Home » Eclipse Projects » Standard Widget Toolkit (SWT) » Concurrency problem in building TreeItem
Concurrency problem in building TreeItem [message #460652] Fri, 02 September 2005 07:43 Go to next message
Originally posted by: murley.murley.murley
Hello, i have a question about concurrency in my gui application.
Left hand side have a many tree item, when select one of the tree item, the
right hand side will create about 50000 numbers of Tree Item.
But when creating the 50000 numbers of tree Item, the gui application become
un-responsive.
Here is my code for concurrency issue...
Thread t = new Thread(){
public void run(){
shell.getDisplay().asyncExec(new Runnable(){
public void run(){
TreeItem item = new TreeItem(tree, SWT.NONE);
item.setText("item " + i);
t.start();
is that i have something wrong?
thanks for help
updated code.. [message #460653 is a reply to message #460652] Fri, 02 September 2005 07:47 Go to previous messageGo to next message
i have update the code like this...
public void run(){
for (int i = 0; i < 50000; i++){
public void run(){
t.start();
Re: updated code.. [message #460654 is a reply to message #460653] Fri, 02 September 2005 08:50 Go to previous messageGo to next message
Originally posted by: ddana78ar.yahoo.com.ar
try to do that without making a thread. When you call "asyncExec" you are making a user thread.
May be like this:
public void run(){
Re: updated code.. [message #460655 is a reply to message #460654] Fri, 02 September 2005 08:54 Go to previous messageGo to next message
ohh... I forget, see that link:
http://help.eclipse.org/help30/index.jsp?topic=/org.eclipse. platform.doc.isv/guide/swt_threading.htm
DD
Re: updated code.. [message #460745 is a reply to message #460653] Tue, 06 September 2005 12:25 Go to previous message
Your updated code gives me reasonable performance while the Tree is
populating (win32), though this does take a while to finish.
The good news is that VIRTUAL is planned to become a supported style on Tree
for 3.2M2 (see
http://dev.eclipse.org/viewcvs/index.cgi/%7Echeckout%7E/plat form-swt-home/R3_2/plan.html )
, so you'll soon be able to just create items on an as-needed basis like in
Table.
Grant
"murley" <murley@murley.murley> wrote in message
news:df9e4h$cr1$1@news.eclipse.org...
> public void run(){
> public void run(){
> t.start();
Previous Topic:Does anybody know an Implementation for using DirectShow in SWT
Next Topic:CCombo issues...
Current Time: Sat Jul 26 17:00:29 EDT 2025
Powered by FUDForum. Page generated in 0.04805 seconds
