.java.core_1.1.0.1/codegen.jar
af8bf000-af8e1000 r-xs 00000000 03:45 84809304
/home/thomas/eclipse-extensions/emf-gef/eclipse/plugins/org. eclipse.emf.common_2.1.0.jar
af8e1000-af97e000 r-xs 00000000 03:45 84811203
/home/thomas/eclipse-extensions/emf-gef/eclipse/plugins/org. eclipse.emf.ecore_2.1.0.jar
af97e000-af993000 r-xs 00000000 03:45 71329561
/home/thomas/eclipse-extensions/ve/eclipse/plugins/org.eclip se.jem.util_1.1.0.1/util.jar
af993000-afa2e000 r-xs 00000000 03:45 95861743
/home/thomas/eclipse-extensions/ve/eclipse/plugins/org.eclip se.ve.java.core_1.1.0.1/core.jar
afa2e000-afab9000 r-xs 00000000 03:45 111105653
/home/thomas/eclipse-extensions/wtp/eclipse/plugins/org.ecli pse.wst.server.ui_0.7.0.jar
afab9000-afb69000 r-xs 00000000 03:45 111094457
/home/thomas/eclipse-extensions/wtp/eclipse/plugins/org.ecli pse.jst.j2ee.ui_0.7.0.jar
afb69000-afb7f000 r-xs 00000000 03:45 67526686
/home/thomas/eclipse-3.1/plugins/org.eclipse.core.filebuffer s_3.1.0.jar
afb7f000-afcc5000 r-xs 00000000 03:45 67527090
/home/thomas/eclipse-3.1/plugins/org.eclipse.debug.ui_3.1.0. jar
afcc5000-afd23000 r-xs 00000000 03:45 67527089
/home/thomas/eclipse-3.1/plugins/org.eclipse.search_3.1.0.ja r
afd23000-afd8d000 r-xs 00000000 03:45 67527072
/home/thomas/eclipse-3.1/plugins/org.eclipse.ui.workbench.te xteditor_3.1.0.jar
afd8d000-afdba000 r-xs 00000000 03:45 67929797
/home/thomas/eclipse-3.1/plugins/org.eclipse.text_3.1.0.jar
afdba000-afe21000 r-xs 00000000 03:45 67987503
/home/thomas/eclipse-3.1/plugins/org.eclipse.ui.editors_3.1. 0.jar
afe21000-afec5000 r-xs 00000000 03:45 67929788
/home/thomas/eclipse-3.1/plugins/org.eclipse.jface.text_3.1. 0.jar
afec5000-afec8000 ---p afec5000 00:00 0
afec8000-aff45000 rwxp afec8000 00:00 0
aff45000-b02aa000 r-xs 00000000 03:45 67987540
/home/thomas/eclipse-3.1/plugins/org.eclipse.jdt.core_3.1.0. jar
b02aa000-b03d0000 r-xs 00000000 03:45 67527079
/home/thomas/eclipse-3.1/plugins/org.eclipse.team.cvs.ui_3.1 .0.jar
b03d0000-b046e000 r-xs 00000000 03:45 67527074
/home/thomas/eclipse-3.1/plugins/org.eclipse.team.ui_3.1.0.j ar
b046e000-b06fa000 r-xs 00000000 03:45 67527080
/home/thomas/eclipse-3.1/plugins/org.eclipse.pde.ui_3.1.0.ja r
b06fa000-b071b000 r-xs 00000000 03:45 67526677
/home/thomas/eclipse-3.1/plugins/org.eclipse.ui.console_3.1. 0.jar
b071b000-b072b000 r-xs 00000000 03:45 67527086
/home/thomas/eclipse-3.1/plugins/org.eclipse.ui.views_3.1.0. jar
b072b000-b074e000 r-xs 00000000 03:45 67987536
/home/thomas/eclipse-3.1/plugins/org.eclipse.pde.runtime_3.1 .0.jar
b074e000-b0de4000 r-xs 00000000 03:45 67526661
/home/thomas/eclipse-3.1/plugins/org.eclipse.jdt.ui_3.1.0.ja r
