Home » Eclipse Projects » Standard Widget Toolkit (SWT) » ScrolledComposite WizardPage Problem
ScrolledComposite WizardPage Problem [message #459326] Fri, 05 August 2005 12:06 Go to next message
Originally posted by: p.clark.mindspring.com
I am having a problem trying to scroll a wizard page. All I get is a
blank page when the wizard page is generated. Here are the snippets of
the Wizard and the WizardPage.
Any help around why I can't scroll a wizard page would be greatly
appreciated.
Thanks!
Patrick
public class SnippetWizardPage extends WizardPage {
protected SnippetWizardPage(String pageName) {
super(pageName);
setTitle("Testing ScrolledComposite");
public void createControl(Composite parent) {
ScrolledComposite scroll = new ScrolledComposite(parent,
SWT.H_SCROLL | SWT.V_SCROLL);
scroll.getVerticalBar().setIncrement(20);
scroll.setLayout(new FillLayout());
Composite container = new Composite(scroll, SWT.NONE);
scroll.setContent(container);
GridLayout pageLayout = new GridLayout();
pageLayout.numColumns = 2;
container.setLayout(pageLayout);
container.setLayoutData(new GridData(GridData.FILL_HORIZONTAL));
for (int x=0; x<30; x++) {
Label label = new Label(container, SWT.NONE);
label.setText("testing...");
setControl(scroll);
public class SnippetWizard extends Wizard {
private SnippetWizardPage page1 = new SnippetWizardPage("page1");
public SnippetWizard() {
super();
public void addPages() {
addPage(page1);
this.setDefaultPageImageDescriptor(ImageDescriptor.createFro mFile(SelectImportServerWizardPage.class,
"/userimportlarge.gif"));
* (non-Javadoc)
* @see org.eclipse.jface.wizard.IWizard#performFinish()
public boolean performFinish() {
return true;
Re: ScrolledComposite WizardPage Problem [message #459332 is a reply to message #459326] Fri, 05 August 2005 14:52 Go to previous messageGo to next message
Originally posted by: sunil_kamath.nohotspammail.com
"Patrick Clark" <p.clark@mindspring.com> wrote in message
news:dd02qm$ij5$1@news.eclipse.org...
>I am having a problem trying to scroll a wizard page. All I get is a blank
>page when the wizard page is generated. Here are the snippets of the
[snip]
[snip]
[snip]
This doesn't look right to me.
Sunil
Re: ScrolledComposite WizardPage Problem [message #459341 is a reply to message #459326] Sat, 06 August 2005 07:49 Go to previous message
> appreciated.
> Thanks!
> Patrick
> super(pageName);
> setControl(scroll);
> super();
> addPage(page1);
> * (non-Javadoc)
> return true;
after adding the components to the inner composite I call the next two
lines to make things visible. So this will be after you added the labels
scrolledComposite.setMinSize(innerComposite.computeSize(SWT. DEFAULT,SWT.DEFAULT));
innercomposite.layout();
Previous Topic:TreeItem.setExpanded() not showing the desired effect
Next Topic:Using FormLayout cannot get the actual size(Cond)
Current Time: Thu Jul 24 21:27:23 EDT 2025
Powered by FUDForum. Page generated in 0.04728 seconds
