Cairo rectangle clipping causing JVM crash [message #458247] |
Mon, 11 July 2005 18:39  |
Hi:
I am having a problem on Linux with a JVM crash in Cairo. The same code
works on Windows, and it frequently causes a crash on Linux. I have a
plugin that uses GEF that is trying to draw a repository-style figure on
the screen. I'm using Eclipse 3.1 and GEF 3.1, with advanced graphics
features (anti-aliasing) turned OFF (it also happens when I have it
turned on).
Any help will be much appreciated - it's blocking my migration to 3.1.
I'm also cross-posting this to eclipse.tools.gef forum.
Bradley.
The code looks like:
Rectangle r = <the bounds of the figure>
int ovalHeight = r.width / 3;
int ovalWidth = r.width;
graphics.pushState();
graphics.fillRectangle(r.x,
r.y + ovalHeight / 2,
r.width+1,
r.height - ovalHeight + 1);
graphics.fillArc(r.x, r.y, ovalWidth + 1, ovalHeight+1, 0, 180);
graphics.clipRect(
new org.eclipse.draw2d.geometry.Rectangle(
r.x,
r.y + r.height - ovalHeight / 2,
ovalWidth,
ovalHeight / 2));
graphics.fillOval(r.x, r.y + r.height - ovalHeight + 1, ovalWidth,
ovalHeight));
graphics.restoreState();
graphics.popState ();
The JVM crash looks like:
An unexpected exception has been detected in native code outside the VM.
Unexpected Signal : 11 occurred at PC=0x4E98B2FC
Function=(null)+0x4E98B2FC
Library=libcairo.so.1
NOTE: We are unable to locate the function name symbol for the error
just occurred. Please refer to release documentation for possible
reason and solutions.
Current Java thread:
at org.eclipse.swt.internal.cairo.Cairo.cairo_clip(Native Method)
- locked <0x49b38648> (a java.lang.Class)
at org.eclipse.swt.graphics.GC.setCairoClip(GC.java:2563)
at org.eclipse.swt.graphics.GC.setClipping(GC.java:2598)
at org.eclipse.swt.graphics.GC.setClipping(GC.java:2633)
at
org.eclipse.draw2d.SWTGraphics$RectangleClipping.setOn(SWTGr aphics.java:135)
at org.eclipse.draw2d.SWTGraphics.checkGC(SWTGraphics.java:279)
at org.eclipse.draw2d.SWTGraphics.checkFill(SWTGraphics.java:26 8)
at org.eclipse.draw2d.SWTGraphics.fillOval(SWTGraphics.java:518 )
at org.eclipse.draw2d.Graphics.fillOval(Graphics.java:428)
at org.eclipse.draw2d.ScaledGraphics.fillOval(ScaledGraphics.ja va:316)
at
AcmeStudio.ui.editors.diagram.styles.ElementVisualization.fi llShape(ElementVisualization.java:932)
at
AcmeStudio.ui.editors.diagram.styles.ElementVisualization.fi llShape(ElementVisualization.java:810)
at
AcmeStudio.ui.editors.diagram.figures.AcmeVisElement.fillSha pe(AcmeVisElement.java:110)
at org.eclipse.draw2d.Shape.paintFigure(Shape.java:107)
at
AcmeStudio.ui.editors.diagram.figures.AcmeVisElement.paintFi gure(AcmeVisElement.java:417)
at org.eclipse.draw2d.Figure.paint(Figure.java:1053)
at
AcmeStudio.ui.editors.diagram.figures.SystemView.paintChildr en(SystemView.java:530)
at org.eclipse.draw2d.Figure.paintClientArea(Figure.java:1127)
