Home » Eclipse Projects » Standard Widget Toolkit (SWT) » SWT Mac os X JVM 1.4.2
SWT Mac os X JVM 1.4.2 [message #459111] Tue, 02 August 2005 05:33 Go to next message
Originally posted by: christoph_weber.gmx.net
Hi!
I try to port an application for using HBCI Banking to Mac OS X. It uses
the GPL Framework Jameica which is based on SWT.
Everything works fine on Windows and Linux (at least according to the
author of the framework). When I try to start it on Mac OS X 10.3.9 in
JVM 1.4.2 and SWT Version 3.0 the dialogs never get focus so you are
unable to communicate with them.
So I used SWT 3.1. Now the starting process works further I can answer
the first dialog (It is a password question to register a new pass), but
then I get an exception in
"org.eclipse.swt.layout.FillLayout.computeChildSize".
I didn't want to post this into the bug database, as I can't imagine
that there is such an essential bug so deep in swt. So I am sure I do
something wrong or forbidden with the framework.
Here is the complete stacktrace. I would also help me if somone knew why
the dialogs don't get focus under 3.0.
[Tue Aug 02 11:28:52 CEST 2005][ERROR][de.willuhn.jameica.gui.GUI.init]
java.lang.ClassCastException
at org.eclipse.swt.layout.FillLayout.computeChildSize(FillLayou t.java:141)
at org.eclipse.swt.layout.FillLayout.computeSize(FillLayout.jav a:119)
at org.eclipse.swt.widgets.Composite.computeSize(Composite.java :187)
at
org.eclipse.swt.custom.SashFormLayout.computeSize(SashFormLa yout.java:46)
at org.eclipse.swt.layout.GridData.computeSize(GridData.java:46 3)
at org.eclipse.swt.layout.GridLayout.layout(GridLayout.java:207 )
at org.eclipse.swt.layout.GridLayout.layout(GridLayout.java:186 )
at org.eclipse.swt.widgets.Composite.updateLayout(Composite.jav a:917)
at org.eclipse.swt.widgets.Shell.setWindowVisible(Shell.java:14 47)
at org.eclipse.swt.widgets.Shell.setVisible(Shell.java:1427)
at org.eclipse.swt.widgets.Shell.open(Shell.java:1080)
at de.willuhn.jameica.gui.GUI.load(GUI.java:206)
at de.willuhn.jameica.gui.GUI.init(GUI.java:221)
at de.willuhn.jameica.system.Application.init(Application.java: 247)
at de.willuhn.jameica.system.Application.newInstance(Applicatio n.java:82)
at de.willuhn.jameica.Main.main(Main.java:78)
You can also receive the Jameica Framework under
http://www.willuhn.de/projects/jameica/
if you want to look into the sources.
Many thanks,
Christoph
Re: SWT Mac os X JVM 1.4.2 [message #459167 is a reply to message #459111] Tue, 02 August 2005 15:37 Go to previous messageGo to next message
It's a programming error in the Jameica framework. See:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=98493
"Christoph Weber" <christoph_weber@gmx.net> wrote in message
news:dcnel1$3i3$1@news.eclipse.org...
> Hi!
> at
> Many thanks,
> Christoph
Re: SWT Mac os X JVM 1.4.2 [message #459172 is a reply to message #459167] Wed, 03 August 2005 02:17 Go to previous messageGo to next message
Hi!
Thank you very much, that solved the problem.
Christoph
Re: SWT Mac os X JVM 1.4.2 [message #459315 is a reply to message #459111] Fri, 05 August 2005 08:25 Go to previous message
To use SWT with JVM > 1.3 you'll have to pass a -XstartOnFirstThread to the
Java VM (/usr/bin/java), or add the following to the Java dictionary inside
your Info.plist:
<key>StartOnMainThread</key>
<true/>
--andre
On 2.8.2005 11:33 Uhr, in article dcnel1$3i3$1@news.eclipse.org, "Christoph
Weber" <christoph_weber@gmx.net> wrote:
> Hi!
> at
> Many thanks,
> Christoph
Previous Topic:SWT key code
Next Topic:Transparent widgets and controls?
Current Time: Sun Jul 27 03:27:37 EDT 2025
Powered by FUDForum. Page generated in 0.04068 seconds
