Re: May I make checkbox of table read_only? [message #459302 is a reply to message #459247] |
Fri, 05 August 2005 03:38  |
James Gan wrote:
> Thank you for the answer. Maybe I should disable the entitle table :)
> Roland Tepp wrote:
>> Not as such afaict...
>> You can however make it visually "disabled" by gray'ing it out and
>> resetting it's value in a listener whenever somebody tries to change
>> it's checked state.
>> James Gan kirjutas mulle ühel talvisel päeval midagi seesugust:
>>> Hi,
>>> I'm using the standard table of swt with SWT.CHECK style. But
>>> sometimes I hope it's read_only to user.
>>> Is there an API for this purpose?
>>> Thanks a lot!
>>> James Gan
You could also use an image of a checked checkbox to display in the
column. That way no one is able to uncheck it.
HTH
Stefan
FUDForum. Page generated in 0.04153 seconds