at org.eclipse.draw2d.Figure.paint(Figure.java:1055)
at
AcmeStudio.ui.editors.diagram.figures.SystemView.paintGraphi cs(SystemView.java:407)
at
AcmeStudio.ui.editors.diagram.figures.SystemView.paint(Syste mView.java:215)
at org.eclipse.draw2d.Figure.paintChildren(Figure.java:1091)
at org.eclipse.draw2d.Figure.paintClientArea(Figure.java:1123)
at
org.eclipse.draw2d.ScalableFreeformLayeredPane.paintClientAr ea(ScalableFreeformLayeredPane.java:69)
at org.eclipse.draw2d.Figure.paintClientArea(Figure.java:1118)
at org.eclipse.draw2d.Viewport.paintClientArea(Viewport.java:15 6)
at
org.eclipse.draw2d.DeferredUpdateManager.repairDamage(Deferr edUpdateManager.java:225)
at
org.eclipse.draw2d.DeferredUpdateManager.performUpdate(Defer redUpdateManager.java:145)
- locked <0x44f7e878> (a org.eclipse.draw2d.DeferredUpdateManager)
at
org.eclipse.draw2d.DeferredUpdateManager$UpdateRequest.run(D eferredUpdateManager.java:40)
at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:3 5)
at
org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchr onizer.java:123)
- locked <0x447815f0> (a org.eclipse.swt.widgets.RunnableLock)
at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.jav a:2844)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2575)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1699)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1663)
at
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:367)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:143)
at
org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:103)
at
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:226)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:376)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:163)
at
at
at java.lang.reflect.Method.invoke(Method.java:324)
at org.eclipse.core.launcher.Main.invokeFramework(Main.java:334 )
at org.eclipse.core.launcher.Main.basicRun(Main.java:278)
at org.eclipse.core.launcher.Main.run(Main.java:973)
at org.eclipse.core.launcher.Main.main(Main.java:948)
Dynamic libraries:
08048000-08056000 r-xp 00000000 03:06 4161571
/usr0/schmerl/j2sdk1.4.2_05/bin/java
08056000-08059000 rw-p 0000d000 03:06 4161571
40000000-40015000 r-xp 00000000 03:01 69634 /lib/ld-2.3.2.so
40015000-40016000 rw-p 00014000 03:01 69634 /lib/ld-2.3.2.so
40017000-4001f000 r-xp 00000000 03:06 5177385
/usr0/schmerl/j2sdk1.4.2_05/jre/lib/i386/native_threads/libh pi.so
4001f000-40020000 rw-p 00007000 03:06 5177385
40020000-4002b000 r-xp 00000000 03:01 69655 /lib/libnss_files-2.3.2.so
4002b000-4002c000 rw-p 0000a000 03:01 69655 /lib/libnss_files-2.3.2.so
4002c000-40030000 rw-s 00000000 03:01 116902
/tmp/hsperfdata_schmerl/9323
40030000-40031000 r--s 00000000 03:06 2343206
/usr0/schmerl/eclipse-3.1/plugins/org.eclipse.swt_3.1.0.jar
40032000-40041000 r-xp 00000000 03:01 69663 /lib/libpthread-0.10.so
