Home » Eclipse Projects » Standard Widget Toolkit (SWT) » VIRTUAL - how to use it?
VIRTUAL - how to use it? [message #458422] Wed, 13 July 2005 09:29 Go to next message
Is there any doc (explanation preferred) on the use of SWT.VIRTUAL style
with the Table? I can't make sense of the javadocs, and if I try the style
all I get no data displayed.
Alex.
Re: VIRTUAL - how to use it? [message #458426 is a reply to message #458422] Wed, 13 July 2005 10:20 Go to previous messageGo to next message
Have a look at this snippet:
http://dev.eclipse.org/viewcvs/index.cgi/org.eclipse.swt.sni ppets/src/org/eclipse/swt/snippets/Snippet151.java?rev=HEAD& amp;content-type=text/vnd.viewcvs-markup
Axel
Re: VIRTUAL - how to use it? [message #458427 is a reply to message #458426] Wed, 13 July 2005 10:26 Go to previous messageGo to next message
>> style with the Table? I can't make sense of the javadocs, and if I try
>> the style all I get no data displayed.
Ok, you wrote "explanation preferred", sorry :) When using
the SWT.VIRTUAL style flag, the table will query a listener
for the rows currently visibile instead of having the program
to fill the table with all rows at once.
So basically you have to add a listener to the table
which creates the necessary table items on the fly
table.addListener(SWT.SetData, new Listener() {
public void handleEvent(Event e) {
TableItem item = (TableItem)e.item;
int index = table.indexOf(item);
item.setText("Item "+data[index]);
and inform the table about the maximum number of rows
your listener could provide:
table.setItemCount(data.length);
table.clearAll();
Hope that helps,
Axel
Re: VIRTUAL - how to use it? [message #458459 is a reply to message #458427] Wed, 13 July 2005 15:47 Go to previous message
Thanks Axel!
Now it makes sense.
"Axel Schlueter" <axel_eclipse@pqrs.de> wrote in message
news:db38at$gh0$1@news.eclipse.org...
> table.clearAll();
> Hope that helps,
> Axel
Previous Topic:Sort indicator in table header
Next Topic:Tab Stops/Keyboard Navigation
Current Time: Sat Jul 19 01:30:10 EDT 2025
Powered by FUDForum. Page generated in 0.25522 seconds
