Home » Eclipse Projects » Standard Widget Toolkit (SWT) » SWT Tree widget memory usage
SWT Tree widget memory usage [message #460421] Thu, 25 August 2005 13:39 Go to next message
Originally posted by: nospam.spam.com
Does anyone know any tricks to reduce the memory footprint of a Tree
widget that has several thousand TreeItems. Based on admittedly
imprecise tests using top to view memory usage, I see the Tree widget
consuming around twice as much memory as the data it is meant to view.
Steve
Re: SWT Tree widget memory usage [message #460443 is a reply to message #460421] Fri, 26 August 2005 11:32 Go to previous messageGo to next message
I'm assuming that you are lazily creating subitems when the branch is
expanded, no? If not, that will reduce memory.
"Steven Farago" <nospam@spam.com> wrote in message
news:dekvpn$h0g$1@news.eclipse.org...
> Steve
Re: SWT Tree widget memory usage [message #460452 is a reply to message #460443] Fri, 26 August 2005 17:30 Go to previous messageGo to next message
In the toy example I used to test the performance and memory footprint,
no. However, we first noticed the memory and performance problems when
trying to view fully expanded trees (where children were lazily
created). In my tests, I was assuming the footprint for a Tree with
several thousand childless nodes was at least as large as that of a
fully expanded tree with same number of nodes with arbitrary
parent/child relationships.
Re: SWT Tree widget memory usage [message #460478 is a reply to message #460452] Mon, 29 August 2005 14:07 Go to previous messageGo to next message
Can you please enter a bug report with a benchmark? Thanks.
news:deo1ld$6qv$1@news.eclipse.org...
Re: SWT Tree widget memory usage [message #460488 is a reply to message #460478] Mon, 29 August 2005 18:30 Go to previous messageGo to next message
Done. Bug #108327.
Re: SWT Tree widget memory usage [message #460755 is a reply to message #460488] Tue, 06 September 2005 20:36 Go to previous message
Lots of intersting issues in there, some of them involving the VM's.
news:df02av$1fg$1@news.eclipse.org...
> Done. Bug #108327.
Previous Topic:TabFolder with tabItem at right/left side
Next Topic:Multiple Display instances questions...
Current Time: Wed Jul 23 20:24:37 EDT 2025
Powered by FUDForum. Page generated in 0.03924 seconds