40041000-40044000 rw-p 0000f000 03:01 69663 /lib/libpthread-0.10.so
40084000-40086000 r-xp 00000000 03:01 69645 /lib/libdl-2.3.2.so
40086000-40087000 rw-p 00002000 03:01 69645 /lib/libdl-2.3.2.so
40087000-401ba000 r-xp 00000000 03:01 69641 /lib/libc-2.3.2.so
401ba000-401be000 rw-p 00132000 03:01 69641 /lib/libc-2.3.2.so
401c0000-405bc000 r-xp 00000000 03:06 5144612
/usr0/schmerl/j2sdk1.4.2_05/jre/lib/i386/client/libjvm.so
405bc000-405d7000 rw-p 003fb000 03:06 5144612
405e9000-405fb000 r-xp 00000000 03:01 69649 /lib/libnsl-2.3.2.so
405fb000-405fc000 rw-p 00011000 03:01 69649 /lib/libnsl-2.3.2.so
405fe000-4061f000 r-xp 00000000 03:01 69647 /lib/libm-2.3.2.so
4061f000-40620000 rw-p 00020000 03:01 69647 /lib/libm-2.3.2.so
40620000-40630000 r-xp 00000000 03:06 5128229
/usr0/schmerl/j2sdk1.4.2_05/jre/lib/i386/libverify.so
40630000-40632000 rw-p 0000f000 03:06 5128229
40632000-40652000 r-xp 00000000 03:06 5128230
/usr0/schmerl/j2sdk1.4.2_05/jre/lib/i386/libjava.so
40652000-40654000 rw-p 0001f000 03:06 5128230
40654000-40668000 r-xp 00000000 03:06 5128232
/usr0/schmerl/j2sdk1.4.2_05/jre/lib/i386/libzip.so
40668000-4066b000 rw-p 00013000 03:06 5128232
4066b000-4200f000 r--s 00000000 03:06 4341839
/usr0/schmerl/j2sdk1.4.2_05/jre/lib/rt.jar
42059000-4206f000 r--s 00000000 03:06 4341795
/usr0/schmerl/j2sdk1.4.2_05/jre/lib/sunrsasign.jar
4206f000-4214c000 r--s 00000000 03:06 4341836
/usr0/schmerl/j2sdk1.4.2_05/jre/lib/jsse.jar
4214c000-4215d000 r--s 00000000 03:06 4341796
/usr0/schmerl/j2sdk1.4.2_05/jre/lib/jce.jar
4215d000-426b6000 r--s 00000000 03:06 4341837
/usr0/schmerl/j2sdk1.4.2_05/jre/lib/charsets.jar
4475e000-4475f000 r-xp 00000000 03:02 327245
/usr/X11R6/lib/X11/locale/lib/common/xlcUTF8Load.so.2
4475f000-44760000 rw-p 00000000 03:02 327245
4c7e0000-4c9e0000 r--p 00000000 03:02 490786
/usr/lib/locale/locale-archive
4c9e0000-4ca0b000 r-xp 00000000 03:06 5128251
/usr0/schmerl/j2sdk1.4.2_05/jre/lib/i386/libjdwp.so
4ca0b000-4ca0d000 rw-p 0002a000 03:06 5128251
4ca10000-4ca13000 r-xp 00000000 03:06 5128252
/usr0/schmerl/j2sdk1.4.2_05/jre/lib/i386/libdt_socket.so
4ca13000-4ca14000 rw-p 00002000 03:06 5128252
4ca14000-4ca30000 r--s 00000000 03:06 5111842
/usr0/schmerl/j2sdk1.4.2_05/jre/lib/ext/sunjce_provider.jar
4ca30000-4ca33000 r--s 00000000 03:06 5111843
/usr0/schmerl/j2sdk1.4.2_05/jre/lib/ext/dnsns.jar
4ca33000-4ca40000 r--s 00000000 03:06 5111844
/usr0/schmerl/j2sdk1.4.2_05/jre/lib/ext/ldapsec.jar
4ca40000-4cafc000 r--s 00000000 03:06 5111845
/usr0/schmerl/j2sdk1.4.2_05/jre/lib/ext/localedata.jar
4cafc000-4cb04000 r--s 00000000 03:06 2097437
/usr0/schmerl/eclipse-3.1/startup.jar
4cb04000-4cbba000 r--s 00000000 03:06 2343226
/usr0/schmerl/eclipse-3.1/plugins/org.eclipse.osgi_3.1.0.jar
4cbba000-4cbca000 r-xp 00000000 03:06 5128235
/usr0/schmerl/j2sdk1.4.2_05/jre/lib/i386/libnet.so
