Home » Eclipse Projects » Rich Client Platform (RCP) » JDK versions when exporting and running product
JDK versions when exporting and running product [message #458642] Thu, 23 November 2006 09:21 Go to next message
Originally posted by: hja-oliveira.criticalsoftware.com
Hello all,
I have an Eclipse RCP plug-in project that I can export as a Linux (gtk/x86) product and run with no problems on the same machine. However, when trying to run the product on another computer, the application fails to start. The error log contains an org.osgi.framework.BundleException, and the message mentions that the plug-in's Activator is invalid.
The problem is similar to the one described in this thread:
http://dev.eclipse.org/newslists/news.eclipse.platform.rcp/m sg15572.html
Basically this happens if the JDK version used to export the product in Eclipse is different from the version used to run it - I'm using Java 1.5.0_09 in to export and 1.5.0_08 to run the product. When I export in the target computer, the application runs without a problem.
Is there any solution/workaround to this? I want to avoid forcing the user to have the exact same version of the JDK to be able to run the product.
hjoliveira
Re: JDK versions when exporting and running product [message #458726 is a reply to message #458642] Thu, 23 November 2006 11:07 Go to previous messageGo to next message
This is very surprising to me, there should not be a difference between
_08 and _09 that would cause this kind of thing.
A common cause of this thing would be compiling on a 1.5.0 vm and trying
to run on a 1.4.2 vm. (Class format exceptions).
This invalid activator exception is usually caused by an earlier
exception that would have occurred when trying to run your activator
start method. Look in your log just above the BundleException to see
what the cause is.
If it is a class format issue, see
http://help.eclipse.org/help32/index.jsp?topic=/org.eclipse. pde.doc.user/guide/tasks/pde_compilation_env.htm
for details on how to control your compilation during export.
-Andrew
hjoliveira wrote:
> Hello all,
> hjoliveira
Re: JDK versions when exporting and running product [message #458751 is a reply to message #458726] Thu, 23 November 2006 14:12 Go to previous message
Actually the cause is below the BundleException. See for example this
log that just happened to me:
> !ENTRY org.eclipse.splash 4 0 2006-11-23 14:07:20.772
> !MESSAGE
> !STACK 0
> org.osgi.framework.BundleException: The activator org.eclipse.splash.Activator for bundle org.eclipse.splash is invalid
> at org.eclipse.osgi.framework.internal.core.AbstractBundle.load BundleActivator(AbstractBundle.java:141)
> at org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tart(BundleContextImpl.java:970)
<snip>
> Caused by: java.lang.UnsupportedClassVersionError: org/eclipse/splash/Activator (Unsupported major.minor version 49.0)
> at java.lang.ClassLoader.defineClass0(Native Method)
> at java.lang.ClassLoader.defineClass(Unknown Source)
The cause in this case is I compiled with java 1.5.0, and tried running
with a 1.4.2 vm.
-Andrew
> what the cause is.
> -Andrew
> hjoliveira wrote:
>> Hello all,
>> product.
>> Thanks,
>> hjoliveira
Previous Topic:hide view-popup-menu?
Next Topic:load Class via RMI
Current Time: Mon Jul 28 11:01:01 EDT 2025
Powered by FUDForum. Page generated in 0.03717 seconds
