Home » Eclipse Projects » Standard Widget Toolkit (SWT) » PocketPC and SWT - how to get started - bad major version error
PocketPC and SWT - how to get started - bad major version error [message #458672] Mon, 18 July 2005 20:59 Go to next message
Originally posted by: jm1.dicehome.com
I'd like to experiment with writing swt apps on my pocketPC. I've seen
the article on a little cup of swt, but it does not talk about exactly
what is needed to run any java app on pocketPC.
I think I need J9 and the swt.jar, but when I run my hello world app I
get "bad major version at offset = 6"
this seems to me like I have the wrong version of something or my code
is not compiled properly. I am using Eclipse and jdk1.5.0_03. Am I
supposed to compile with a different jdk?
Thanks for any help.
Chip
Re: PocketPC and SWT - how to get started - bad major version error [message #458679 is a reply to message #458672] Tue, 19 July 2005 03:02 Go to previous messageGo to next message
> Chip
Try compiling with "Compiler Compliance" set to 1.4.
Thomas
Re: PocketPC and SWT - how to get started - bad major version error [message #458720 is a reply to message #458679] Tue, 19 July 2005 20:49 Go to previous messageGo to next message
Thomas,
Thanks for your input. I got past that error only to run into
"NoClassDefFoundError". I've included my code below.
Thanks for any input,
Chip
import org.eclipse.swt.SWT;
import org.eclipse.swt.widgets.Label;
import org.eclipse.swt.widgets.Shell;
public class HelloSWT {
Display display = new Display();
Shell shell = new Shell(display, SWT.CLOSE);
shell.setText("Main");
Label l = new Label(shell, 0);
l.setText("Hello, World");
l.setBounds(shell.getClientArea());
shell.open();
while (!shell.isDisposed()) {
if (!display.readAndDispatch())
display.sleep();
display.dispose();
>> Chip
> Thomas
Re: PocketPC and SWT - how to get started - bad major version error [message #458738 is a reply to message #458720] Wed, 20 July 2005 09:21 Go to previous messageGo to next message
Can you give the full error? What class was not found?
"cdx11356" <jm1@dicehome.com> wrote in message
news:dbk6uq$4c4$1@news.eclipse.org...
> Thomas,
> Chip
> import org.eclipse.swt.widgets.Display;
> public static void main(String[] args) {
> shell.open();
> display.sleep();
> display.dispose();
> Thomas M
Re: PocketPC and SWT - how to get started - bad major version error [message #458779 is a reply to message #458738] Wed, 20 July 2005 20:24 Go to previous message
This is all I get. I do not know what Class it is referring to
Exception in thread "main" java.lang.NoClassDefFoundError
at java.lang.ClassLoader.defineClassImpl(Native Method)
at java.lang.ClassLoader.defineClass(Unknown Source)
at java.security.SecureClassLoader.defineClass(Unknown Source)
at java.net.URLClassLoader.findClassImpl(Unknown Source)
at java.net.URLClassLoader$4.run(Unknown Source)
at java.security.AccessController.doPrivileged(Unknown Source)
at java.net.URLClassLoader.findClass(Unknown Source)
at com.ibm.oti.vm.URLSystemClassLoader.findClass(Unknown Source)
at com.ibm.oti.vm.URLSystemClassLoader.loadClass(Unknown Source)
>>Thomas,
>>Chip
>>shell.open();
>> display.sleep();
>> display.dispose();
>>>>Chip
>>>Thomas
Previous Topic:need PropertyGrid control
Next Topic:How to deploy SWT/JFace apps?
Current Time: Sun Jul 27 08:01:27 EDT 2025
Powered by FUDForum. Page generated in 0.04669 seconds