b0de4000-b0de6000 r-xp 00000000 03:46 235336011
/usr/lib/pango/1.4.0/modules/pango-basic-fc.so
b0de6000-b0de7000 rwxp 00001000 03:46 235336011
b0de7000-b0df8000 r-xp 00000000 03:46 218753892
/usr/X11R6/lib/X11/fonts/TTF/Vera.ttf
b0df8000-b0e58000 rwxs 00000000 00:06 1409032 /SYSV00000000 (deleted)
b0e58000-b0e8e000 r-xs 00000000 03:45 67987509
/home/thomas/eclipse-3.1/plugins/org.eclipse.team.core_3.1.0 .jar
b0e8e000-b0e91000 ---p b0e8e000 00:00 0
b0e91000-b0f0e000 rwxp b0e91000 00:00 0
b0f0e000-b0f15000 r-xs 00000000 03:45 67987544
/home/thomas/eclipse-3.1/plugins/org.eclipse.core.resources. linux_3.1.0.jar
b0f15000-b0f31000 r-xs 00000000 03:45 67527084
/home/thomas/eclipse-3.1/plugins/org.eclipse.core.resources. compatibility_3.1.0.jar
b0f31000-b0fc7000 r-xs 00000000 03:45 67987505
/home/thomas/eclipse-3.1/plugins/org.eclipse.core.resources_ 3.1.0.jar
b0fc7000-b0ff7000 rwxs 00000000 00:06 1343494 /SYSV00000000 (deleted)
b0ff7000-b1004000 r-xs 00000000 03:45 67987502
/home/thomas/eclipse-3.1/plugins/org.eclipse.core.expression s_3.1.0.jar
b1004000-b1015000 r-xs 00000000 03:45 67526679
/home/thomas/eclipse-3.1/plugins/org.eclipse.core.commands_3 .1.0.jar
b1015000-b103b000 r-xp 00000000 03:45 18951706
/home/thomas/eclipse-3.1/configuration/org.eclipse.osgi/bund les/208/1/.cp/libswt-gtk-3138.so
b103b000-b103d000 rwxp 00025000 03:45 18951706
b103d000-b103e000 rwxp b103d000 00:00 0
b103e000-b104e000 r-xp 00000000 03:46 50656994 /usr/lib/libz.so.1.2.2
b104e000-b104f000 rwxp 0000f000 03:46 50656994 /usr/lib/libz.so.1.2.2
b104f000-b106d000 r-xp 00000000 03:46 50406239 /usr/lib/libexpat.so.0.5.0
b106d000-b106f000 rwxp 0001e000 03:46 50406239 /usr/lib/libexpat.so.0.5.0
b106f000-b1094000 r-xp 00000000 03:46 50332256
/usr/lib/libpangoft2-1.0.so.0.800.1
b1094000-b1095000 rwxp 00025000 03:46 50332256
b1095000-b109c000 r-xp 00000000 03:46 84847783
/usr/X11R6/lib/libXrender.so.1.2.2
b109c000-b109d000 rwxp 00006000 03:46 84847783
b109d000-b10a5000 r-xp 00000000 03:46 84847781
/usr/X11R6/lib/libXcursor.so.1.0.2
b10a5000-b10a6000 rwxp 00007000 03:46 84847781
b10a6000-b10aa000 r-xp 00000000 03:46 83961868
/usr/X11R6/lib/libXfixes.so.3.0
b10aa000-b10ab000 rwxp 00003000 03:46 83961868
b10ab000-b10ce000 r-xp 00000000 03:46 84847784
/usr/X11R6/lib/libfontconfig.so.1.0.4
b10ce000-b10d1000 rwxp 00022000 03:46 84847784
b10d1000-b10d2000 rwxp b10d1000 00:00 0
b10d2000-b1135000 r-xp 00000000 03:46 51716346
/usr/lib/libfreetype.so.6.3.7
b1135000-b113c000 rwxp 00063000 03:46 51716346
b113c000-b114d000 r-xp 00000000 03:46 84847789
/usr/X11R6/lib/libXft.so.2.1.2
