Re: Problem opening a file in the RCP application [message #460704 is a reply to message #460702] |
Thu, 28 December 2006 12:30   |
Thanks Charle!!
I tried including the following jars and runing the application.
1. org.eclipse.core.filesystem.win32.x86_1.0.0.v20060603.jar
2. org.eclipse.core.filesystem_1.0.0.v20060603.jar
But it still gives me the following error in the log file.
!SESSION 2006-12-28
22:52:35.855 -----------------------------------------------
eclipse.buildId=unknown
java.version=1.5.0_08
Framework arguments: -application
com.cisco.nm.cmp.client.ui.workbench.app -pdelaunch
Command-line arguments: -application
com.cisco.nm.cmp.client.ui.workbench.app -data C:\Eclipse Workspaces\View
try out/../runtime-EclipseApplication -dev file:C:/Eclipse Workspaces/View
try out/.metadata/.plugins/org.eclipse.pde.core/Application with Config
Archive/dev.properties -pdelaunch -os win32 -ws win32 -arch x86
!ENTRY org.eclipse.ui 4 4 2006-12-28 22:52:40.621
!MESSAGE Invalid Menu Extension (Path is invalid):
convertToWebModuleTypeAction
!ENTRY org.eclipse.ui 4 4 2006-12-28 22:52:40.668
org.eclipse.ui.edit.text.gotoLastEditPosition
!ENTRY org.eclipse.ui 4 4 2006-12-28 22:52:40.933
org.jboss.ide.eclipse.packaging.ui.actions.PackagingRunActio n
!ENTRY org.eclipse.ui 4 4 2006-12-28 22:52:41.136
org.jboss.ide.eclipse.xdoclet.run.ui.actions.XDocletRunActio n
!ENTRY org.eclipse.osgi 2 1 2006-12-28 22:52:42.183
!MESSAGE NLS missing message: EventLogCategory in:
org.jboss.ide.eclipse.as.ui.Messages
!MESSAGE NLS missing message: HidePropertiesAction in:
!MESSAGE NLS missing message: HideTextAction in:
!MESSAGE NLS missing message: HideLowerFrameAction in:
!ENTRY org.eclipse.ui 4 4 2006-12-28 22:52:55.027
!MESSAGE Unhandled event loop exception
!ENTRY org.eclipse.ui 4 0 2006-12-28 22:52:55.027
!MESSAGE org/eclipse/core/filesystem/EFS
!STACK 0
java.lang.NoClassDefFoundError: org/eclipse/core/filesystem/EFS
at
com.cisco.nm.cmp.ems.ems_configarchive_gui.actions.SampleAct ion.run(SampleAction.java:326)
at
com.cisco.nm.cmp.ems.ems_configarchive_gui.actions.SampleAct ion.run(SampleAction.java:299)
at org.eclipse.ui.internal.PluginAction.runWithEvent(PluginActi on.java:254)
at
org.eclipse.ui.internal.WWinPluginAction.runWithEvent(WWinPl uginAction.java:229)
at
org.eclipse.jface.action.ActionContributionItem.handleWidget Selection(ActionContributionItem.java:539)
at
org.eclipse.jface.action.ActionContributionItem.access$2(Act ionContributionItem.java:488)
at
org.eclipse.jface.action.ActionContributionItem$6.handleEven t(ActionContributionItem.java:441)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :66)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:928)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3348)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2968)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1914)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1878)
at
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:419)
at
com.cisco.nm.cmp.client.ui.workbench.rcp.CMPApplication.run( CMPApplication.java:49)
at
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:78)
at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:92)
at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:68)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:400)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:177)
at org.eclipse.core.launcher.Main.invokeFramework(Main.java:336 )
at org.eclipse.core.launcher.Main.basicRun(Main.java:280)
at org.eclipse.core.launcher.Main.run(Main.java:977)
at org.eclipse.core.launcher.Main.main(Main.java:952)
Thanks in advance!!
Krishna
"Charle Kelly" <Eclipse@CharlieKelly.com> wrote in message
news:en0q3t$2iq$1@utils.eclipse.org...
> Hi Krishna,
> If your code does not throw an Exception, is there a message in the
> Eclipse log file?
> Are you including org.eclipse.core.filesystem (and its counter-part for
> your operating system) with your application?
> Charlie
> krishna wrote:
>> I tried to open a file by adding my own action, SampleAction to a
>> toolbar. I used the OpenExternalFileAction.java
>> ( http://www.koders.com/java/fid513463C78735A056B09498429C20BA FB6B4307AF.aspx)code.
>> This is the same code that Eclipse uses to perform the same action of
>> opening a file. When I run the application the SampleAction code seems to
>> stop running at
>> IFileStore fileStore= EFS.getLocalFileSystem().getStore(new
>> Path(fFilterPath));
>> Need any solution regarding this issue.
>> Thanks in advance!!
>> Regards,
>> Krishna
Re: Problem opening a file in the RCP application [message #460705 is a reply to message #460704] |
Thu, 28 December 2006 13:02   |
Hi Krishna,
Are you using JBossIDE version 1.6 or 2.0 (1.6 uses Eclipse 3.1 libraries).
You might try inserting Class.forName (...) for
in the SampleAction.run() method.
This would distinguish between a ClassDef error and a "path" error.
Charlie
krishna wrote:
> Thanks Charle!!
> !SESSION 2006-12-28
> BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=en_US
> !STACK 0
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> Thanks in advance!!
> Regards,
> Krishna
>>Hi Krishna,
>>Eclipse log file?
>>Charlie
>>>stop running at
>>>Path(fFilterPath));
>>>Thanks in advance!!
>>>Regards,
>>>Krishna
FUDForum. Page generated in 0.04511 seconds
