Home » Eclipse Projects » Standard Widget Toolkit (SWT) » ContentProvider for TableViewer Problem
ContentProvider for TableViewer Problem [message #459861] Thu, 18 August 2005 12:20 Go to next message
This return in the method within a ContentProvider
public Object[] getElements(Object inputElement) (
return inputElement.getCases().toArray();
needs to be replaced with something not using the parameter inputElement
like
return caseList.getCases().toArray();
because the method gets called before setInput is called causing a null
pointer exception. It would seem that the getElements method should not
be called until setInput is called. Am I missing something?
Re: ContentProvider for TableViewer Problem [message #459920 is a reply to message #459861] Thu, 18 August 2005 13:09 Go to previous messageGo to next message
Originally posted by: sunil_kamath.nohotspammail.com
"James Leotta" <jleotta@bascom.com> wrote in message
news:de2cds$mhv$1@news.eclipse.org...
> like
Yes you are.
You should check for nulls in the getElements() method.
If inputElement == null, then return null.
Sunil
Re: ContentProvider for TableViewer Problem [message #459926 is a reply to message #459861] Thu, 18 August 2005 17:48 Go to previous messageGo to next message
> like
Here is how the ArrayContentProvider does it:
public Object[] getElements(Object inputElement) {
if (inputElement instanceof Object[])
return (Object[]) inputElement;
if (inputElement instanceof Collection)
return ((Collection) inputElement).toArray();
return new Object[0];
So effectively you should be adding null checks.
Re: ContentProvider for TableViewer Problem [message #459941 is a reply to message #459861] Fri, 19 August 2005 15:20 Go to previous message
Thanks folks!
> like
Previous Topic:Fixed Editor - How to avoid the user to close one editor
Next Topic:JFace Document
Current Time: Sun Jul 27 11:46:39 EDT 2025
Powered by FUDForum. Page generated in 0.04466 seconds