b114d000-b114e000 rwxp 00011000 03:46 84847789
b114e000-b1150000 r-xp 00000000 03:46 84847793
/usr/X11R6/lib/libXinerama.so.1.0
b1150000-b1151000 rwxp 00001000 03:46 84847793
b1151000-b1158000 r-xp 00000000 03:46 84847786 /usr/X11R6/lib/libXi.so.6.0
b1158000-b1159000 rwxp 00006000 03:46 84847786 /usr/X11R6/lib/libXi.so.6.0
b1159000-b115b000 r-xp 00000000 03:46 83907946
/usr/X11R6/lib/libXrandr.so.2.0
b115b000-b115c000 rwxp 00002000 03:46 83907946
b115c000-b1169000 r-xp 00000000 03:46 83907951
/usr/X11R6/lib/libXext.so.6.4
b1169000-b116a000 rwxp 0000c000 03:46 83907951
b116a000-b11e9000 r-xp 00000000 03:46 50449480
/usr/lib/libglib-2.0.so.0.600.5
b11e9000-b11ea000 rwxp 0007e000 03:46 50449480
b11ea000-b11ed000 r-xp 00000000 03:46 50449483
/usr/lib/libgmodule-2.0.so.0.600.5
b11ed000-b11ee000 rwxp 00002000 03:46 50449483
b11ee000-b1220000 r-xp 00000000 03:46 50449482
/usr/lib/libgobject-2.0.so.0.600.5
b1220000-b1221000 rwxp 00032000 03:46 50449482
b1221000-b1238000 r-xp 00000000 03:46 51224731
/usr/lib/libatk-1.0.so.0.901.0
b1238000-b123a000 rwxp 00016000 03:46 51224731
b123a000-b126e000 r-xp 00000000 03:46 50332258
/usr/lib/libpango-1.0.so.0.800.1
b126e000-b1273000 rwxp 00033000 03:46 50332258
b1273000-b127d000 r-xp 00000000 03:46 50332260
/usr/lib/libpangox-1.0.so.0.800.1
b127d000-b127e000 rwxp 00009000 03:46 50332260
b127e000-b1284000 r-xp 00000000 03:46 50332255
/usr/lib/libpangoxft-1.0.so.0.800.1
b1284000-b1285000 rwxp 00005000 03:46 50332255
b1285000-b134b000 r-xp 00000000 03:46 84847787
/usr/X11R6/lib/libX11.so.6.2
b134b000-b134f000 rwxp 000c6000 03:46 84847787
b134f000-b13c8000 r-xp 00000000 03:46 50348017
/usr/lib/libgdk-x11-2.0.so.0.600.7
b13c8000-b13cb000 rwxp 00079000 03:46 50348017
b13cb000-b13df000 r-xp 00000000 03:46 50449499
/usr/lib/libgdk_pixbuf-2.0.so.0.600.7
b13df000-b13e0000 rwxp 00014000 03:46 50449499
b13e0000-b13e4000 r-xp 00000000 03:46 83907949
/usr/X11R6/lib/libXtst.so.6.1
b13e4000-b13e5000 rwxp 00004000 03:46 83907949
b13e5000-b13e8000 r-xp 00000000 03:46 50449481
/usr/lib/libgthread-2.0.so.0.600.5
b13e8000-b13e9000 rwxp 00003000 03:46 50449481
b13e9000-b16b1000 r-xp 00000000 03:46 50449496
/usr/lib/libgtk-x11-2.0.so.0.600.7
b16b1000-b16b9000 rwxp 002c7000 03:46 50449496
b16b9000-b16bc000 rwxp b16b9000 00:00 0
b16bf000-b16d0000 r-xs 00000000 03:45 67811726
/home/thomas/eclipse-3.1/plugins/org.eclipse.help_3.1.0.jar
b16d0000-b16d3000 rwxs 00000000 00:06 1376263 /SYSV00000000 (deleted)
b16d3000-b16d5000 r-xp 00000000 03:45 71347658
/home/thomas/eclipse-3.1/configuration/org.eclipse.osgi/bund les/221/1/.cp/os/linux/x86/libcore_3_1_0.so
