Home » Eclipse Projects » Standard Widget Toolkit (SWT) » Disable shell resize
Disable shell resize [message #459951] Sun, 21 August 2005 00:24 Go to next message
Originally posted by: ignorante.ignorante.com
Is there a way to disable the shell resize ?
I've been looking for that, but no body says something specifically for
this case.
I dont want that the shell can change of size, no bigger, no smaller of
the original size.
Re: Disable shell resize [message #459962 is a reply to message #459951] Sun, 21 August 2005 16:36 Go to previous messageGo to next message
On Sun, 21 Aug 2005 06:24:18 +0200, ignorante <ignorante@ignorante.com>
> this case.
When you create your shell, don't specify the RESIZE style (have a look at
the Shell Javadoc). This should give you a standard shell that doesn't
resize:
shell = new Shell(parent, SWT.CLOSE | SWT.TITLE | SWT.MIN | SWT.MAX);
Max - rotvel AT bolignet-aarhus DOT dk
Re: Disable shell resize [message #460418 is a reply to message #459962] Thu, 25 August 2005 12:43 Go to previous messageGo to next message
Well, it continues resizing, and by the way, i want to it doesnt
maximisize, too.
the lines are:
sShell = new Shell(SWT.ON_TOP | SWT.SHELL_TRIM | SWT.CLOSE | SWT.TITLE);
Re: Disable shell resize [message #460422 is a reply to message #460418] Thu, 25 August 2005 13:44 Go to previous messageGo to next message
> maximisize, too.
> the lines are:
Don't use SHELL_TRIM since it includes resize and maximize. The following
is from the javadoc:
SHELL_TRIM
the result of combining the constants which are required to produce a
typical application top level shell: (that is, CLOSE | TITLE | MIN | MAX |
RESIZE)
Connie
Re: Disable shell resize [message #460423 is a reply to message #460422] Thu, 25 August 2005 14:29 Go to previous messageGo to next message
It works Great!
I was really stupid XD
I never notice that about SWT.SHELL_TRIM
Thanks :D
sShell = new Shell(SWT.ON_TOP | SWT.CLOSE | SWT.TITLE);
Re: Disable shell resize [message #460431 is a reply to message #460423] Fri, 26 August 2005 05:33 Go to previous message
just for the record - you could switch of the RESIZE flag using
sShell = new Shell(SWT.SHELL_TRIM & ~ SWT.RESIZE);
Previous Topic:Table and TableCursor
Next Topic:Customized Group
Current Time: Sun Jul 27 04:40:43 EDT 2025
Powered by FUDForum. Page generated in 0.06276 seconds
