Home » Eclipse Projects » Standard Widget Toolkit (SWT) » Add icon in a TableTree
Add icon in a TableTree [message #460403] Wed, 24 August 2005 13:17 Go to next message
Hello, I am using a swt TableTree component. I have 2 columns.
I am trying to put an Icon for every node. The icon appears if a use:
TableTreeItem item1 = new TableTreeItem(tableTree,SWT.NULL);
item1.setText(0,"BPL 1");
item1.setImage(1,image);
However I would like : first the image and then the text.
item1.setText(1,"BPL 1");
item1.setImage(0,image);
But that doesn't work.
Any idea?
Thanks.
Re: Add icon in a TableTree [message #460412 is a reply to message #460403] Thu, 25 August 2005 09:09 Go to previous message
TableTree does not support putting an image in column 0 (report:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=25007 ).
However, as of 3.1 TableTree has been deprecated in favour of using a Tree
with TreeColumns. You should use this instead because it utilizes the
native Tree widget properly, and will allow you to put images in the first
column.
Grant
"oscar" <OE_PROMOS@TERRA.ES> wrote in message
news:4b73c6d1af3651cdd97b9bc3f4a6cf6c$1@www.eclipse.org...
> Any idea?
> Thanks.
Previous Topic:Uninitialise plugin
Next Topic:duplicate entries in TableViewer
Current Time: Sat Jul 19 01:08:07 EDT 2025
Powered by FUDForum. Page generated in 0.06024 seconds