b16d5000-b16d6000 rwxp 00001000 03:45 71347658
b16d6000-b16d7000 r-xp 00000000 03:46 67222257 /usr/lib/gconv/ISO8859-1.so
b16d7000-b16d8000 ---p 00001000 03:46 67222257 /usr/lib/gconv/ISO8859-1.so
b16d8000-b16da000 rwxp 00001000 03:46 67222257 /usr/lib/gconv/ISO8859-1.so
b16da000-b16dc000 r-xp 00000000 03:46 67339071
/usr/X11R6/lib/X11/locale/lib/common/xlcDef.so.2
b16dc000-b16dd000 rwxp 00001000 03:46 67339071
b16dd000-b171f000 r-xp 00000000 03:45 18951705
/home/thomas/eclipse-3.1/configuration/org.eclipse.osgi/bund les/208/1/.cp/libswt-pi-gtk-3138.so
b171f000-b1721000 rwxp 00042000 03:45 18951705
b1721000-b173f000 r-xs 00000000 03:45 67526680
/home/thomas/eclipse-3.1/plugins/org.eclipse.ui_3.1.0.jar
b173f000-b1890000 r-xs 00000000 03:45 67987532
/home/thomas/eclipse-3.1/plugins/org.eclipse.swt.gtk.linux.x 86_3.1.0.jar
b1890000-b1891000 r-xs 00000000 03:45 67526685
/home/thomas/eclipse-3.1/plugins/org.eclipse.swt_3.1.0.jar
b1891000-b1934000 r-xs 00000000 03:45 67929784
/home/thomas/eclipse-3.1/plugins/org.eclipse.jface_3.1.0.jar
b1934000-b1935000 r-xs 00000000 03:45 34701436
/home/thomas/eclipse-3.1/plugins/org.eclipse.ui.workbench.co mpatibility_3.1.0/compatibility.jar
b1935000-b1bf1000 r-xs 00000000 03:45 67987537
/home/thomas/eclipse-3.1/plugins/org.eclipse.ui.workbench_3. 1.0.jar
b1bf1000-b1d69000 r-xs 00000000 03:45 67527091
/home/thomas/eclipse-3.1/plugins/org.eclipse.ui.ide_3.1.0.ja r
b1d69000-b1d80000 r-xs 00000000 03:45 67929789
/home/thomas/eclipse-3.1/plugins/org.eclipse.update.configur ator_3.1.0.jar
b1d80000-b1d95000 r-xs 00000000 03:45 67526687
/home/thomas/eclipse-3.1/plugins/org.eclipse.core.runtime.co mpatibility_3.1.0.jar
b1d95000-b1e04000 r-xs 00000000 03:45 67987543
/home/thomas/eclipse-3.1/plugins/org.eclipse.core.runtime_3. 1.0.jar
b1e04000-b1e07000 ---p b1e04000 00:00 0
b1e07000-b1e84000 rwxp b1e07000 00:00 0
b1e84000-b1e87000 ---p b1e84000 00:00 0
b1e87000-b1f04000 rwxp b1e87000 00:00 0
b1f04000-b1f07000 ---p b1f04000 00:00 0
b1f07000-b1f84000 rwxp b1f07000 00:00 0
b1f84000-b1f8a000 r-xp 00000000 03:46 33948943
/usr/lib/jdk1.5.0_04/jre/lib/i386/libnio.so
b1f8a000-b1f8b000 rwxp 00005000 03:46 33948943
b1f8b000-b1f9f000 r-xp 00000000 03:46 33948942
/usr/lib/jdk1.5.0_04/jre/lib/i386/libnet.so
b1f9f000-b1fa0000 rwxp 00013000 03:46 33948942
b1fa0000-b2056000 r-xs 00000000 03:45 67929790
/home/thomas/eclipse-3.1/plugins/org.eclipse.osgi_3.1.0.jar
b2056000-b2059000 ---p b2056000 00:00 0
b2059000-b20d6000 rwxp b2059000 00:00 0
b20d6000-b20de000 r-xs 00000000 03:45 42359800
/home/thomas/eclipse-3.1/startup.jar
b20de000-b21a2000 r-xs 00000000 03:46 17143570