4cbca000-4cbcb000 rw-p 0000f000 03:06 5128235
4cbcb000-4cbd1000 r-xp 00000000 03:06 5128236
/usr0/schmerl/j2sdk1.4.2_05/jre/lib/i386/libnio.so
4cbd1000-4cbd2000 rw-p 00005000 03:06 5128236
4cbd2000-4cc41000 r--s 00000000 03:06 2343243
/usr0/schmerl/eclipse-3.1/plugins/org.eclipse.core.runtime_3 .1.0.jar
4cc41000-4cc58000 r--s 00000000 03:06 2343225
/usr0/schmerl/eclipse-3.1/plugins/org.eclipse.update.configu rator_3.1.0.jar
4cc58000-4cc6e000 r--s 00000000 03:06 2343223
/usr0/schmerl/eclipse-3.1/plugins/org.eclipse.ant.core_3.1.0 .jar
4cc6e000-4cc7f000 r--s 00000000 03:06 2343202
/usr0/schmerl/eclipse-3.1/plugins/org.eclipse.core.commands_ 3.1.0.jar
4cc7f000-4cc8c000 r--s 00000000 03:06 2343229
/usr0/schmerl/eclipse-3.1/plugins/org.eclipse.core.expressio ns_3.1.0.jar
4cc8c000-4cca2000 r--s 00000000 03:06 2343207
/usr0/schmerl/eclipse-3.1/plugins/org.eclipse.core.filebuffe rs_3.1.0.jar
4cca2000-4cd38000 r--s 00000000 03:06 2343232
/usr0/schmerl/eclipse-3.1/plugins/org.eclipse.core.resources _3.1.0.jar
4cd38000-4cd4d000 r--s 00000000 03:06 2343208
/usr0/schmerl/eclipse-3.1/plugins/org.eclipse.core.runtime.c ompatibility_3.1.0.jar
4cd4d000-4cd54000 r--s 00000000 03:06 2343163
/usr0/schmerl/eclipse-3.1/plugins/org.eclipse.core.variables _3.1.0.jar
4cd54000-4cdc6000 r--s 00000000 03:06 2343135
/usr0/schmerl/eclipse-3.1/plugins/org.eclipse.draw2d_3.1.0.j ar
4cdc6000-4ce7b000 r--s 00000000 03:06 2343138
/usr0/schmerl/eclipse-3.1/plugins/org.eclipse.gef_3.1.0.jar
4ce7b000-4ce8c000 r--s 00000000 03:06 2343220
/usr0/schmerl/eclipse-3.1/plugins/org.eclipse.help_3.1.0.jar
4ce8c000-4ce90000 r--s 00000000 03:06 2343184
/usr0/schmerl/eclipse-3.1/plugins/org.eclipse.help.appserver _3.1.0.jar
4ce90000-4cec5000 r--s 00000000 03:06 2343176
/usr0/schmerl/eclipse-3.1/plugins/org.eclipse.help.base_3.1. 0.jar
4cec5000-4cf68000 r--s 00000000 03:06 2343222
/usr0/schmerl/eclipse-3.1/plugins/org.eclipse.jface_3.1.0.ja r
4cf68000-4d00c000 r--s 00000000 03:06 2343224
/usr0/schmerl/eclipse-3.1/plugins/org.eclipse.jface.text_3.1 .0.jar
4d00c000-4d02f000 r--s 00000000 03:06 2343239
/usr0/schmerl/eclipse-3.1/plugins/org.eclipse.pde.runtime_3. 1.0.jar
4d02f000-4d180000 r--s 00000000 03:06 2343235
/usr0/schmerl/eclipse-3.1/plugins/org.eclipse.swt.gtk.linux. x86_3.1.0.jar
4d180000-4d1ad000 r--s 00000000 03:06 2343227
/usr0/schmerl/eclipse-3.1/plugins/org.eclipse.text_3.1.0.jar
4d1ad000-4d1cb000 r--s 00000000 03:06 2343203
/usr0/schmerl/eclipse-3.1/plugins/org.eclipse.ui_3.1.0.jar
4d1cb000-4d232000 r--s 00000000 03:06 2343230
/usr0/schmerl/eclipse-3.1/plugins/org.eclipse.ui.editors_3.1 .0.jar
4d232000-4d265000 r--s 00000000 03:06 2343242
/usr0/schmerl/eclipse-3.1/plugins/org.eclipse.ui.forms_3.1.0 .jar
4d265000-4d3dd000 r--s 00000000 03:06 2343219
/usr0/schmerl/eclipse-3.1/plugins/org.eclipse.ui.ide_3.1.0.j ar
