Home » Eclipse Projects » Standard Widget Toolkit (SWT) » How to scroll a table to its end
How to scroll a table to its end [message #458951] Wed, 27 July 2005 04:46 Go to next message
Hello !
I want to scroll a table to its end after the user has added an item, so
that the user can see directly that the item has been added instead of
having to scroll the whole table down.
After looking in the API I found the setTopIndex(int index) method of
the Table class but it does not want I want : the last element is
sometimes "cut" because the table's height isn't exactly a multiple of
rows' height.
How can I solve that ? Is there a "setBottomIndex()" method hidden
somewhere ;) ?
Thanks ;) !
Vincent
Re: How to scroll a table to its end [message #458958 is a reply to message #458951] Wed, 27 July 2005 08:38 Go to previous messageGo to next message
try mytable.getItem(table.getItemCount()-1).showItem()
or newItem.showItem() if you already have a reference to the new item.
Yves
> Hello !
> rows' height.
> somewhere ;) ?
> Thanks ;) !
> Vincent
Re: How to scroll a table to its end [message #458960 is a reply to message #458958] Wed, 27 July 2005 08:58 Go to previous messageGo to next message
Yves Harms wrote:
> Yves
Thanks for your answer ! The right code is :
TableItem lastItem = myTable.getItem(restoreItemsTable.getItemCount() - 1);
myTable.showItem(lastItem);
But unfortunately the result is the same as with setTopIndex() : the
last item is most of the time "cut" :(...
Re: How to scroll a table to its end [message #458963 is a reply to message #458960] Wed, 27 July 2005 09:26 Go to previous messageGo to next message
Vincent,
Which platform do you see this on? Do you have a snippet that shows it
happening? I did a quick experiment (snippet below) on win32, gtk and
motif, and could not get any of them to cut off the last item, even with
various Table heights. Using Table.setTopIndex() with a large value (eg.-
setTopIndex(table.getItemCount() - 1)) _should_ do what you want.
public class Main {
static int TABLE_HEIGHT = 195;
static int TABLE_ITEMCOUNT = 100;
Display display = new Display ();
final Shell shell = new Shell(display);
shell.setBounds(10,10,300,300);
final Table table = new Table(shell, SWT.NONE);
table.setBounds(10,10,200,TABLE_HEIGHT);
for (int i = 0; i < TABLE_ITEMCOUNT; i++) {
new TableItem (table, SWT.NONE).setText("item " + i);
shell.open();
shell.addListener(SWT.MouseDown, new Listener() {
public void handleEvent(Event event) {
TableItem lastItem = table.getItem(TABLE_ITEMCOUNT - 1);
table.showItem(lastItem);
//table.setTopIndex(TABLE_ITEMCOUNT - 1);
while (!shell.isDisposed()) {
if (!display.readAndDispatch()) display.sleep();
display.dispose();
Grant
"Vincent Etter" <vincent.etter@gmail.com> wrote in message
news:dc80d6$tbf$1@news.eclipse.org...
> Yves Harms wrote:
> > Hi,
> > Yves
1);
Re: How to scroll a table to its end [message #458966 is a reply to message #458963] Wed, 27 July 2005 10:04 Go to previous messageGo to next message
Grant,
I'm running on Windows XP. Your snippet works fine but not my code...
Here is a screenshot of what I get :
http://img59.imageshack.us/img59/4816/screenshot3ur.jpg
This is really strange... Thanks for your interest !
Vincent
Re: How to scroll a table to its end [message #458968 is a reply to message #458966] Wed, 27 July 2005 10:31 Go to previous messageGo to next message
There's something strange happening with the TableEditor (just logged
https://bugs.eclipse.org/bugs/show_bug.cgi?id=105316 ), though I have not
replicated your problem. If you have a stand-alone snippet that shows it
happening then it would be easier to determine what's happening in your
case.
Grant
news:dc8497$2o2$1@news.eclipse.org...
> Grant,
> Vincent
Re: How to scroll a table to its end [message #458971 is a reply to message #458968] Wed, 27 July 2005 10:53 Go to previous message
> case.
> Grant
My problem is the same as the one you reported. The stand-alone snippet
I made shows the same than your screenshot in the bug report. Here it is :
public class Main {
new TableColumn(table, SWT.NONE).setWidth(75);
TableItem item = new TableItem(table, SWT.NONE);
Label label = new Label(table, SWT.NONE);
label.setText("item " + i);
label.setBackground(Display.getCurrent().getSystemColor(SWT. COLOR_WHITE));
label.pack();
TableEditor editor = new TableEditor(table);
editor.grabHorizontal = true;
editor.grabVertical = true;
editor.setEditor(label, item, 0);
Button remove = new Button(table, SWT.PUSH);
remove.setText("Remove");
remove.pack();
editor.minimumWidth = remove.getSize().x;
editor.setEditor(remove, item, 1);
table.getColumn(1).setWidth(remove.getSize().x + 5);
shell.open();
display.dispose();
Look at the labels : you can see that the scrollbar seems to scroll but
the content of the table does not move ! Screenshot :
http://img61.imageshack.us/img61/1639/screenshot20cg.jpg
Previous Topic:"Unsupported or unrecognized format" reading jpegs
Next Topic:SWT exception kills VM
Current Time: Wed Jul 23 12:18:05 EDT 2025
Powered by FUDForum. Page generated in 0.11245 seconds
