Home » Eclipse Projects » Rich Client Platform (RCP) » Exception launching the Eclipse Platform
Exception launching the Eclipse Platform [message #460231] Mon, 18 December 2006 09:08 Go to next message
Originally posted by: eclipse.patcom.demon.co.uk
Hello
I have just upgraded from 3.1 to 3.2.1 and my Plug-in application will
no longer start. When I use the "Launch an Eclipse application" option
on the plug-in editor, I get an "Exception launching the Eclipse
Platform" message with the following stack trace
java.lang.ArrayIndexOutOfBoundsException: 0
at org.eclipse.core.launcher.Main.getSplashLocation(Main.java:1 642)
at org.eclipse.core.launcher.Main.handleSplash(Main.java:1539)
at org.eclipse.core.launcher.Main.basicRun(Main.java:278)
at org.eclipse.core.launcher.Main.run(Main.java:977)
at org.eclipse.core.launcher.Main.main(Main.java:952)
I have not defined a splash screen for the application - this was OK in
3.1, do I need to define one for 3.2?
Mike
Re: Exception launching the Eclipse Platform [message #460313 is a reply to message #460231] Tue, 19 December 2006 08:21 Go to previous messageGo to next message
Did you use a new workspace when you started? It might be that there's some old data in the pde launch configurations that you can get rid of if that's the case. You can also try deleting the launch configuration and re-creating it; that will also ensure that any cached data for the runtime version will be cleaned.
If that doesn't work, the 'runtime-workspace' (or whatever you called it) could be cleaned and you could try again.
Alex.
Re: Exception launching the Eclipse Platform [message #460479 is a reply to message #460313] Thu, 21 December 2006 09:14 Go to previous message
> Alex.
Hello Alex
I am using the 3.1 workspace but I did add the --clean argument to the
Eclipse startup. I removed and re-created the launch configuration so I
will create a new workspace and copy my plug-in over to it
Mike
Previous Topic:Table editing using TableViewer
Next Topic:Minimal Configuration
Current Time: Tue Nov 04 02:40:11 EST 2025
Powered by FUDForum. Page generated in 0.67542 seconds