4d3dd000-4d3ed000 r--s 00000000 03:06 2343216
/usr0/schmerl/eclipse-3.1/plugins/org.eclipse.ui.views_3.1.0 .jar
4d3ed000-4d6a9000 r--s 00000000 03:06 2343240
/usr0/schmerl/eclipse-3.1/plugins/org.eclipse.ui.workbench_3 .1.0.jar
4d6a9000-4d713000 r--s 00000000 03:06 2343209
/usr0/schmerl/eclipse-3.1/plugins/org.eclipse.ui.workbench.t exteditor_3.1.0.jar
4d713000-4d78b000 r--s 00000000 03:06 2343159
/usr0/schmerl/eclipse-3.1/plugins/org.eclipse.update.core_3. 1.0.jar
4d78b000-4d7fb000 r--s 00000000 03:06 2343165
/usr0/schmerl/eclipse-3.1/plugins/org.eclipse.update.ui_3.1. 0.jar
4d7fb000-4d83d000 r-xp 00000000 03:06 7536865
/usr0/schmerl/workspace/.metadata/.plugins/org.eclipse.pde.c ore/AcmeStudio/org.eclipse.osgi/bundles/22/1/.cp/libswt-pi-g tk-3138.so
4d83d000-4d83f000 rw-p 00042000 03:06 7536865
4d83f000-4da88000 r-xp 00000000 03:02 295514
/usr/lib/libgtk-x11-2.0.so.0.200.1
4da88000-4da91000 rw-p 00248000 03:02 295514
4da93000-4da97000 r-xp 00000000 03:02 294504
/usr/lib/libgthread-2.0.so.0.200.1
4da97000-4da98000 rw-p 00003000 03:02 294504
4da98000-4da9e000 r--s 00000000 03:02 147544
/usr/lib/gconv/gconv-modules.cache
4da9e000-4daaa000 r-xp 00000000 03:02 720083
/usr/lib/gtk-2.0/2.2.0/engines/libbluecurve.so
4daaa000-4daab000 rw-p 0000b000 03:02 720083
4daab000-4daac000 r-xp 00000000 03:02 147488 /usr/lib/gconv/ISO8859-1.so
4daac000-4daad000 rw-p 00001000 03:02 147488 /usr/lib/gconv/ISO8859-1.so
4daad000-4daaf000 r-xp 00000000 03:02 327416
/usr/lib/pango/1.2.0/modules/pango-basic-xft.so
4daaf000-4dab0000 rw-p 00001000 03:02 327416
4dab0000-4dab1000 r-xp 00000000 03:02 163787
/usr/kerberos/lib/libcom_err.so.3.0
4dab1000-4dab2000 rw-p 00001000 03:02 163787
4dab3000-4dab7000 r-xp 00000000 03:02 49601
/usr/X11R6/lib/libXtst.so.6.1
4dab7000-4dab8000 rw-p 00004000 03:02 49601
4dab8000-4daca000 r-xp 00000000 03:02 295510
/usr/lib/libgdk_pixbuf-2.0.so.0.200.1
4daca000-4dacb000 rw-p 00011000 03:02 295510
4dacb000-4db34000 r-xp 00000000 03:02 295508
/usr/lib/libgdk-x11-2.0.so.0.200.1
4db34000-4db39000 rw-p 00069000 03:02 295508
4db39000-4db59000 r-xp 00000000 03:02 295501
/usr/lib/libpangoxft-1.0.so.0.200.1
4db59000-4db5a000 rw-p 0001f000 03:02 295501
4db5a000-4db66000 r-xp 00000000 03:02 295499
/usr/lib/libpangox-1.0.so.0.200.1
4db66000-4db67000 rw-p 0000b000 03:02 295499
4db67000-4db8e000 r-xp 00000000 03:02 295495
/usr/lib/libpango-1.0.so.0.200.1
4db8e000-4db9a000 rw-p 00026000 03:02 295495
4db9a000-4dbb1000 r-xp 00000000 03:02 295451
/usr/lib/libatk-1.0.so.0.200.0
4dbb1000-4dbb3000 rw-p 00016000 03:02 295451
4dbb3000-4dbe6000 r-xp 00000000 03:02 294502
/usr/lib/libgobject-2.0.so.0.200.1
4dbe6000-4dbe8000 rw-p 00032000 03:02 294502
4dbe8000-4dbeb000 r-xp 00000000 03:02 294500
/usr/lib/libgmodule-2.0.so.0.200.1
4dbeb000-4dbec000 rw-p 00002000 03:02 294500
4dbec000-4dc55000 r-xp 00000000 03:02 294498
