Home » Eclipse Projects » Rich Client Platform (RCP) » XML Editor
XML Editor [message #460686] Thu, 28 December 2006 05:19 Go to next message
I have to show an XML, present in the filesystem, in an RCP application.
Is there a way I can extend the default XML editors present in Eclipse to
show the fiel. I need to show it in the editable tree table format as it
shown in eclipse
Need information regarding this issue.
Thanks in advance!!
Krishna
Re: XML Editor [message #460687 is a reply to message #460686] Thu, 28 December 2006 05:37 Go to previous messageGo to next message
Please search the newsgroup before asking questions I've already
answered this kind of question in a post dating from December, 22nd.
If this is not sufficient for you please follow up here or ask the guys
from WTP how to include the tree-editor they are providing.
Tom
> shown in eclipse
> Thanks in advance!!
> Regards,
> Krishna
Re: XML Editor [message #460700 is a reply to message #460687] Thu, 28 December 2006 10:08 Go to previous messageGo to next message
Thanks Tom!
I tried to build a multi page editor, following the instruction given at
http://www.eclipse.org/webtools/wst/components/sse/tutorials /multipage-editor-tutorial.html#test
When i try to open a editor(using a tollbar action) with the shown code the
program stops exectuing at the line marked below. On the RCP application
where I called the action no change is seen. The RCP application doesn't
hang. It seems like there is no action due to the clicking of the toolbar
button.
File file= queryFile();
if (file != null) {
IWorkbenchPage page=
PlatformUI.getWorkbench().getActiveWorkbenchWindow().getActi vePage();
FileEditorInput input = new FileEditorInput(ifile);
try {
page.openEditor(input,MultiPageEditor.ID );
} catch (PartInitException e) {
e.printStackTrace();
private File queryFile() {
FileDialog dialog= new
FileDialog(PlatformUI.getWorkbench().getActiveWorkbenchWindo w().getShell(),
SWT.OPEN);
dialog.setText("Open File");
String path= dialog.open();
IPath ipath = new Path(path);
if (path != null && path.length() > 0)
return new File(path);
return null;
Any help regardin the issue will be appreciated.
Thanks in advance!!
Kirshna
"Tom Schindl" <tom.schindl@bestsolution.at> wrote in message
news:en06q4$h1s$1@utils.eclipse.org...
> Tom
>> shown in eclipse
>> Thanks in advance!!
>> Regards,
>> Krishna
Re:Extending XML Editor with TableTree [message #460776 is a reply to message #460700] Fri, 29 December 2006 03:01 Go to previous messageGo to next message
I was able to resolve the previous problem, of not being able to open the
XML editor, even in text format.
I wanted some pointers regarding developing a multipage editor for opening
the XML file in a tabletree format, as default XML editor do in JBoss
Eclipse IDE.
I am able to do the page for showing raw text. I want to know how to go
about developing the tabletree page of it.
Thanks in advance!!
Krishna
Re: Changing the properties of XMLTableTreeViewer [message #460781 is a reply to message #460776] Fri, 29 December 2006 06:24 Go to previous messageGo to next message
I was able to get the treetable viewer using
org.eclipse.wst.xml.ui.internal.tabletree.XMLTableTreeViewer ;
I want to make the treetable read only and the change the contents of
context sensitive menu. Is there any way I can do it.
Any help in this regard would be appreciated.
Thanks in advance!!
Krishna
Re: Changing the properties of XMLTableTreeViewer [message #460783 is a reply to message #460781] Fri, 29 December 2006 06:51 Go to previous messageGo to next message
as already said you should ask the WTP guys on their newsgroup/mailing
list how this can be done if it can. Please also note that the class you
are using seems to be internal and can be changed/removed/... without
notification from the WTP team.
Tom
krishna schrieb:
> Thanks in advance!!
> Regards,
> Krishna
Re: Changing the properties of XMLTableTreeViewer [message #460797 is a reply to message #460783] Fri, 29 December 2006 09:45 Go to previous messageGo to next message
Thanks Tom!!
I am new to Eclipse Forum.
Krishna
Re: Changing the properties of XMLTableTreeViewer [message #549420 is a reply to message #460797] Mon, 26 July 2010 11:25 Go to previous message
Hey,
I am kind of stuck with the same problem. I want to make the treetable read only. Did u get a solution for this???
If yes kindly share it.
Ankit
Previous Topic:Visibility at toolbar-contribution
Next Topic:Need help getting started with RCP
Current Time: Sat Jul 19 02:43:26 EDT 2025
Powered by FUDForum. Page generated in 0.03627 seconds
