InvocationTargetException [message #460716] |
Mon, 05 September 2005 04:00  |
Originally posted by: qminor.austin.rr.com
I am getting an error that I don't understand and I can't get around it. I
am trying to build an email application using JavaMail and I am receiving
the InvocationTargetException. What does this exception catch? Can anyone
help?
This is the error:
at org.eclipse.jface.operation.ModalContext.run(ModalContext.ja va:327)
at com.crypto.ui.menu_actions.SendAction.run(SendAction.java:41 )
at org.eclipse.jface.action.Action.runWithEvent(Action.java:996 )
at
org.eclipse.jface.action.ActionContributionItem.handleWidget Selection(ActionContributionItem.java:538)
at
org.eclipse.jface.action.ActionContributionItem.access$2(Act ionContributionItem.java:488)
at
org.eclipse.jface.action.ActionContributionItem$6.handleEven t(ActionContributionItem.java:441)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :66)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:843)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3080)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2713)
at org.eclipse.jface.window.Window.runEventLoop(Window.java:809 )
at org.eclipse.jface.window.Window.open(Window.java:787)
at com.crypto.ui.Crypto.run(Crypto.java:72)
at com.crypto.ui.Crypto.main(Crypto.java:216)
Caused by: org.eclipse.swt.SWTException: Invalid thread access
at org.eclipse.swt.SWT.error(SWT.java:2942)
at org.eclipse.swt.SWT.error(SWT.java:2865)
at org.eclipse.swt.SWT.error(SWT.java:2836)
at org.eclipse.swt.widgets.Widget.error(Widget.java:395)
at org.eclipse.swt.widgets.Widget.checkWidget(Widget.java:298)
at org.eclipse.swt.widgets.Text.getText(Text.java:851)
at com.crypto.ui.Crypto.getTxtTo(Crypto.java:205)
at com.crypto.ui.menu_actions.SendAction$1.run(SendAction.java: 55)
at
org.eclipse.jface.operation.ModalContext$ModalContextThread. run(ModalContext.java:113)
Here is the code:
public class SendAction extends Action {
private Properties props;
private String host = "smtp-server.austin.rr.com";
private Session session;
private String from = "qminor@austin.rr.com";
public SendAction() {
super("Send");
setImageDescriptor(ImageDescriptor.createFromFile(SendAction .class,
"/com/crypto/images/sendmsg.gif"));
setToolTipText("Send");
// TODO Auto-generated constructor stub
public void run() {
try {
ModalContext.run(new IRunnableWithProgress() {
public void run(IProgressMonitor progressMonitor) {
try {
progressMonitor.beginTask("Sending",
IProgressMonitor.UNKNOWN);
props = System.getProperties();
props.put("mail.smtp.host", host);
session = Session.getDefaultInstance(props, null);
MimeMessage message = new MimeMessage(session);
message.setFrom(new InternetAddress(from));
message.addRecipient(Message.RecipientType.TO,
new InternetAddress(Crypto.getApp().getTxtTo()));
message.setSubject(Crypto.getApp().getTxtSubject());
message.setText("This is a test");
Transport.send(message);
progressMonitor.done();
Crypto.getApp().refreshView();
} catch (AddressException e) {
e.printStackTrace();
} catch (MessagingException e) {
}, true, Crypto.getApp().slm.getProgressMonitor(),
Crypto.getApp().getShell()
.getDisplay());
} catch (InterruptedException e) {
} catch (InvocationTargetException e) {
} finally {
FUDForum. Page generated in 0.27956 seconds