/usr/lib/libglib-2.0.so.0.200.1
4dc55000-4dc56000 rw-p 00069000 03:02 294498
4dc56000-4dc63000 r-xp 00000000 03:02 49577
/usr/X11R6/lib/libXext.so.6.4
4dc63000-4dc64000 rw-p 0000c000 03:02 49577
4dc64000-4dd40000 r-xp 00000000 03:02 49567
/usr/X11R6/lib/libX11.so.6.2
4dd40000-4dd43000 rw-p 000db000 03:02 49567
4dd43000-4dd46000 r-xp 00000000 03:02 49595
/usr/X11R6/lib/libXrandr.so.2.0
4dd46000-4dd47000 rw-p 00002000 03:02 49595
4dd47000-4dd4e000 r-xp 00000000 03:02 49585 /usr/X11R6/lib/libXi.so.6.0
4dd4e000-4dd4f000 rw-p 00006000 03:02 49585 /usr/X11R6/lib/libXi.so.6.0
4dd4f000-4dd60000 r-xp 00000000 03:02 49583
/usr/X11R6/lib/libXft.so.2.1
4dd60000-4dd61000 rw-p 00010000 03:02 49583
4dd61000-4dd68000 r-xp 00000000 03:02 49597
/usr/X11R6/lib/libXrender.so.1.2
4dd68000-4dd69000 rw-p 00006000 03:02 49597
4dd69000-4dd8a000 r-xp 00000000 03:02 295171
/usr/lib/libfontconfig.so.1.0
4dd8a000-4dd8d000 rw-p 00021000 03:02 295171
4dd8e000-4ddda000 r-xp 00000000 03:02 295165
/usr/lib/libfreetype.so.6.3.2
4ddda000-4ddde000 rw-p 0004c000 03:02 295165
4dddf000-4ddfd000 r-xp 00000000 03:02 294488 /usr/lib/libexpat.so.0.4.0
4ddfd000-4ddff000 rw-p 0001e000 03:02 294488 /usr/lib/libexpat.so.0.4.0
4ddff000-4de25000 r-xp 00000000 03:06 7536866
/usr0/schmerl/workspace/.metadata/.plugins/org.eclipse.pde.c ore/AcmeStudio/org.eclipse.osgi/bundles/22/1/.cp/libswt-gtk- 3138.so
4de25000-4de27000 rw-p 00025000 03:06 7536866
4de28000-4de3b000 r--p 00000000 03:02 99039
/usr/X11R6/lib/X11/fonts/Type1/l047013t.pfa
4de3b000-4de42000 r-xp 00000000 03:02 49591 /usr/X11R6/lib/libXp.so.6.2
4de42000-4de43000 rw-p 00006000 03:02 49591 /usr/X11R6/lib/libXp.so.6.2
4de43000-4de4b000 r-xp 00000000 03:02 49575
/usr/X11R6/lib/libXcursor.so.1.0
4de4b000-4de4c000 rw-p 00007000 03:02 49575
4de4c000-4dea3000 r--s 00000000 03:06 4112411
/usr0/schmerl/workspace/AcmeStudio/lib/log4j-1.2.8.jar
4dea3000-4deb5000 r--p 00000000 03:02 99049
/usr/X11R6/lib/X11/fonts/Type1/l048016t.pfa
4deb5000-4debd000 r-xp 00000000 03:02 49565 /usr/X11R6/lib/libSM.so.6.0
4debd000-4debe000 rw-p 00007000 03:02 49565 /usr/X11R6/lib/libSM.so.6.0
4debe000-4dec1000 r-xp 00000000 03:06 7536867
/usr0/schmerl/workspace/.metadata/.plugins/org.eclipse.pde.c ore/AcmeStudio/org.eclipse.osgi/bundles/22/1/.cp/libswt-gnom e-gtk-3138.so
4dec1000-4dec2000 rw-p 00002000 03:06 7536867
4dec2000-4dec6000 r-xp 00000000 03:02 295482
/usr/lib/libORBitCosNaming-2.so.0.0.0
4dec6000-4dec7000 rw-p 00004000 03:02 295482
4dec7000-4ded9000 r--p 00000000 03:02 99053
/usr/X11R6/lib/X11/fonts/Type1/l048036t.pfa
4ded9000-4deeb000 r--p 00000000 03:02 99047
/usr/X11R6/lib/X11/fonts/Type1/l048013t.pfa
4deec000-4df00000 r--p 00000000 03:02 99041
/usr/X11R6/lib/X11/fonts/Type1/l047016t.pfa
4df00000-4df13000 r-xp 00000000 03:02 295525
/usr/lib/libgnome-2.so.0.200.0
4df13000-4df14000 rw-p 00013000 03:02 295525
