Home » Eclipse Projects » Standard Widget Toolkit (SWT) » Problems with Embedded Excel ActiveX with SWT 3.1 (works with 2.1)
Problems with Embedded Excel ActiveX with SWT 3.1 (works with 2.1) [message #459775] |
Tue, 16 August 2005 08:50  |
Originally posted by: john.nichol.psjsolutions.com
I am having problems using the Excel ActiveX control in with SWT 3.1 (SWT
from Eclipse 3.1). Basically I can not get the control to size correctly,
show scrollbars, show column headers when needed, etc with 3.1. This all
works fine with SWT 2.1 (SWT from Eclipse 2.1).
I am guessing that I need to be move explicit about layout management or
sizing, but have tried all sorts of variants of layouts and sizing of the
OleFrame that contains the component all to no avail. Have the rules
changed from 2.1 to 3.1 if so could anyone point me at an appropriate
resource.
I have been through various IBM and Eclipse resources including
http://www.eclipse.org/articles/Article-ActiveX%20Support%20 in%20SWT/ActiveX%20Support%20in%20SWT.html
and
http://www-128.ibm.com/developerworks/library/os-activex/
These are pretty old (in Eclipse dev timeframes), are there newer
resources for embedding ActiveX in SWT/Eclipse RCP that I should be
reading?
Attached is a snippet that reproduces the problem. I have removed all
attempts to set layouts constrain sizes etc as they haven't worked. I
have run the code with minimal set of jars (swt, jfaces, runtime, boot)
from 2.1 and 3.1. 2.1 does what I expect, lays out correctly, shows row
and column headers, 3.1 doesn't fit the space sensibly, resize correctly,
etc.
I am using MS Office 2003 Pro.
Any help gratefully received.
John
import org.eclipse.swt.SWT;
import org.eclipse.swt.graphics.Point;
import org.eclipse.swt.layout.FillLayout;
import org.eclipse.swt.ole.win32.OLE;
import org.eclipse.swt.ole.win32.OleClientSite;
import org.eclipse.swt.ole.win32.OleFrame;
import org.eclipse.swt.widgets.Menu;
import org.eclipse.swt.widgets.Shell;
public class SWTExcelTest {
private Shell sShell = null;
Display display = Display.getDefault();
SWTExcelTest thisClass = new SWTExcelTest();
thisClass.createSShell();
thisClass.sShell.open();
while (!thisClass.sShell.isDisposed()) {
if (!display.readAndDispatch())
display.sleep();
display.dispose();
* This method initializes sShell
private void createSShell() {
sShell = new Shell();
sShell.setText("Shell");
sShell.setSize(new Point(300, 200));
sShell.setLayout(new FillLayout());
sShell.setMenuBar(new Menu(sShell, SWT.BAR));
OleFrame frame = new OleFrame(sShell, SWT.NONE);
OleClientSite site = new OleClientSite(frame, SWT.NONE,
"ExcelWorksheet");
site.doVerb(OLE.OLEIVERB_SHOW);
Re: Problems with Embedded Excel ActiveX with SWT 3.1 (works with 2.1) [message #460438 is a reply to message #459775] |
Fri, 26 August 2005 11:11  |
Please enter a bug report with the snippet. Thanks!
"John Nichol" <john.nichol@psjsolutions.com> wrote in message
news:df69095f7e4e26fe1a28cbc21131a49f$1@www.eclipse.org...
> resource.
> and
> reading?
> etc.
> Regards,
> John
> import org.eclipse.swt.widgets.Display;
> public static void main(String[] args) {
> display.sleep();
> display.dispose();
> "ExcelWorksheet");
Current Time: Wed Jul 23 21:40:45 EDT 2025
Powered by FUDForum. Page generated in 0.03411 seconds
