Problem with DefaultUndoManager in Eclipse 3.1 [message #460925] |
Sun, 11 September 2005 16:05  |
Originally posted by: john.butt.freeuk.com
With Eclipse 3.1 the following line of code running in a standalone SWT
application on linux:
IUndoManager undoManager = new DefaultUndoManager(1);
Produces the exception:
Exception in thread "main" java.lang.NoClassDefFoundError:
org/eclipse/core/commands/ExecutionException
Any idea why this should be and how to fix it?
John B.
Re: Problem with DefaultUndoManager in Eclipse 3.1 [message #460983 is a reply to message #460935] |
Tue, 13 September 2005 16:04  |
Alex Blewitt wrote:
> It looks like a simple classpath issue; it's looking for code in the org.eclipse.core plugin, and you haven't got it defined on your classpath.
> Depending on how you're bundling this plugin, you might need to make changes in the Manifest.MF to ensure that the dependent Jar is on the right classpath. As an eclipse plugin, it would be handled with the Bundle-ClassPath: entry, which almost certainly won't work as a standalone application using it as a JAR.
When I run my application I have "VM arguments" set to:
-Djava.library.path=/myLibs
In directory myLibs I have the following shared libraries, but no jar files:
libswt-atk-gtk-3138.so
libswt-awt-gtk-3138.so
libswt-cairo-gtk-3138.so
libswt-gnome-gtk-3138.so
libswt-gtk-3138.so
libswt-mozilla-gtk-3138.so
libswt-pi-gtk-3138.so
Are there other libraries I'm missing or other VM arguments I should set
to run the application "standalone"? A simple example would be great
if you have one.
John B.
FUDForum. Page generated in 0.07682 seconds
