Home » Eclipse Projects » Standard Widget Toolkit (SWT) » Where is source and JavaDoc for SWT & JFace
Where is source and JavaDoc for SWT & JFace [message #458093] |
Sat, 09 July 2005 18:29  |
Could someone explain how/where to find the JavaDoc and source for SWT and
JFace?
Once we find it, we expect that we'll be able to right click on their jars
and set the JavaDoc location. We used to do that with eclipse 3.0.x once
we figured out where it was buried in under the plugins folder, which is
now restructured. We couldn't find mention of this in "New and
Noteworthy," which is a long list of cool stuff (but would sure benefit
from a table of contents at the beginning).
Bottom line, what we want to do is this:
1. In source editor, click on a SWT or JFace class name.
2. Hit F1.
3. See a list that includes "Show Javadoc for classname"
BTW, the above has always worked for us with every class from Sun. We
simply install their JDK (1.4 or 5.0) and it simply works in Eclipse. No
wonder NetBeans people are asking questions like this.
Eclipse team: would it be asking too much for that to also work
straightaway for SWT and JFace?
Re: Where is source and JavaDoc for SWT & JFace [message #458096 is a reply to message #458093] |
Sat, 09 July 2005 21:25   |
> and JFace?
> jars and set the JavaDoc location. We used to do that with eclipse
> 3.0.x once we figured out where it was buried in under the plugins
> folder, which is now restructured.
You should not need to manually attach a source location. If I were
to guess, I bet you are writing a Java project, and then adding the SWT
and JFace jar files as external jar dependencies. Am I correct?
For writing a standalone SWT application, I recommend importing SWT
into your workspace, either from the standalone SWT .zip file (which you
can now import using the "Existing Projects into Workspace" wizard) or
using the "External Plug-ins and Fragments" wizard. Either method will
give you code assist with documentation, and the Javadoc will appear
correctly in the Javadoc view.
If you really don't want to have SWT and JFace imported in your
workspace, you can also create a Plug-In project, but just write a Java
application within it. This will let Eclipse's plug-in architecture
take care of finding the jar and source, all you need to do is make your
plug-in depend on SWT and JFace.
> 2. Hit F1.
This feature of the Help view is really interesting, I have not seen
it before. The Javadoc for SWT is included in the API reference in the
Help > Help Conents window, but I do not know where it is stored, nor
how to hook it up. Clearly, if there is a way we can ship the Javadoc
with the standalone SWT download such that it "just works", I'd be very
much in favour of that.
I filed the following two bugs:
http://bugs.eclipse.org/bugs/show_bug.cgi?id=103261
http://bugs.eclipse.org/bugs/show_bug.cgi?id=103262
Hope this helps,
-Billy
Re: Where is source and JavaDoc for SWT & JFace [message #458620 is a reply to message #458096] |
Sat, 16 July 2005 18:45  |
Billy Biggs wrote:
>> and JFace?
>> 2. Hit F1.
> Hope this helps,
> -Billy
Thank you very much, Billy, for the energy and thoughtfulness of your
reply. We will study your response.
We are using the excellent GUI designer available at SWT-Designer.com.
Thus, it kicks things off for us, but we do want to use the F1 key as
described above.
What we figured out is shown below.
Sadly, I am left wondering:
* why I, a newbie, can't find answers to questions like this in the FAQ
and numerous eclipse books we've purchased
* are other developers actually happy not having this (F1 key feature)?
* why does this had to be so hard to figure out and has to done over and
over for each and every project -- something no other IDE maker in the
world wouldn't dream of not doing this for you?
I can't believe any of the above are true, since everything about eclipse
is so excellent.
Our procedure (based on installing eclispe into c:\eclipse):
1. Create folder: c:\eclipse_doc. Making this independent from c:\eclipse
avoids having to redo these steps if the main eclipse folder is ever
deleted which we've done plenty of times to fix problems (that might be
our own fault).
2. Unzip the following file into the above folder.
c:\eclipse\plugins\org.eclipse.platform.doc.isv_3.1.0\doc.zi p
3. In the Package Explorer window, find the SWT and JFace library jar
files. Starting with Eclipse 3.1, swt.jar has been renamed to the file
highlighted in the screenshot below. JFace, which is not machine
dependent, is the file right shown below it.
==(screenshots can't be shown here, sorry)==
4. For each of the above jar files:
· Right click, select Properties.
· Select Java Build Path.
· Click on Browse.
· Navigate to C:/eclipse_doc/reference/api/
· Click on OK.
5. Click on Validate. Success looks like the following.
6. Now do the real test. In the source editor, click on an SWT control
class name such as Combo (you can simply declare one or make one visually
using the designer). Press F1. A window should appear with Javadoc for
'org.eclipse.swt.widgets.Combo'
7. Don't forget to do the same for the JFace library as well. Test this
with a JFace class such as ApplicationWindow.
Current Time: Sat Jul 26 14:16:40 EDT 2025
Powered by FUDForum. Page generated in 0.26622 seconds