/usr/lib/jdk1.5.0_04/jre/lib/ext/localedata.jar
b21a2000-b21c8000 r-xs 00000000 03:46 17143569
/usr/lib/jdk1.5.0_04/jre/lib/ext/sunjce_provider.jar
b21c8000-b21f3000 r-xs 00000000 03:46 17143533
/usr/lib/jdk1.5.0_04/jre/lib/ext/sunpkcs11.jar
b21f3000-b21f5000 r-xs 00000000 03:46 17143532
/usr/lib/jdk1.5.0_04/jre/lib/ext/dnsns.jar
b21f5000-b21fd000 r-xs 00000000 03:45 42359800
b21fd000-b21fe000 ---p b21fd000 00:00 0
b21fe000-b227d000 rwxp b21fe000 00:00 0
b227d000-b2280000 ---p b227d000 00:00 0
b2280000-b22fd000 rwxp b2280000 00:00 0
b22fd000-b2300000 ---p b22fd000 00:00 0
b2300000-b237d000 rwxp b2300000 00:00 0
b237d000-b2380000 ---p b237d000 00:00 0
b2380000-b23fd000 rwxp b2380000 00:00 0
b23fd000-b2400000 ---p b23fd000 00:00 0
b2400000-b247d000 rwxp b2400000 00:00 0
b247d000-b2480000 ---p b247d000 00:00 0
b2480000-b24fd000 rwxp b2480000 00:00 0
b24fd000-b24fe000 ---p b24fd000 00:00 0
b24fe000-b2594000 rwxp b24fe000 00:00 0
b2594000-b25aa000 rwxp b2594000 00:00 0
b25aa000-b25bd000 rwxp b25aa000 00:00 0
b25bd000-b2621000 rwxp b25bd000 00:00 0
b2621000-b2623000 rwxp b2621000 00:00 0
b2623000-b262a000 rwxp b2623000 00:00 0
b262a000-b263e000 rwxp b262a000 00:00 0
b263e000-b26a1000 rwxp b263e000 00:00 0
b26a1000-b26ac000 rwxp b26a1000 00:00 0
b26ac000-b26c1000 rwxp b26ac000 00:00 0
b26c1000-b26d6000 rwxp b26c1000 00:00 0
b26d6000-b274c000 rwxp b26d6000 00:00 0
b274c000-b29c4000 rwxp b274c000 00:00 0
b29c4000-b474c000 rwxp b29c4000 00:00 0
b474c000-b4f87000 r-xs 00000000 03:46 8640173
/usr/lib/jdk1.5.0_04/jre/lib/charsets.jar
b4f87000-b4f9b000 r-xs 00000000 03:46 8640187
/usr/lib/jdk1.5.0_04/jre/lib/jce.jar
b4f9b000-b5022000 r-xs 00000000 03:46 8640163
/usr/lib/jdk1.5.0_04/jre/lib/jsse.jar
b5022000-b508b000 rwxp b5022000 00:00 0
b508b000-b766b000 r-xs 00000000 03:46 8640179
/usr/lib/jdk1.5.0_04/jre/lib/rt.jar
b766b000-b767e000 r-xp 00000000 03:46 33948955
/usr/lib/jdk1.5.0_04/jre/lib/i386/libzip.so
b767e000-b7680000 rwxp 00012000 03:46 33948955
b7680000-b76a1000 r-xp 00000000 03:46 33948962
/usr/lib/jdk1.5.0_04/jre/lib/i386/libjava.so
b76a1000-b76a3000 rwxp 00020000 03:46 33948962
b76a3000-b76ab000 r-x
Re: problems with swt browser - mozilla on linux [message #461128 is a reply to message #461027] Fri, 16 September 2005 12:34 Go to previous messageGo to next message
Hi Andrzej,
This looks like https://bugs.eclipse.org/bugs/show_bug.cgi?id=108331 , which
was fixed recently in the 3.2 stream and will also be in the 3.1.1 release.
So if you can migrate to one of these versions then this should work for
you. I cannot think of any other workarounds to suggest.