4df14000-4df28000 r--p 00000000 03:02 99045
/usr/X11R6/lib/X11/fonts/Type1/l047036t.pfa
4df28000-4e1f9000 r-xp 00000000 03:06 5128240
/usr0/schmerl/j2sdk1.4.2_05/jre/lib/i386/libawt.so
4e1f9000-4e20f000 rw-p 002d0000 03:06 5128240
4e234000-4e287000 r-xp 00000000 03:06 5128239
/usr0/schmerl/j2sdk1.4.2_05/jre/lib/i386/libmlib_image.so
4e287000-4e288000 rw-p 00052000 03:06 5128239
4e288000-4e299000 r-xp 00000000 03:02 295488
/usr/lib/libbonobo-activation.so.4.0.0
4e299000-4e29b000 rw-p 00011000 03:02 295488
4e29b000-4e2a2000 r-xp 00000000 03:02 295478 /usr/lib/liblinc.so.1.0.0
4e2a2000-4e2a3000 rw-p 00006000 03:02 295478 /usr/lib/liblinc.so.1.0.0
4e2a3000-4e2f1000 r-xp 00000000 03:02 49599 /usr/X11R6/lib/libXt.so.6.0
4e2f1000-4e2f5000 rw-p 0004d000 03:02 49599 /usr/X11R6/lib/libXt.so.6.0
4e2f5000-4e309000 r-xp 00000000 03:02 49561
/usr/X11R6/lib/libICE.so.6.3
4e309000-4e30a000 rw-p 00013000 03:02 49561
4e30c000-4e3c6000 r-xp 00000000 03:06 5128243
/usr0/schmerl/j2sdk1.4.2_05/jre/lib/i386/libfontmanager.so
4e3c6000-4e3e1000 rw-p 000b9000 03:06 5128243
4e3e2000-4e419000 r-xp 00000000 03:02 295521
/usr/lib/libgnomevfs-2.so.0.0.0
4e419000-4e41b000 rw-p 00036000 03:02 295521
4e41b000-4e4a3000 r-xp 00000000 03:02 295538
/usr/lib/libgnomeui-2.so.0.200.0
4e4a3000-4e4a6000 rw-p 00088000 03:02 295538
4e4a6000-4e4d9000 r-xp 00000000 03:02 295517
/usr/lib/libgconf-2.so.4.1.0
4e4d9000-4e4dc000 rw-p 00033000 03:02 295517
4e4dc000-4e515000 r-xp 00000000 03:02 295480
/usr/lib/libORBit-2.so.0.0.0
4e515000-4e51e000 rw-p 00038000 03:02 295480
4e51e000-4e5fd000 r-xp 00000000 03:02 295206 /usr/lib/libxml2.so.2.5.4
4e5fd000-4e608000 rw-p 000de000 03:02 295206 /usr/lib/libxml2.so.2.5.4
4e609000-4e615000 r-xp 00000000 03:02 294585 /usr/lib/libz.so.1.1.4
4e615000-4e617000 rw-p 0000b000 03:02 294585 /usr/lib/libz.so.1.1.4
4e617000-4e61f000 r-xp 00000000 03:06 7536870
/usr0/schmerl/workspace/.metadata/.plugins/org.eclipse.pde.c ore/AcmeStudio/org.eclipse.osgi/bundles/22/1/.cp/libswt-cair o-gtk-3138.so
4e61f000-4e620000 rw-p 00007000 03:06 7536870
4e620000-4e632000 r--p 00000000 03:02 99047
4e632000-4e664000 r-xp 00000000 03:01 69698 /lib/libssl.so.0.9.7a
4e664000-4e667000 rw-p 00032000 03:01 69698 /lib/libssl.so.0.9.7a
4e667000-4e743000 r-xp 00000000 03:01 69697 /lib/libcrypto.so.0.9.7a
4e743000-4e755000 rw-p 000db000 03:01 69697 /lib/libcrypto.so.0.9.7a
4e758000-4e75e000 r-xp 00000000 03:01 69667 /lib/librt-2.3.2.so
4e75e000-4e760000 rw-p 00005000 03:01 69667 /lib/librt-2.3.2.so
4e76a000-4e7b8000 r-xp 00000000 03:02 295492
/usr/lib/libbonobo-2.so.0.0.0
4e7b8000-4e7c1000 rw-p 0004e000 03:02 295492
4e7c1000-4e7c8000 r-xp 00000000 03:02 295467 /usr/lib/libesd.so.0.2.28
4e7c8000-4e7c9000 rw-p 00006000 03:02 295467 /usr/lib/libesd.so.0.2.28
4e7c9000-4e7eb000 r-xp 00000000 03:02 295455
/usr/lib/libaudiofile.so.0.0.2
