Home » Eclipse Projects » Standard Widget Toolkit (SWT) » gc.setClipping
gc.setClipping [message #458778] Wed, 20 July 2005 19:19 Go to next message
On Windows, I was trying to set a clipping region on the GC, do some
painting, reset the clipping region and do some more painting:
final Display display = new Display();
final Shell shell = new Shell(display);
shell.addPaintListener(new PaintListener() {
public void paintControl(PaintEvent event) {
GC gc = event.gc;
Display display = event.display;
Transform transform = new Transform(display);
gc.setTransform(transform); // <-- clipping is fine if I
comment this line
/* Set the clipping region. */
Region region = new Region(display);
gc.getClipping(region);
gc.setClipping(50, 50, 100, 100);
/* Do some painting. */
gc.setBackground(display.getSystemColor(SWT.COLOR_RED));
gc.fillRectangle(50, 50, 100, 100);
/* Restore the clipping region. */
gc.setClipping(/* (Region)null */region);
/* Do some more painting. */
gc.fillRectangle(200, 50, 100, 100);
transform.dispose();
region.dispose();
shell.open();
while (!shell.isDisposed()) {
if (!display.readAndDispatch()) display.sleep();
display.dispose();
Whatever is painted after restoring the clipping region does not show up
on the shell - it seems that the clipping region is not reset properly.
However, clipping works fine if I don't set the transform on the GC.
I found a bug with the similar problem:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=103642
Then I tried to reset my GC by calling gc.setClipping((Region)null) and it
works!
Question:
Is there any difference between calling
gc.setClipping(...);
gc.setClipping(region);
vs.
gc.setClipping((Region)null);?
Connie
Re: gc.setClipping [message #458853 is a reply to message #458778] Fri, 22 July 2005 17:31 Go to previous messageGo to next message
Connie,
the bug you mentioned was fixed today. It's surely worth a try to
check the newest SWT build.
Michael
On Wed, 20 Jul 2005 23:19:39 +0000 (UTC), kkconcome@yahoo.com (Connie
Lam) wrote:
>Hi,
>public static void main(String[] args) {
> GC gc = event.gc;
>comment this line
> region.dispose();
> shell.open();
> display.dispose();
>works!
>Question:
>vs.
>Thanks,
>Connie
Re: gc.setClipping [message #458977 is a reply to message #458853] Wed, 27 July 2005 14:51 Go to previous message
Thanks Michael! Unfortunately my code still doesn't work with the latest
build. The problem I encountered is a little different from the one
described in the bug report. I'll file a separate bug for it.
Connie
Michael Baehr wrote:
> Connie,
> Michael
> Lam) wrote:
>>Hi,
>> GC gc = event.gc;
>>comment this line
>> region.dispose();
>> shell.open();
>> display.dispose();
>>works!
>>Question:
>>vs.
>>Thanks,
>>Connie
Previous Topic:HIDE_SELECTION in Table
Next Topic:Deranged wizard pages
Current Time: Wed Jul 23 12:33:04 EDT 2025
Powered by FUDForum. Page generated in 0.12138 seconds