Grant
"Andrzej Roszkowski" <thomas@interia.pl> wrote in message
news:dgaasa$1sd$1@news.eclipse.org...
> Hi!
id=4242]
> Registers:
> C=native code)
annel+0x1cb
> j
dow$IExceptionHandler;Lorg/eclipse/swt/widgets/Display;)V+9
> j
gets/Display;Lorg/eclipse/ui/application/WorkbenchAdvisor;)I +11
> j
play;Lorg/eclipse/ui/application/WorkbenchAdvisor;)I+2
> j
/Object;+98
> j
> j
/lang/Object;+170
> j
> j
/lang/Object;[Ljava/lang/Object;)Ljava/lang/Object;+0
> j
> j
> j
lang/Object;+111
> j
/URL;)V+181
> C [java+0x17fe]
> j
> j
> j
> j
/Object;+98
> j
> j
/lang/Object;+170
> j
> j
> j
> j
> j
lang/Object;+111
> j
/URL;)V+181
> id=4252]
> id=4248]
id=4247]
> id=4246]
> id=4244]
> Other Threads:
> Heap
> 0x5acf0000)
> 0x69940000)
> 0x5d1e0000)
> 0x6ae40000)
> 0x6e140000)
> 0x6ed40000)
> Dynamic libraries:
..proxy_0.7.0/ipproxy.jar
..tools.core_4.1.0/java.runner.jar
..tools.core_4.1.0/manual.runner.jar
..tools.core_4.1.0/common.runner.jar
..core_4.1.0/test-core.jar
..core_4.1.0/hexrecr.jar
..core_4.1.0/hexteh.jar
..tools.core_4.1.0/tools-core.jar
..1.0.jar
ogui.jar
uto.gui_4.1.0.jar
jdt.ws.core_1.5.0.M2/org-jboss-ide-eclipse-jdt-ws-core.jar
jdt.j2ee.core_1.5.0.M2/org-jboss-ide-eclipse-jdt-j2ee-core.j ar
jdt.j2ee.jsp.core_1.5.0.M2/org-jboss-ide-eclipse-jdt-j2ee-js p-core.jar
jdt.j2ee.jsp.ui_1.5.0.M2/org-jboss-ide-eclipse-jdt-j2ee-jsp- ui.jar
deployer.core_1.5.0.M2/org-jboss-ide-eclipse-deployer-core.j ar
deployer.ui_1.5.0.M2/org-jboss-ide-eclipse-deployer-ui.jar
jdt.core_1.5.0.M2/org-jboss-ide-eclipse-jdt-core.jar
jdt.test.core_1.5.0.M2/org-jboss-ide-eclipse-jdt-test-core.j ar
re_0.9.4/xmlbeans/typelib/ejb3-persistence-xml.jar
r
launcher.core_1.5.0.M2/org-jboss-ide-eclipse-launcher-core.j ar
ejb3.wizards.core_1.0.0.beta3/ejb3-wizards-core.jar
jdt.aop.core_1.1.0.beta3/jboss-aspect-library.jar
jdt.aop.core_1.1.0.beta3/org-jboss-ide-eclipse-jdt-aop-core. jar
ore_0.7.0.jar
omcat.ui_0.7.0.jar
e.ui_4.1.0.jar
mption.ui_0.7.1.jar
1.1.0.1/common.jar
1.1.0.1/codegen.jar
on_2.1.0.jar
e_2.1.0.jar
0.1/util.jar
1.1.0.1/core.jar
i_0.7.0.jar
0.7.0.jar
ar
1.0.jar
bswt-gtk-3138.so
bswt-gtk-3138.so
Re: problems with swt browser - mozilla on linux [message #461157 is a reply to message #461128] Sun, 18 September 2005 10:11 Go to previous message
Grant Gayed napisał(a):
> Hi Andrzej,
> Grant
Thank You!
Wil try to migrate to 3.1.1 stream ...
Previous Topic:lightweightsystem initialization failing
Next Topic:wizard problem--please help
Current Time: Thu Jul 24 22:09:14 EDT 2025
Powered by FUDForum. Page generated in 0.05436 seconds
