Widget is disposed!!! [message #458685] |
Tue, 19 July 2005 06:06  |
My application is throwing a "Widget is disposed" exception, when a tab is
closed and reopend again (using window->show view). The view object still
shows all the elements sitting on it, however, upon accessing their
various properties (like getText() etc.), it throws an SWTException caused
by "Widget is disposed".
I am attaching the complete stack trace. Any suggestion to get around this
are welcome.
Mohit
PS: one of the makeshift solution is to make the entire perspective fixed,
so that user can not close a tab. However, I m looking for a solution
wherein user should not feel restricted.
org.eclipse.swt.SWTException: Widget is disposed
at org.eclipse.swt.SWT.error(SWT.java:2940)
at org.eclipse.swt.SWT.error(SWT.java:2863)
at org.eclipse.swt.SWT.error(SWT.java:2834)
at org.eclipse.swt.widgets.Widget.error(Widget.java:393)
at org.eclipse.swt.widgets.Widget.checkWidget(Widget.java:295)
at org.eclipse.swt.widgets.Combo.getText(Combo.java:704)
at
com.qwest.rx.ottodesktop.views.WatchListView$WatchListModelL istener.notify(WatchListView.java:118)
at
com.qwest.rx.ottodesktop.DesktopManager.notifyListeners(Desk topManager.java:124)
at
com.qwest.rx.ottodesktop.DesktopManager.postEvent(DesktopMan ager.java:110)
at
com.qwest.rx.ottodesktop.views.WatchListView$5.widgetSelecte d(WatchListView.java:293)
at
org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListe ner.java:89)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :82)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:842)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:2921)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2554)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1601)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1565)
at
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:315)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:143)
at
com.qwest.rx.ottodesktop.PlatformRunnableImpl.run(PlatformRu nnableImpl.java:28)
at
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:230)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:371)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:160)
at
at
at java.lang.reflect.Method.invoke(Method.java:324)
at org.eclipse.core.launcher.Main.invokeFramework(Main.java:330 )
at org.eclipse.core.launcher.Main.basicRun(Main.java:274)
at org.eclipse.core.launcher.Main.run(Main.java:977)
at org.eclipse.core.launcher.Main.main(Main.java:952)
Re: Widget is disposed!!! [message #458692 is a reply to message #458685] |
Tue, 19 July 2005 10:52   |
What are you doing when the tab is closed? If you are disposing the content
of the tab, then that would explain the widget is disposed error.
The content of the tab is a child of the TabFolder (or CTabFolder) and not a
child of the TabItem (or CTabItem). If you wish to reuse the widgets when
the tab is created again at a later time, rather than disposing the content,
just set the content to not be visible (setVisible(false)).
"Mohit" <mohit.jhawar@gmail.com> wrote in message
news:b5ac3592dd639d98834ab9ee3a3b3b27$1@www.eclipse.org...
> are welcome.
> Mohit
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
Re: Widget is disposed!!! [message #458698 is a reply to message #458692] |
Tue, 19 July 2005 11:33   |
Sorry for querying in an obscure way. Here are the steps which caused the
exception.
1. Close a view tab using 'x' (one of the various views sitting on a
IFolderLayout)
2. open the view again using Window-> Show View
3. The selection listener of Combo (or any other element) post event to
some listener which is a inner class to the view class. (till this stage
the getText() of combo was returning some value and combo was alive)
Now, All the elements (Combo etc) when accessed from inner class of view
class indicate disposed status but are very much alive in the view class.
Inside the inner class my combo indicates disposed-off status and calling
getText() throws the SWTException.
public class WatchListView{
//listener to the view
class WatchListModelListener implements ModelUpdateListener{
public void notify(Event event) {
if(event.getEventId().equals(WatchListEvent.WATCHLIST_FETCH_ NAMES)){
WatchListView.this.populateWatchlistCombo(WatchListView.this .watchListType.getText());
I am not doing nything extra in dispose().
tia,
Mohit
>> Hi,
>> are welcome.
>> Thanks,
>> Mohit
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
>> at
>> at
Re: Widget is disposed!!! [message #458734 is a reply to message #458704] |
Wed, 20 July 2005 08:00  |
Thanks a lot Sunil.
I just forgot to unregister my listener :|
Mohit
> news:52c5d463354207bfdd171f62b63ec63e$1@www.eclipse.org...
>> Hi,
>> exception.
>> IFolderLayout)
> When you close (dispose) the view, make sure to remove the
> watchListModelListener from the model.
> What has happened is that even though the view was closed/disposed, the
> listener object is still active and listening for model changes.
> Sunil
FUDForum. Page generated in 0.26351 seconds
