Home » Eclipse Projects » Standard Widget Toolkit (SWT) » Replace the Content of a Composite on the fly.
Replace the Content of a Composite on the fly. [message #460932] Mon, 12 September 2005 07:49 Go to next message
Originally posted by: wudongs.gmail.com
Hi, everyone:
I have the following problem:
I want to change the content (compositeContent) of a Composite
(compositeContainer) accoridng to the selection event of a combox.
I do the following thing:
1. check if compositeContent is null or displosed. if it's not null and
not disposed, disposed it.
2. create a new Compoiste with the parent of compositeContainer,
assigning that to the compositeContent.
3. layout() on the compositeContainer.
It works for the replacing of the content. but the content isn't
displayed only after i drag to change the size of the compositeContainer.
Why the step 3 doesn't work? i'm assumed it will re-layout the content
of compositeContainer and display the content.
Thank you.
Re: Replace the Content of a Composite on the fly. [message #460933 is a reply to message #460932] Mon, 12 September 2005 08:36 Go to previous messageGo to next message
redraw?
Re: Replace the Content of a Composite on the fly. [message #460938 is a reply to message #460932] Mon, 12 September 2005 10:18 Go to previous messageGo to next message
Originally posted by: sunil_kamath.nohotspammail.com
"Wudong Liu" <wudongs@gmail.com> wrote in message
news:dg3q0f$ncn$1@news.eclipse.org...
> Hi, everyone:
Code snippet?
Sunil
Re: Replace the Content of a Composite on the fly. [message #460952 is a reply to message #460938] Mon, 12 September 2005 22:11 Go to previous messageGo to next message
Sunil Kamath 写道:
>>Hi, everyone:
> Code snippet?
> Sunil
Here is the code snippet:
combo.addSelectionListener(new SelectionListener() {
public void widgetSelected(SelectionEvent e) {
String text = combo.getText();
SearchType type = SearchType.getSearchTypeByName(text);
if (searchControl!=null&&!searchControl.isDisposed()) {
searchControl.dispose();
//Create the New content control
//on the parent searchpane.
searchControl = type.createComposite(searchpane);
((Composite)searchControl).layout();
searchpane.layout();
parent.layout();
Re: Replace the Content of a Composite on the fly. [message #460972 is a reply to message #460952] Tue, 13 September 2005 09:30 Go to previous messageGo to next message
news:4326354B.5010601@gmail.com...
> Sunil Kamath д
Re: Replace the Content of a Composite on the fly. [message #461029 is a reply to message #460972] Wed, 14 September 2005 21:56 Go to previous messageGo to next message
Sunil Kamath 写道:
>>Sunil Kamath 写道:
> [snip]
>>>Code snippet?
>>>Sunil
>>parent.layout();
> Hmmm... looks fine. What layout manager are you using?
> Did you try debugging to see what is going on?
> Sunil
The searchpane compoiste uses FillLayout, and the parent composite uses
gridlayout. I assume nomatter what layout i use, it should work when
the layout() method is invoked.
I do debug, but found nothing.
Re: Replace the Content of a Composite on the fly. [message #461045 is a reply to message #461029] Thu, 15 September 2005 04:37 Go to previous message
Originally posted by: stefan.renz.web.de
May be this snippet will help you:
// determine top level shell
Composite comp = this;
while ( ! ((comp = comp.getParent()) instanceof Shell ))
Shell shell = (Shell)comp;
// fetch current size of shell
Point oldSize = shell.getSize();
// compute size of shell with the given current width (only the
height should change)
Point newSize = shell.computeSize(oldSize.x, SWT.DEFAULT, true);
// set the new size of the shell
shell.setSize(oldSize.x, newSize.y);
Wudong Liu wrote:
> Sunil Kamath ÐŽµÀ:
>>>Sunil Kamath ÐŽµÀ:
>> [snip]
>>>>Code snippet?
>>>>Sunil
>>>parent.layout();
>> Sunil
Previous Topic:Examples
Next Topic:Table.select() doesn't call SelectionListener
Current Time: Wed Jul 23 14:07:50 EDT 2025
Powered by FUDForum. Page generated in 0.04963 seconds
