Home » Eclipse Projects » Standard Widget Toolkit (SWT) » How do I implement this dialog behavior?
How do I implement this dialog behavior? [message #461018] Wed, 14 September 2005 14:29 Go to next message
Originally posted by: gilbert.pilz.sbc-guesstherest.net
I have a dialog that has two text fields (URL and user name) and two
buttons (Connect and Cancel). I want to implement the following behavior:
1.) If the user tries to press Connect and either of the two text fields
are empty the dialog automatically refocuses on the empty text field.
2.) If the user presses <enter> while the focus is on either of the text
fields the dialog behaves as if the Connect were pressed (including the
validation performed in (1).
I've already implemented (1) by using a FocusListener on the Connect
button. I figure I can do (2) by adding a KeyListener to the text fields
that watches for <enter> and does "the right thing". I'm worried that
this might cause some weird behavior if one of the text fields is empty.
I'm also wondering if there is some more elegant way of implementing
this. Also, is there some way of visually cueing the user that the
Connect button will be pressed if they hit <enter>?
- g
Re: How do I implement this dialog behavior? [message #461125 is a reply to message #461018] Fri, 16 September 2005 12:01 Go to previous message
The correct way to do #2 is with Shell.setDefaultButton(yourConnectButton).
This will give you the desired Enter behaviour with no work required on your
end, and a visual cue on the Connect button as well.
Grant
"Gilbert Pilz" <gilbert.pilz@sbc-guesstherest.net> wrote in message
news:dg9q4m$b59$1@news.eclipse.org...
> - g
Previous Topic:Tree: "Good Practice" when base domain doesnŽt represent Tree structure?
Next Topic:Image size cannot be changed after first setImage in SWT Table using Win32
Current Time: Sat Jul 26 04:37:18 EDT 2025
Powered by FUDForum. Page generated in 0.05617 seconds