4e7eb000-4e7ee000 rw-p 00021000 03:02 295455
4e7ee000-4e7f5000 r-xp 00000000 03:02 294524 /usr/lib/libpopt.so.0.0.0
4e7f5000-4e7f6000 rw-p 00006000 03:02 294524 /usr/lib/libpopt.so.0.0.0
4e7f6000-4e855000 r-xp 00000000 03:02 295536
/usr/lib/libbonoboui-2.so.0.0.0
4e855000-4e858000 rw-p 0005f000 03:02 295536
4e858000-4e884000 r-xp 00000000 03:02 295530
/usr/lib/libgnomecanvas-2.so.0.200.0
4e884000-4e885000 rw-p 0002c000 03:02 295530
4e885000-4e89a000 r-xp 00000000 03:02 295474
/usr/lib/libart_lgpl_2.so.2.3.11
4e89a000-4e89b000 rw-p 00015000 03:02 295474
4e89b000-4e8bc000 r-xp 00000000 03:02 295497
/usr/lib/libpangoft2-1.0.so.0.200.1
4e8bc000-4e8bd000 rw-p 00021000 03:02 295497
4e8bd000-4e8da000 r-xp 00000000 03:02 295178 /usr/lib/libjpeg.so.62.0.0
4e8da000-4e8db000 rw-p 0001d000 03:02 295178 /usr/lib/libjpeg.so.62.0.0
4e8db000-4e8ea000 r-xp 00000000 03:01 69665 /lib/libresolv-2.3.2.so
4e8ea000-4e8eb000 rw-p 0000f000 03:01 69665 /lib/libresolv-2.3.2.so
4e8ed000-4e8ff000 r-xp 00000000 03:02 163793
/usr/kerberos/lib/libgssapi_krb5.so.2.2
4e8ff000-4e900000 rw-p 00011000 03:02 163793
4e900000-4e95c000 r-xp 00000000 03:02 163807
/usr/kerberos/lib/libkrb5.so.3.1
4e95c000-4e95e000 rw-p 0005c000 03:02 163807
4e95e000-4e96d000 r-xp 00000000 03:02 163797
/usr/kerberos/lib/libk5crypto.so.3.0
4e96d000-4e96e000 rw-p 0000f000 03:02 163797
4e96e000-4e99e000 r-xp 00000000 03:06 2097431
/usr0/schmerl/eclipse-3.1/libcairo.so.1
4e99e000-4e99f000 rw-p 00030000 03:06 2097431
Heap at VM Abort:
Heap
def new generation total 576K, used 155K [0x44760000, 0x44800000,
0x44c40000)
eden space 512K, 27% used [0x44760000, 0x447839c8, 0x447e0000)
from space 64K, 20% used [0x447e0000, 0x447e3430, 0x447f0000)
to space 64K, 0% used [0x447f0000, 0x447f0000, 0x44800000)
tenured generation total 5568K, used 4077K [0x44c40000, 0x451b0000,
0x48760000)
the space 5568K, 73% used [0x44c40000, 0x4503b498, 0x4503b600,
0x451b0000)
compacting perm gen total 20736K, used 20723K [0x48760000,
0x49ba0000, 0x4c760000)
the space 20736K, 99% used [0x48760000, 0x49b9cfa0, 0x49b9d000,
0x49ba0000)
Local Time = Mon Jul 11 18:21:13 2005
Elapsed Time = 19
# The exception above was detected in native code outside the VM
# Java VM: Java HotSpot(TM) Client VM (1.4.2_05-b04 mixed mode)
# An error report file has been saved as hs_err_pid9323.log.
# Please refer to the file for further information.
Re: Cairo rectangle clipping causing JVM crash [message #458270 is a reply to message #458266] |
Tue, 12 July 2005 10:24  |
Turning it OFF actually turns advanced graphics ON. There is no reason to
make that call on any platform except Mac, where the default is AA on.
> Yes. I am calling setAntialias (SWT.OFF). I guess a workaround would be
> not to call any of the advanced graphics routines if I'm on Linux.
FUDForum. Page generated in 0.04255 seconds
